Question about Goodyear 1982 Mercedes-Benz 380SL Accessory Drive Belt
White smoke from exhaust smells like gas - Goodyear 1982 Mercedes-Benz 380SL Accessory Drive Belt
White smoke from BMW 740i exhaust
white were? the exhaust tip, or other spot, long pipe, name spot?
white, is steam or OIL.
oil smells like burnt oil and takes for ever to dispate
steam is water, and smells , sweet due to 50% glycol inside.
and goes away fast.
but all Gas engines make water at all the time running as a by product of combustion and for sure on cold days, some times full time cold
due to climate effects.
does your neighbors car smoke at same time, (look)
bingo , dew point.
all gas engine smoke cold started, (steam)
so first find out what it is,
take the dip stick out of a hot engine. stalled, drip it on the exhaust
see that smoke ,smell it? that is burning oil
now you know what you have, steam or oil. smoke.
Jan 18, 2014 | 2004 Suzuki Forenza
1992 mitsubishi mighty max Smoking 2.4 5speed
Sounds like you have a blown head gasket and coolant is getting into one of the cylinders.
Feb 13, 2013 | 1993 Mazda 323
NISSAN CEDRIC 2001, ENGIN STOPS WHEN PRESS BRAKE PEDDEL
There are few possibilities that can cause such problem.
I recommend you few help links related to your problem.Click the link below and follow the troubleshooting;-----Idles rough and quits when gas pedal is pressed less? http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html-----------
Brake pedal stuck? http://howtobyme.blogspot.in/2012/03/brake-pedal-stuck.html
Car only starts when gas pedal is pressed? http://technoanswers.blogspot.com/2012/01/car-only-starts-when-gas-pedal-is.html
Car won't start without hitting the gas pedal? http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-without-hitting-gas.html
emits whitish bluish smoke and bad fuel smell from exhaust
http://schematicsdiagram.blogspot.com/2011/12/van-emits-whitish-bluish-smoke-and-bad.html
White smoke and Acrid Smell? http://whoisbyme.blogspot.in/2012/07/white-smoke-and-acrid-smell.html
---------- Car stalls and throws white smoke from exhaust? http://repairhelpcenter.blogspot.com/2012/01/car-stalls-and-throws-white-smoke-from.html
This will help.
Thanks.
Jul 20, 2012 | Cars & Trucks
2001 Dakota compression loss, smells like gas, white smoke from exhaust
Sorry but this has happened to me before, you might have a blown head gasket. that is where oil and or water are getting in to the piston cylinder and causing the white smoke cause the oil and water is being burnt or boiled.take it to a shop unless you have all the right tools and knowledge to do this job. i cost me like $1500 labor and parts.
May 26, 2012 | 2001 Dodge Dakota
Oil and white smoke out through exhaust?
smell the oil if it smells like gas change the needle and seat inn the carb and change the oil the valve in the carb doesn't seat and the gas drains into the oil
May 24, 2012 | Yard Machines Garden
2000 pontiac sunfire starts only when gas pedal is held to floor, idles rough and white smoke comming to exhaust changed IAC valve..no change
If you have excessive white smoke coming from the vehicles exhaust, it sounds like your headgasket is failing. Especially having a rough idle too. Check your coolant level, does your exhaust smoke smell sweet, like Antifreeze? If so, the gasket has blown. Hope this helps...
Mar 12, 2011 | 2000 Pontiac Sunfire
ALOT OF SMOKE FROM THE EXHAUST
Blue smoke is oil and means you have internal engine damage.
White smoke with a sweet smell means you have a blown head gasket (check antifreeze, if it's low that is another sign)
White smoke with no real smell is water in the gas tank. Grab some water remover.
Black smoke is a sign your burning to much gas, you need a tune up.
Feb 24, 2011 | 1995 Mitsubishi Montero
Gas smell in exhaust
you have either a blown head gasket or cracked head. The white smoke is coolant passing through the engine and exhaust. The gas smell is from compression leaking past the gasket or head, pushing fuel vapor into the air.
Dec 01, 2009 | 1993 Toyota Paseo
Smells like gas and when i press on the gas it putters. white smoke coming out of exhaust
White smoke is usually a sign of head gasket problems.Gas smell could be the unburnt fuel from the cylinder head which is the source of the problem.
Jul 14, 2009 | 1986 Ford Bronco
a tune up will not cure smoke, sounds like u may need a head gasket replaced.
Jun 17, 2009 | 1996 Oldsmobile 88
Goodyear 1982 Mercedes-Benz 380SL Accessory Drive Belt Logo
46 people viewed this question
Top Goodyear Air Tools & Compressors Experts
old fart58
Mike
Are you a Goodyear Air Tool and Compressor Expert? Answer questions, earn points and help others
