Question about Cooper Lighting AL6501FL 65 Watt Fluorescent Area Light
Has power, does not light
The light as power, checked with amp meter, grounded properly, and yet it does not light, backed light in and out, and nothing
Amp is not turning on but all wires are connected properly what can be the issue
check the power wire fuse. Also, make sure your ground won't budge if you move it side to side. Make sure there is not paint there on the ground as well. last check power at the amp. use a meter and see if you getting 12 volts from the power wire and remote wire. One of them is not getting power. It's the only logical answer.
Dec 19, 2014 | RCA Car Audio & Video
My back brack lights are not coming on. I checked the fuels, bulbs and switch nothing wrong with them whats next?
check power to switch,power out of switch,power to bulb,earth,and bulb makes good contact with power and earth posable broken power wire or earth wire
Aug 07, 2011 | 1995 Oldsmobile Cutlass Supreme
Sound turns on and off. Green light sound, red light no sound. It is like playing name that tune. A few seconds of music then off then on and repeat. It is not the deck as it has meters showing output. The...
Amp is probably going into protection mode, or does not have enough current from the power wire to continue operating. Check that the speaker wires are not shorting out against each other. Also check your power wire and ground wire. Ensure that the amp is solidly grounded. Are you using the proper gauge of power and ground wire? (4awg recommended.)
Mar 10, 2011 | Coustic Car Audio 481QE Car Audio...
2003 passat 1.8t, GL My left brake light wasn't getting brighter when I braked for a while, replaced the bulb and no luck. I replaced the bulb housing and it still wasnt working properly until I took...
check to make sure that you have the correct bulb in the correct socket in both left and right tail lights. dual filament bulbs have to contacts on the base of the bottom of the bulb. make sure the socket that you are inserting them into also has two contacts. if that doesn't work then you need to get a test light so you can find out if power is going to the bulb housing and all ground. check all fuses also with amp meter
May 27, 2017 | 2003 Volkswagen Passat
Amp is getting power but its not playing
Checking wires doesn"t help unless you are checking them with a multi-meter. Amp needs 4 things to turn on. 1) 12volt power from battery, 2) 12 volt power from radio (remote turn on), 3) ground (solid ground to the chassis or the car free from paint or rust), 4) fuses on side of amp need to be good. If any of these 4 things don't measure up then fix them so they do. If all 4 are verified with the meter and still no lights then you might have a dead amp. If the lights are on but no sound, then there are many other things that needs to be checked.
Feb 27, 2010 | Car Audio & Video
I have a pioneer gm-d8400m the amp isnt working
flashing light could mean a few different things. 1- constant power may not be there. check with a test light or multimeter. should read around 12 volts. it would be a good idea to check all the power and ground leads. make sure u have a good ground. 2- bad sub. im assuming sub since its a monoblock amp. you can meter the subs. make sure the total ohm load is no less than 2 ohms. any lower the amp will go into protect mode. 3- bad amp. power supply may be bad. the newer pioneer amps are full of protection circuits. ive been a professional installer for a shop about 8 years and we sell pioneer. hope it helps.
Dec 25, 2009 | Car Audio & Video
Kicker protection light won't shut off
Hello newwithtech,
There are 4 possible causes for the amp to go into protection mode. Kicker calls it SORT for Short, Overvoltage, Reverse polarity, and Thermal. If the amp has been in and working properly, it's probably not reverse polarity. And if it goes immediately into protection when power is connected, I'd rule out thermal. So it's probably either a short or overvoltage.
1) Start by removing the speaker wires and see if the amp powers up properly. If it does, one or more of the speakers is shorted or grounded.
2) Test each pair of wires with a multimeter set to the lowest resistance (ohms) scale. Measure across each pair and from each individual wire to ground. Across each pair, the meter should read about 3-4 ohms. From each individual wire to ground, it should read infinity. If the meter reads "0" ohms (shorted) in any test, you have located the problem.
3) If the speaker wires test OK, set the meter to read DC volts and measure the voltage at the amp positive terminal. If the voltage is higher than 16V or lower than 9V, you've located the problem.
4) If the voltage is OK, remove the RCA inputs and test for proper power up. If it powers up without going into protection, you have a shorted/grounded input. Replace them one at a time to determine which one(s) is/are defective and replace the cable.
If these tests show all the wiring is good and the voltage is OK, the amp is probably shorted internally (most likely an output MOSFET), and requires service at the component level. You need to take it to your local audio shop or send it to Kicker for repair.
Hope this helps.
Jun 29, 2009 | Kicker KX300.4 Car Audio Amplifier
Power
Have you checked the on-board fuses?
Did you confirm (with a multimeter) that you have voltage on the B+ and remote terminals of the amplifier?
Did you have the black meter lead on the ground terminal of the amp when you checked the voltage?
Jul 18, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Pioneer 760W (Mosfet Power Supply) Amplier
If you are connecting the negative lead of the voltmeter to the chassis of the car, and then checking the voltage at the amp on the ground power input of the amplifier, then your amplifier is not grounded properly. The amp should also be grounded on the chassis of the car, so if you have 4 V DC on it, it can not possibly be grounded to the chassis. The chassis is the same potential at any point on the car.
Could it be that the 4 V DC is at the power terminals +B or positive voltage? That would not be an uncommon thing to have since the amplifier will hold some charge after it is turned off and that would be normal.
Since you have a voltage meter, you could check the current draw of the amplifier if your meter also have a setting for current or amps.
If so, connect the meter in series with the ground of the amplifier. That means to disconnect the ground wire at the amplifier, and use the meter to complete the ground connection by putting one lead of the meter on the ground wire that should be connected to the chassis of the car and the other lead to the ground terminal of the amplifier. It does not matter which lead you connect to the wire or the amplifier, that would only make your measurement i postive current or negative current, but the meter must be set up properly for current. Most of them have a diiferent jack to put the positive lead into for current. most have two different jacks. If yours does also, choose the lead with the larger amp rating. Most have 10A and 300mA, the lareger amp rating is 10A. That is 10 amps max and the 300mA means 300 milli-amps which is .3 amps max.
Do this with the amplifier turned off and the car off. If you measure any current at that point you do have a current draw with the amp off and the amp would need to be serviced by a professional. If you have no current draw there, the amp is not the source of your battery draining. This would find out for certain if the amplifier is really draining the battery.
If you have found this information help a rating of "FixYa" would be appreciated.
If you need more help just ask,
Dave
Jun 27, 2008 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Amp
Sisnce you didn't mention the protection LED, I'll assume it's not on.
You need to measure the voltage across the B+ and ground terminals of the amplifier to confirm that the voltage at the terminals is least 11 volts. Also check the voltage on the remote turn-on terminal. Place the black meter lead on the ground terminal of the amp and set the meter to DC volts.
Nov 07, 2007 | Power Acoustik LT-980/2 Car Audio...
Cooper Lighting AL6501FL 65 Watt Fluorescent Area Light Logo
48 people viewed this question
Top Cooper Lighting Electrical Supplies Experts
john h
Ottoniel
Gene Haynes
Are you a Cooper Lighting Electrical Supply Expert? Answer questions, earn points and help others
