Coby tftv1913t i have coby tf tv1913t ..........002f19-1310e1r all function is ok but do not chang mode select on ly on av mode and picture is out off zoom .zoom function is work but width is over on sides
  • 6 Answers
SOURCE: Can't take pictures-all buttuns don't work
hi, look for my answer in another fx8 topic! there is a soft reset combination. just switch to record mode, press the shooter button, hold it down, and switch the camera on. it is a some kind of reset. it worked me.
Posted on Jul 12, 2007
  • 3 Answers
SOURCE: Coby TF-DVD7050 no video.just a blue screen
you simply need a new screen
Posted on Jul 20, 2008
  • 3 Answers
SOURCE: download manual for coby tf-dvd7100
Go to www.cobyusa.com
Click on Support.
Go to FAQ's.
Under DVD's, click on the question that gives you the PDF of the manual.
It's about 24 pages in length.
Posted on Oct 26, 2008
ramon49
  • 111 Answers
SOURCE: Aspect ratio
this is normal as you are looking at WIDE screen aspect ..
Posted on Mar 27, 2009
  • 133 Answers
SOURCE: my coby tv remote is not working, for my coby TV model Tf-TV1913
There are no universal remotes compatible with any of Coby's televisions. You can get a replacement original from www.remotes.com
Posted on Jun 04, 2010
Tf d Ihave a tf dvd7100 I am trying to hook it up to my tv to plac a movie cd
HI,
Before connecting the the DVD to your TV First of all you have to the audio out put of your for the do the following using the setup menu.
Press SETUP button of of the DVD player to show "setup" menu. Select the audio setup the select the digital out then change to OFF from SPIDF/RAW.
Here i have added a picture which shows how to hookup the dvd player to a TV. Its for the same model that you have .
to make the connection you need two codes
1. 3.5mm stereo to two RCA (for audio)
2. 3.5mm mono to single RCA(for video)
connect the first cord to inoptical/audio and second one to video output of the dvd player.
connect the cable which comes from the video out out of dvd to the video input (yellow) of your TV. then connect the cable which comes from the inoptical/audio of the dvd player to the audio input of the TV (red and white ).
You have to select the input of your TV by pressing the AV/ source selection on the remote of the TV. check where you made the connection on the tv AV 1 or AV 2. then select the corresponding input. hope you will get it worked.
Also Added the image of the cable that you need to make the connections.
25383850-eev1v0sv1zwox43luwgxtns5-4-5.jpg 3.5mm stereo to two RCA (for audio)
Electronics Equipment Repair Center
Jan 25, 2015 | Coby TF-DVD7107 Portable DVD Player
Coby TF-DVD8500: "AV" code in upper left corner, won't play.
AV stands for audio video input..is that where you have your input coming from?
Feb 11, 2018 | Coby TF-DVD8500 DVD Player
Problem with Coby TF-TV3217 32 in. LCD TV
sounds like there is a fault with the tv or there is a bad cable.but you have tried av cables to. I would use another tv for time being. capacitors in the tv may be week and need changing. if its been used alot by i mean on and off a lot then it will wear out quicker than normal use. and the startup wear components out a lot quicker than normal home use.
May 20, 2013 | Coby TF-TV3217 32 in. LCD TV
No audio from my DVD Player, don't know how to plug in the cables in the back
ok,red and white are audio (left and right),you come OUT of DVD player and INTO TV (via your AV inputs),then make sure you telle is switched to AV
Rod
Apr 29, 2009 | Coby TF-DVD7005 Portable DVD Player
Says "AV" at the top of the screen and then won't play. Help?
With the player in front of you, look at the right hand side you should see a volume selection, phone, optical/audio video then in av out slide that button to out. You will no longer see av on the screen.
Apr 12, 2009 | Coby TF-DVD7100 Portable DVD Player
No Sound when playing a video game on Coby Pertable DVD player
Do you have the audio plugs in the proper spot? The red & white audio plugs from the PS 2 need to be plugged into the audio in jacks on the portable dvd player in order to get sound. Should match up red to red; white to white for sound, yellow to yellow for video. Hope this helps.
Feb 03, 2009 | Coby TF-DVD1023 Player
Coby TF-DVD1540
Yes, use a VGA Cable and conect it. just select source to pc.
May 04, 2008 | Coby TF-DVD1540 15 in. TV/DVD Combo
Computers & Internet Logo
David Payne
David Payne
