Question about Sears Parts Direct Washer Knob - 131977101
Freezer knob missing is on up or down - Sears Parts Direct Washer Knob - 131977101
How do I unstick the temperature control knob in my freezer? It will not budge. My freezer is over freezing and my refrigerator is not cooling properly.
It is possible that water or the moisture in your freezer has frozen the knob so it feels stuck, so the couple of ways you can fix it is, 1 unplug the freezer, let it defrost and when it warm the knob should loosen up. 2 if you dont want to do the first cuz of food and whatnot what i would do is get a wrench that can fit the knob, put a wash cloth over the knob so dont scratch it all up and grab it with the wrench and try to twist it that way. And 3 take that part of the fridge apart, take off the covers or see if you can open up that area and try to take the knob completely off, and if its like every other knob ive ever seen, once you get the plastic knob off there will be a metal pin that has a flat side that lines up with the plastic knob, take pliers or wrench and try to spin that little pin
Oct 01, 2016 | Refrigerators
I have Mod. # RT21LMXKQ. There is only one thermostat control. How do I regulate the temperature in the refridgerator and freezer?
Walter,
Usually the thermostat control knob is in the refrigerator compartment, and the knob in the freezer controls how much cold air is moved past the damper down into the refrigerator area. All of you cooling is generated in the freezer section and the fan forces is downward. Your thermostat usually has a bulb that senses the temperature that turns the compressor on and off. The factory settings are in the middle of the dial on both areas. Hope this helps!
Aug 05, 2015 | Roper Refrigerators
I have a mitsubishi modelrs2545sh sxs . The refrigerator side works but the freezer side doesn;t possibly the control board ?
check several things, the freezer thermistors, the air damper flow control vent and knob, the control board, door seals,
Mar 22, 2015 | Refrigerators
GE UPRIGHT FREEZER NOT FREEZING.
Hello Mary;
My name is Peter. I am a retired field service refrigeration technician.
You are locked in the defrost mode. About every 8-10 hours your freezer will go into a defrost mode for 20-30 minutes. This is where all of the components will shut down except for the light.
You have water on the floor because your condenser fan and compressor is shut down.
You did not provide a model number. Your model number is on the inside wall of your freezer near the top. So, I can only guess.
Lets take your freezer out of the defrost mode. In the lower back on the left hand side is your defrost timer (This may also be in the lower front depending on the model). Following is a picture of what a defrost timer looks like.
The time is mounted on the back of a plate and held on with two screws. The plate has a hole through it to give you access to the round knob on the left. The knob has a slot in it. With a flat head screw driver turn the knob clockwise. You will hear a click. Turn one click at a time until the freezer turns on.
The timer cost about $20.00. You can replace it yourself. Unplug the freezer. Unscrew the timer. Remove the connector on the right.
You need to replace the timer or you will have icing problems.
Send me your model number and I will tell you what the part number is.
Feb 17, 2014 | GE 25.1 cu. ft. / 711 liter Chest Freezer...
Cant find where you ture down the frezzer
Did you mean TURN down the freezer? There should be a knob at the back where you can control the temperature for the freezer.
May 31, 2012 | Refrigerators
Freezer is working well but the refrigerator is not cooling. It doesn't appear there is air coming out of the vent. Is the only vent for the refrigerator the one next to the temperature dial? Are there...
sounds like the coil is iced up maybe any signs of water dripping in refrigerator. if not turn freezer knob down to low and turn freezer knob up to high and try this. and a rating would help. thanks.
Apr 14, 2011 | Amana ABB1927DE Bottom Freezer...
The ge refrig. is 9 years old. Regardless of the refrig. setting, from 5 down to one it is too cold. set on 3, after 24 hours it is 28 degrees in the crisper and 32 degrees in the main refrig. tried...
ok u ok u turning wrong knob..turn other knob the one with the letters. make the freezer colder than u make ref. warmer. that knob controls a flap that controls how much cold air flows from the freezer to ref. ok
Feb 12, 2011 | GE Refrigerators
Fridge and freezer same temp.
First of all, there is only one thing that cools in a fridge and that is the freezer. The fresh food section is cooled by air forced into it from the freezer.
  • You ice maker will not work if the temp inside the freezer is above 5 degrees. It has a thermostat inside it that enables it.
  • The knob that turns the fridge off and on is the thermostat for the freezer.
  • The other knob opens and closes a damper between the freezer and fresh food section.
  • There is a fan that should be running that pulls air from the freezer into the fresh food section.
(The factory does make the discription of the knobs confussing)
Now. turn one of the knobs all the way one way and then the next. If it turns the compressor off, it's the thermostat. If it does not, try the other knob. Once you find the thermostat, set it in the middle of the scale. Now place the other knob the same. Check and see if you can either feel or hear the inside fan running. If so lets go to the back. This is where your compressor is. It is under the fridge and also has a fan that blows on it. You will need to remove the back bottom panel. See if you can tell if the fan is running. Also notice if the fan is blowing into a set if coils. You should also be able to fill the compressor, if it's hot, it's running. If these two are running, and you didn't see a coil at the fan. Take the front kick panel off the fridge and clean the coil that's under the fridge. If it's dirty, give the fridge a couple hours and see if it cools down. If so, this was your problem. If both knobs are set mid scale, both fans are running, the compressor is also running and the coils are clean. You most likely have a bad timer, compressor or thermostat. This is all that's left.
Please rate solution
Sep 16, 2009 | Amana ASD2326HE Side by Side Refrigerator
Does the single temperature control guage affect both,freezer and
check in the freezer section for a knob to control the freezer. Turn this knob back to center and return refrigerator setting to 5. What is happening is the freezer control is just a baffle that divides the air flow into the fresh food and freezer section. If the freezer knob is turn to 1 or cold it is sending all the cold air into the refrigerator, then when you turn down the actual cold control, the system isn't allowed to run long enough to allow the freezer to stay frozen.
Jun 19, 2009 | Kenmore 64802 Top Freezer Refrigerator
Upright freezer not cold enough
IF THE FREEZER IS AUTO DEFROST, DO YOU SEE A FROST BUILDUP ON THE BACK WALL? IF SO, YOU NEED TO DIAGNOSE THE DEFROST FAILURE. THERE ARE THREE ITEMS TO THE DEFROST CIRCUIT. THE TIMER, HEATER, AND BI-METAL. FIND THE TIMER, USUALLY ON THE BACK OF THE FREEZER DOWN IN THE CORNER NEAR THE COMPRESSOR. IT WILL HAVE A CONNECTOR WITH FOUR WIRES ATTACHED TO IT. IT HAS A KNOB THAT CAN BE TURNED TO PUT IT INTO A DEFROST CYCLE. WITH THE FREEZER RUNNING, START TURNING THE KNOB UNTIL THE COMPRESSOR STOPS. THAT WILL BE THE DEFROST CYCLE. THEN WAIT 5 MINUTES AND LISTEN IN THE FREEZER FOR A SIZZLING NOISE AND LOOK FOR A GLOWING FROM THE BACK BOTTOM. IF THE HEATER IS ON, THE TIMER IS THE PROBLEM. IF THE HEATER IS NOT ON, THE HEATER OR BI-METAL IS AT FAULT.
IF THE FREEZER IS NOT AUTO DEFROSTING, CHECK TO SEE IF THE COMPRESSOR IS RUNNING. IF IT IS, ARE THE SHELVES ALL FROSTED? IF NOT, YOU HAVE A SYSTEM FAILURE. IT COULD BE A LEAK, RESTRICTION, OR FAILED COMPRESSOR.
Apr 02, 2008 | Frigidaire 12 cu. ft. / 340 liter Upright...
Sears Parts Direct Washer Knob - 131977101 Logo
13 people viewed this question
Top Sears Parts Direct Washing Machines Experts
Are you a Sears Parts Direct Washing Machine Expert? Answer questions, earn points and help others
