Question about Whirlpool GI6FARXXF
Whirlpool model gi6fdrxxxyo7 leaking
Freezer compartment has ice in the bottom water is leaking out onto floor
  • 1462 Answers
SOURCE: Freezing water in bottom of Whirlpool Gold
remove back panel inside freezer. you will see a tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely
Posted on Nov 26, 2008
Tech007
  • 63 Answers
SOURCE: water in bottom of fridge
THE DRIAN HOLE IS CLOGGED ITS IN FREZZOR IN THE BACK BEHIND THE BACK PANEL BUT YOU CAN LOOK UNDER THE FRIDGE AND FIND THE OTHER END OF THE DRIAN HOSE BLOW AIR TROUGH IT TO CLEAN IT OUT MAKE SURE THE FRIDG IS OFF FOR A DAY, OPEN FREEZOR DOOR TO MELT ICE IN DRIAN HOLE AND HOSE AIR PRESSOR MAY NOT BLOW THE ICE BLOCKAGE OUT DEFROST FOR A DAY THEN IT WILL CLEAN UP NICE
Posted on Aug 30, 2007
Master_Tech
  • 770 Answers
SOURCE: Water Leak
pull the funnel tube out of the back wall and clean the drain that goes out the back wall of the refrig section
Posted on Feb 18, 2008
Thanks to all who spent money or shared their experience to have somebody do this repair, and I really mean it.
I have a Whirlpool TopLoad Fridge (not a side by side).
Things you'll need
30 minutes
Small socket for cardboard panel on lower back and panel inside freezer
Bicycle Pump
4 Towels
Hair Dryer
1. Take everything out of freezer
2. Turn dials off in fridge for both compartments
3. Pull fridge out so you can get behind it and unplug it
4. Be vigilant of ice maker line if installed
5. Pull cardboard panel off on back
On the left side you should see the back of the skinny drip pan and a small line. That line goes from the freezer and is most likely clogged.
6. Blow dry the back of the freezer enough so the ice is thawed at the bottom of the back panel.
7. Remove the two screws on the back panel. You may just be able to pull it toward you enough to get behind it. You'll see the coils and fan, and underneath these you may see some ice sheets and there should be a hole. That is the drain line that is clogged. I heated up some water and poured it over the drain to thaw the line. You may want to remove the crisper drawers and put some towels down there to catch the overflow. Once the ice is thawed enough at the drain. Go to the back of the fridge and place the end of the bicycle pump at the bottom of the drain hose. Apply pressure to get a good seal but keep pumping. You may have to go back and forth between pumping and thawing, but you'll know it is clear when you hear air going into the freezer and then the wonderful moment when water drips into the drip pan as advertised!
Keep those fridges less full so that the door stays sealed and keep the seal clean and also keep your doors from having too much stuff so the weight of the door doesn't pull away.
Okay, put it back together, turn everything on and be careful of your cord and lines when pushing the fridge back. Thank the Lord ours has wheels and man,was it cruddy underneath. Vacuum those coils underneath the fridge too for proper air circulation.
Blessings to you!
tay
Posted on Jan 11, 2009
gaeb7
  • 25 Answers
SOURCE: hotpoint csx22bc 21.7 cu. ft. leaking water on freezer side
Look for obstruction at the drain tray for the freezer. Common to have plastic wrap sucked into that area.Or gunk in the drain line. Blow through line to insure the gunk is not an issue.
Posted on Mar 01, 2009
Whirlpool GX2SHBXVY05 refrigerator leaking from bottom freezer onto floor.
if it has an ice maker check the water feed hose for leaks.
also I have a freezer that ices up twice a year. poor design. have to defrost every now and then.
Jun 09, 2015 | Refrigerators
WHY IS MY SIDE BY SIDE WHIRLPOOL leaking water onto floor?
normally caused by a clogged drain in back of freezer . check to see if you have ice build up on bottom of freezer..... gently chip away ice in freezer and turkey baste hot water into drain hole until water flows freely
Aug 27, 2014 | Whirlpool Refrigerators
What causes ice build up in bottom of freezer with french doors and then leaks out
sounds to me like a bad door seals causing condensation and leakage
Aug 23, 2014 | Whirlpool Refrigerators
How to access drain hole for maytag model mf12269vem3
please check your ice maker to make sure it is not jammed up water can leak into fridge
Nov 01, 2013 | Freezers
Water on floor - french door refrigerator with freezer below
Yes the bottom compartment does have a drain opening but to see it you will need to remove the rear panel covering the evaporator inside the back wall of the freezer compartment. See item location number 11 on page 3 of the parts list. That will need to be removed so you can reach the drain inside the freezer compartment. The fresh food section also has a drain. Here is a=> AFF2534FEB4 Parts List and AFF2534FEB4 User Manual I am here to answer any questions you may have, Thanks Sea Breeze
Leaking Refrigerators
Jul 23, 2013 | Whirlpool Amana Refrigerator Water Filter...
Ice build up in freezer compartment until water flows onto floor.
Hi, Is this a wwhirlpool brand fridge?
The drain is plugged in the freezer section. If I could get model #,I can get you ezact instructions.
If the floor panel in the freezer has screws holding it in, remove the fllor panel. Now you will need to remove the rear panel inside the freezer as well.
If this is a Whirlpool brand, there is an after market drain heat strip that you will need to add to the defrost heater.
Please let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | Refrigerators
Amana bottom freezer: water leaking & ice build-up
There should be some kind of drain at bottom of freezer compartment to collect and run off any condensate that collects during defrost cycle.. Clean out the drain and snake out the line that leads from it. Right now the liquid is collecting where it should not and it will leak out the gasket when you have enough of it.
Sep 09, 2017 | Amana ABB1927DE Bottom Freezer...
Whirlpool GI6FARXXF Logo
49 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
