Question about Xante FilmMaker 4 Printer
Driver windows xp with USB port
I cannot install that printer ;in the display error comes"PRET/REPOS"
I want to install hp deskjet 3325 in windows 7 ultimate, I have driver CD which works on win xp, how to install the driver for hp printer on win 7?
Follow these steps to install the compatible driver in Windows 7.
  • Make sure that the USB cable is not connected to the product. If the USB cable is connected to the product, disconnect it.
  • From the Windows taskbar, click the Windows icon ( ), and then click Devices and Printers . The Devices and Printers window opens.
  • Click Add a printer . The Add Printer window opens.
  • Click Add a local printer .
  • Click Use an existing port .
  • Click the Use an existing port drop-down list, select LPT1: (Printer Port) , and then click Next .
  • Under Manufacturer in the Install the printer driver window, click HP .
  • Under Printers , select the appropriate alternate driver for the product (listed in the table in the previous step), and then click Next .
  • In the Printer name text box, type the product name and then click Next . The print driver starts the installation process.
  • NOTE: The name of the alternate driver displays in the window as the default name. If you prefer, you can change the name of your product. This step is optional.
  • When the installation is complete, a message displays on the computer stating that the product was added successfully.
  • In the message window, click Finished .
  • Connect the USB cable to the product, and connect the USB cable to the computer. A Device driver software was not successfully installed window opens.
  • Click Close (X ) to close the window.
Nov 04, 2010 | Computers & Internet
Konika Minolta 2400W can not connect. Clearly Windows XP sees it, and the driver is installed etc. When I plug or unplug the USB cable, Windows plug 'n play notices the difference. And the USB cable works...
Everytime you disconnect and reconnect the USB cable to a different port, unfortunately, Windows creates a new and distinct copy of the printer. You can see this by looking at the Windows Printers folder. The solution is when you change around USB ports, right click on the printer icon that is actually the active one (the other copies will be grayed out) and Set to Default. Then you can delete the other invalid copies. Then in the Minolta status software, go to the Display menu and Select Printer to change which printer is monitored to the correct copy. It's very stupid that Windows Plug n' play does this, but it does. So avoid change around USB ports on your Konika Minolta printer.
Jul 19, 2009 | Minolta magicolor 2400W Laser Printer
Usb not recognized , malfunctioned.
you need to reinstall printer driver .
"USB NOT RECOGNIZED" error come when windows cant to find driver of a new device .
Apr 27, 2009 | Office Equipment & Supplies
I have a Roland Camm-1 CX-24 cutting machine that has a parallel connection. I have recently bought a Dell Inspiron 1720 with a Windows Vista OS. I have a USB to Parallel cable to connect the two. I have...
connect the printer and the comp. and boot up....windows should recognize the new device.
did you add the plotter to "add printers" and its driver and to the correct port?
make sure your plotter is on and loaded and function key pressed.
also some cable manufacturers supply a driver...so download one if need be.
what software are you using? is the software cutter driver set to the correct printer and port?
(by default it never is)!!
Aug 03, 2008 | Computers & Internet
Possible usb malfunction?
hi,
well xp is a better OS than 98 ( i think) ...
few things you should know that xp is pre-installed with lotsa drivers..but on the other hand 98 isn't .. so each time you put in a USB device you need to install the driver for that device( eg your camera, pen drive etc...) . this drivers would be there accompanied with your device.
hope it helps
regards
bzoy
Jan 14, 2008 | Computers & Internet
USB port malfunction?
Oh God i have the same exact problem. I run XP Pro and USB ports all malfunctioned, after tyring EVERYTHING I reloaded windows and it worked.......for about 8 months, now I'm back to I can't use my printer, storage devices ANYTHING that plugs into the USB ports. I'm at my wits end. I'm thinking of throwing the compter out the window
Jan 12, 2008 | Computers & Internet
CanĀ“t install my photosmart C3180 on my Windows XP
Hope this helps. Be sure the USB port at BIOS setting are enable. And also, you have to update the USB device or uninstall the unknown error (it may contain missing USB driver). Restart the computer and place your motherboard CD installer in the CDROM browse the folder where the USB driver is located. You have to resolve first this error before proceeding to next possible steps. Another way of installing printer or any USB devices; Dettached first the USB cable connecting to PC or laptop, Install the driver (CD installer) when prompt to connect the USB cable connect the cables and turn the printer on, browse manually where the file being looked and is located.
Best regards,
Rosener Guyano
Dec 03, 2007 | HP Photosmart C3180 All-In-One InkJet...
Unable to use printer over network with Server 2003 64Bit
Probably the best and easiest solution for your problem would be to buy an EDIMAX USB-Ethernet print server, or something equivalent. I have several of these running on the network at work. They're easy to setup and they work great.
Nov 11, 2007 | Konica Minolta magicolor 2430 DL Laser...
Xante FilmMaker 4 Printer Logo
14 people viewed this question
Top Xante Office Equipment & Supplies Experts
Ottoniel
Dudeman321
CheckitRight
CheckitRight
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
