Question about LG WM3470H TurboWash Series 4.0 cu. ft.
Why won't all water come out of drain tube because when trying to clean filter lots of water comes out on floor?
I have tried to drain water from tube on lower front of washer. About 1 oz. comes out after 25 loades of clothes. Then as I am removing filter beside drain tube, water is pouring out on floor. Why? Filter has nothing in it. So why is water not go to drain tube?
jason0110
  • 66 Answers
SOURCE: Water won't drain
make sure there is power getting to the pump if so then your pump has stopped working or may be blocked if not than it will most likly be your pcb
Posted on Sep 14, 2007
johnychel
  • 796 Answers
SOURCE: spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Posted on Mar 23, 2008
SOURCE: How to clean out drain hose
I was actually able to fix this problem by blowing out the drain hose with an air compressor. The drain hose was full of beach sand.
Posted on Sep 16, 2008
MNTECH
  • 1543 Answers
SOURCE: LG WM2016CW won't drain
The impeller may have come off the pump motor shaft. Generally, you will notice a louder sound when the pump runs if this happened.
Unplug the machine. Remove the filter recess by removing the one screw inside and using a putty knife at the left and / or right edge and popping it out. Pull the machine out about 18 inches and tip it back, resting it against the wall. Remove two more screws behind where the recess was holding the pump housing on. Reach under the machine and remove pump. There is a tab to depress under the pump housing to release it from the base. The pump motor is held onto the housing by three screws. Remove them and inspect the impeller to see if it has come off the shaft. If it has, pushing it back on will not solve the problem, as it will come off again. Install new pump motor and reassemble. Clean washer tub with the longest, hottest cycle and three Ah-fresh tablets, Whirlaway hot tub cleaner, Smellywasher cleaner (smellywashercleaner.com) or Tide washer cleaner. Repeat. From now on, use only 1 tablespoon of HE laundry detergent per load (1/2 T if 2X concentrate) and only 1 teaspoon of fabric softener per load if you use it. (these machines use very little water, and thus require reduced amounts of additives to work properly)
Posted on Feb 08, 2009
SOURCE: LG WM2010CW filter drain no draining
In all likelihood the rubber drain hose is clogged. I had the same problem with my LG front loader. The hose was clogged with sand and dirt almost the entire length of the hose. The following solution is far simpler than taking the dryer apart to clear the drain hose. Besides I figure this same thing could keep reoccurring with all the sand and dirt we get in our clothes here in East Texas.
I purchased about 4 feet of 3/16 inch OD vinyl tubing and adapted it to fit on the end of a garden hose. The adapter gizmo included a valve so I could control the water flow and not give myself a bath. A picture of the gizmo is included below. Make sure that when you connect the water hose to the faucet that the faucet valve is just slightly opened and that the gizmo valve is closed. Using the gizmo is straight forward. First remove the drain filter and than insert the vinyl tubing in the end of the rubber drain hose and slowly open the valve on the gizmo. Make sure you have a large pan or bucket underneath the drain hose to catch the debris and water. Slowly advance the tubing up inside the hose until it won’t go any further. By this time water will also be running out of the drain filter cavity which will indicate the clog has been removed. Continue back flushing for a few more seconds to assure all the debris has been cleared, than clean up and you’re finished.
Posted on Mar 16, 2010
After I drain water from the drain tube, I pull out the filter and a lot more water comes out there. What would prevent all of the water coming out the drain tube. And how do I fix that.
I assume that you are referring to the small rubber drain tube that is coiled up in the filter tray compartment. Manually draining the tub with this small tube will remove most of the water, but a certain amount is still present in the sump. It is best to place an old towel on the floor around the filter section when removing it.
The OE error code tells you that there is a problem with your drain pump, Check the pump impeller to see whether it turns freely and the coil for continuity, check that the coil does not have zero Ohms or no reading at all, the coil should have a resistance reading on the meter.
Oct 12, 2014 | LG Washing Machines
Why won't the aircondition drain won't drain
If you are saying the ac is dumping water into the cabin floor, the drain tube is probably stopped up. The tube should be under the car near the passenger's feet. You would insert a coat hanger or other stiff object to clean out the tube.
Jul 03, 2012 | 2005 Chevrolet Cobalt
Why is my Miele Novotronic w1512 saying Drain fault?
I have the same problem, i have cleaned the filter area and there was a plastic sweet wrapper in there also. However, I have put the machine back on an express cycle ans still have the error message coming up?? Drain Fault! I then tried to spin and the spin cycle wasn't working eithet. Whilst the machine was still on i patially undone the filter cap and removed a full tray of water, it then began to spin. What could yhe problem be?
May 21, 2012 | Miele Washing Machines
Dishwasher won't start - I get an F7 message on my ADP5966
Remove the filter on the floor of the machine, including the metal grill. Press & hold the start button (like you do when you want to cancel a programme). this will drain the water out of your clogged up drain outlet. Clean your filter and grill and replace it. My guess is that the sensor in the drain (a little glass tube) measures whether the water going out is clean enough to decide that your dishes are now rinsed correctly. If your filter's clogged, the water going down the drain is still dirty. After a while it gets sick of trying and stops the machine. F7 in whirlpoolese may mean "Clean my filter
Dec 17, 2010 | Whirlpool 24 in. ADP5966 Free-standing...
Water is left in the bottom of the dishwasher after the cycle is done
Sounds like a partial blockage in the drain-check drain tube and drain it plugs into. Could try disconnecting drain tube from sink drain and lower it close to floor level into shallow pan. I excess water come out slowly blockage prob. in tube or filter screen in washer.
Oct 09, 2009 | Dishwashers
What does F7 mean on a whirlpool 6th sense washing machine?
F7 in whirlpools means "Clean the filter”.
The following troubleshooting steps would help fix it. Remove the filter on the floor of the machine, including the metal grill. Press & hold the start button (like you do when you want to cancel a program this will drain the water out of your clogged up drain outlet. Clean your filter and grill and replace it. My guess is that the sensor in the drain (a little glass tube) measures whether the water going out is clean enough to decide that your dishes are now rinsed correctly. If your filters clogged, the water going down the drain is still dirty. After a while it gets sick of trying and stops the machine.
Thank you for contacting www.Fixya.com
Jul 30, 2009 | Whirlpool Washing Machines
May 11, 2009 | LG Washing Machines
I need a picture of the windshield drain on a 2001 catera cadillac. It seems the tube does not go all the way down to the drain. It is leaking into the body this can't be good.
You need to clean out the cabin filter drain tube. The cabin filter housing allows the air to enter the cabin through the HVAC system. When water gets in here, the drain tube allows it to escape. If the drain tube is plugged with leaves and dirt, the housing fills up and it overflows into passenger floor area.
Remove the filter, clean the drain tube (prepare to get your feet wet) and put in a new filter.
The filter is below the pass side WS wiper under the plastic cover.
Mar 18, 2009 | 2001 Cadillac Catera
Lots of water in side fridge cannot reach lower pan gets past seal on to floor
hi thanks for the question the drain tube is clogged up pull fridge from wall remove back panel if any locate drain tube in the drain tray clean replace .try that thanks the appliance doc
Sep 28, 2008 | Whirlpool Refrigerators
LG WM3470H TurboWash Series 4.0 cu. ft. Logo
32 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
