Question about Bio Ionic G-Luxe Series Style Winder 1 Inch Rotating Styling Iron
Bio ionic blow dryer wont get hot - Bio Ionic G-Luxe Series Style Winder 1 Inch Rotating Styling Iron
How can I clean the plate of my Oliso pro. It has wonder under on it
get the iron hot. Take a piece of fabric and a dryer sheet. Put the dryer sheet between two layers of fabric. Place this at the edge of your ironing board. With the iron hot, run the sole place over the "fabric/dryer sheet set" several times. This will remove wonder under and many other adhesives from your iron.
May 31, 2016 | Oliso Tg1600 1800 Watts Smart Iron Pro
I want use distilled water in my new Rowenta DG8030 steam station but instructions say to use 1/2 tap water and 1/2 distilled water or 100% spring water. Why can't I use 100% distilled water? Why can't I...
Believe it or not, distilled water is quite corrosive, more so when hot. Distilled water doesn't contain any dissolved ions but the water is ionic in nature, the ions of every water molecule tend to dissolve away other elements. Steam generating plants and steam ships as well as steam heating systems treat the water with chemicals to keep the water from eating away the metals of the system and test the chemical makeup several times a day while operating. [I spent 4 years in the Navy on a steam powered ship.]
The same holds true for smaller steam appliances like espresso machines and steamers. A very thin coating of calcium carbonate [limestone] is a good protector but too much makes for inefficiencies and burned up elements.
Somewhere I read that Chrystal Geyser spring water is approximately the correct ion balance for espresso machines and I have been using it for years in my espresso machine. In any case you still need to occasionally de-scale your steamer per the manufacturers recommendations.
Feb 03, 2015 | Rowenta Irons
SEDU flat iron won't turn on when i plug it in...
flat iron has large metal foil so change the procdure
Jan 24, 2014 | Sedu Pro Ionic Ceramic Tourmaline Flat...
How to stop a flat iron from turning on and off when being used
sounds like a bad connection in the power lead be careful about a possible short hazard ZAP!!! Find a handyman to fix it.
May 16, 2013 | Sedu Pro Ionic Ceramic Tourmaline Flat...
Sedu flat iron
because it is automatic so it turns on and off after heating at a certain temperature it turns off automatically.
Need manual
Call the company or the manufactor or try to look it up on line with just the name of it.
Dec 27, 2012 | Revlon Ionic Steam Hair Setter -...
Hair Dryer cord has electrical shortage
IF you take off about a inch of wire from the plug and re-wire it [somtimes with new plug also] make sure to remember the fuse and this should do the trick.
Jun 27, 2008 | Conair Dry 'N Straight Hair Dryer and...
Bio Ionic G-Luxe Series Style Winder 1 Inch Rotating Styling Iron Logo
26 people viewed this question
Top Bio Ionic Irons Experts
Are you a Bio Ionic Iron Expert? Answer questions, earn points and help others
