Question about Bernina Sewing Machines
Needle stuck in left position
I just bought a Bernette 15 (London 5) and as I was learning what all the functions were, I noticed my needle, on normal stitching, is over on the left. I cannot get it to center out and the handbook that came with the machine is not helping. Most other stitches it centers out for, but the straight line stitching the needle veers left and if I were to try sewing with it like that it'd just bump into the pressure foot and/or the feeder. I'm at a loss and really want to use my beautiful machine.
5 Suggested Answers
  • 188 Answers
SOURCE: needle stuck in right position, will only sew tiny,tiny stitches
oil it. down the shaft if you can get to it. and where ever there is a hole it always helps.
Posted on Mar 26, 2009
  • 1116 Answers
SOURCE: Pfaff 7530/ electronic problem?
Where has it been for ten years? This could have a big affect on an electronic sewing machine.
Take the machine in to a sewing machine shop for service.
Posted on Feb 22, 2010
  • 20 Answers
SOURCE: I cannot ser a straight
Some machines are not designed to sew the straight stitch with the needle in the center position. Some are left or right position to do that and it is simply the way they were designed. Linda at Relics
Posted on Jul 05, 2011
SOURCE: Viking 1+ Horizontal movement quit working after needle hit something
it sounds like you knocked the machine out of time & it will have to be taken to a
sewing machine shop to be retimed
Posted on Apr 27, 2012
How do I change the needle on my Bernette 303 overlocker
To be sure you don't drop the needle down inside the machine, place a piece of paper or fabric across the needle plate. There are 2 tiny screws above the needles. One does the right needle, the other does the left needle. Loosen the screw (do not loosen the screw so much that it will fall out--they are Hard to find!). Pull out the old needle. Push the new needle up into the hole (the flat side should face the back of the machine). Hold the needle in place while you tighten the screw.
Bernina Bernette 303 334D 335 Serger
Aug 14, 2017 | Sewing Machines
Is there a way to do a manual buttonhole on a Bernette 65 since I so not have an automatic buttonhole foot
all sewing machines can make manual buttonholes. when the machine is adjustable stitch length, stitch width and needle position.
stitch length should be short.
stitch width to be set en route between 2 and 5 at the ends.
needle position must also be set on the way
you have to try and make some test before you get it right
good Luck ;)
Apr 27, 2014 | Sewing Machines
Needle sticks
Bent needle and dirty machine or machine in need of a proper COA (tuneup) are my first thoughts.
Jan 21, 2014 | Bernina Bernette 75
My needle gets stuck and its bending.I changed the needle but didn't work!
OK. There are many types of needle. Are you using the correct one?
Is it NEW? How thick is what you are sewing? On from there, feeddog timing could be out.
If sewing 'normal' fabric, does it still have the issue?
Oct 14, 2013 | Bernina BERNETTE 65 Mechanical Sewing...
Machine embroidery needle changes position
truthfully I think their something wrong with the computer in the machine because
the bobbin locked up. sometimes when a sewing machine jams it can make
the machine jump time.
but the needle moved positions, some part of the machine is changed during the
jam up, even tho you reset it.
embroidery machine are expensive, my suggestion is to have the machine checked
Apr 05, 2012 | Sewing Machines
Making a buttonhole on a Necchi 3204 sewing machine
Here's what the manual says:
Before sewing, fit the button-hold foot to the machine (long white plastic thing with red, ruler like markings).
Select the pattern selector dial that is solid green on the left hand side. Set the dial to "1" position. Sew the left side and raise the needle.
Select the pattern selector dial that is solid green on the top and bottom. Set the dial to "2" position. Sew 5-6 stitches and raise the needle.
Select the pattern selector dial that is solid green on the right hand side. Set the dial to "3" position. Sew the right side. Raise the needle.
Select the pattern selector dial that is solid green on the top and bottom. Set the dial to "4" position. Sew 5-6 stitches and raise the needle.
Hope that helps...
Nov 26, 2008 | Necchi 3537 Mechanical Sewing Machine
Bernette 600 deco
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Oct 07, 2008 | Bernina Bernette Deco 600
Bernette 90E
Our Bernette E90 timing was off due to a jam (design flaw I think)...Instructions on how we fixed it.
1. To correct timing, tip over machine and unscrew inspection plate.
2. Find the gear and unscrew the 2 grub screws so the gear is free from the shaft
3. Turn the main sewing machine handle to manually get the hook (pointed piece) of the housing (see arrow) to be directly behind the needle
4. Hold it the tightly, and turn the handle again, the needle should be able to go up and down while holding the hook in position.
5. When the needle is at it lowest and starting to move back up and the hook is directly behind tip the machine over and tighten the 2 grub screws on the gear underneath.
6. Replace inspection cover and you’re done
Dec 26, 2007 | Bernina Bernette 75
Sewing Machines Logo
22 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
