Question about M T D Products MTD Gold 42" 19 HP Lawn Tractor
No spark 19hp kohler - M T D Products MTD Gold 42" 19 HP Lawn Tractor
  • 30 Answers
If the mower has been stored outside the magneto could have rust on it. Remove the top of the engine cover. There is a coil that's bolts to the block the the magnet of the magneto passes by as it rotates. See it there is rust on the magnet. If so. Take a fine grit sandpaper and remove the rust. The rust changes the air gap causing no voltage to the ignition coil. Thus no spark at the plug. I've corrected this problem twice with same symptoms as yours.
Posted on Nov 26, 2014
Are there timing marks on 19hp kohler
No, there is a key in the shaft that ensures that the flywheel is lined up properly. These sometimes shear and the flywheel slips on the shaft, this causes the timing to go affordable as the magnets don't pass the coil at the correct time. Remove the blower cover, undo the centre nut, slip up the flywheel, replace the key in the keyway in the shaft and realign the flywheel. This should solve the problem.
May 02, 2015 | Garden
Have oil spitting out of carb and dip stick fill tube just started doing that on 19 hp kohler courage
if engine is not overfull you have bad rings on piston have to take in to have it done may end up short blocking it witch is cheaper to do replace rings cheaper by far 200.00 per cylinder
Sep 14, 2014 | Garden
Free engine diagrams
http://www.bridenbeckers.com/pages/oemparts?aribrand=ARN#%2fKawasaki_Engine%2fFH580V-ES20_4_Stroke_Engine_FH580V%2fCYLINDER%2f%2fCRANKCASE%2fFH580V-ES20%2f99907-61680011
Jul 22, 2014 | Kawasaki Engines NEW 19HP KAWASAKI ENGINE...
Why does my engine run perfect for 5 minutes then rough?
Sounds like a fuel starvation issue. Does the choke stay open? The motor could be overheating, too. Make sure the heat sink blades are free of junk.
New fuel pump doesn't suck fuel from tank
The pumps work off of a vacuum pulse, make sure the vacuum line has zero leaks.
Jul 17, 2014 | Kawasaki Engines NEW 19HP KAWASAKI ENGINE...
What is causing my kawsaki 580v to smoke
you check the oil with the dipstick resting on the tube, not screwed in
then check your fuel supply as it might have water in it
then remove valve covers and see if you have a valve guide seal that has moved
May 16, 2014 | Kawasaki Engines NEW 19 HP KAWASAKI ENGINE...
Fh580v has weak spark
Weak battery? That is the simplest and best way to eliminate that factor. Even if it runs it can seem charged but will be giving less power to some components. Maybe the charge system is weak. Run it with jumpers or a diff battery and check spark. Same thing? Ok. Check all your grounds, connectors, wiring, and particularily the coil terminals for corrosion and looseness. All good? Test the mhttp://www.google.com/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=1&cad=rja&ved=0CE4QtwIwAA&url=http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DAsRoSeyJ38o&ei=sNB-Uq2uIOzMsQSQoIHoCg&usg=AFQjCNEG8eK98F5T6nGjXuI3OVJYYDfp8Q&sig2=YHYXfQdNQXfu8bHmlEOv3Q&bvm=bv.56146854,d.cWcagneto and ignition coil. Heres a video. Only other thing could be bad plugs or wires. Good luck.
Nov 08, 2013 | Kawasaki Engines NEW 19HP KAWASAKI ENGINE...
Remove clutch from kawasaki fh580v
to remove clultch pulley remove crank bolt unplug pulley first then ie should pull off some times you mights need to need to use a pulley remover
Oct 26, 2013 | Kawasaki Engines NEW 19HP KAWASAKI ENGINE...
19hp kohler blowing gas out valve cover. will start and run but starts blowing large stream of gas.
the fuel pump is driven by vacuum from the engine so it could just be a bad pump
Sep 22, 2012 | Garden
M T D Products MTD Gold 42" 19 HP Lawn Tractor Logo
70 people viewed this question
Top M T D Products Garden Experts
Dennis Key
Dennis Key
john h
Are you a M T D Products Garden Expert? Answer questions, earn points and help others
