Question about Vehicle Parts & Accessories
What does a rack and pinion look like
Show diagram of rack and pinion cause i need a most common to see if it match to the on i have.
    Sergeant:
  • 406 Answers
They vary from vehicle to vehicle..and a tuff job to replace..they are located usually behind the motor and transaxle on front wheel drives are about the witdth of your vehicle from nearly tire to tire they have hydraulic ends that connect to the cars wheels via tie rods IT IS THE STEERING SYSTEM BASICLY..best way to check is call your local parts store and see if they have them or can order it..then go to that store and ask them to show you it if they have one..if not ask them to show you on their computer screen. You can match it on there..good luck
Posted on Oct 03, 2014
Power steering hose keeps breaking, even when replaced by high pressure hoses. Replacing rack and pinion does not help either.
A bad seal in the rack and pinion would have caused low pressure from fluid by-passing the seal. This also would have caused noticeably increased effort to steer the vehicle. Excessively high pressure would indicate an issue between the power steering pump and the rack, and since the hoses have been replaced I would focus on the pump. PS, find a real mechanic, not a parts changer.
Apr 06, 2014 | 2001 Chrysler Town & Country
Need picture to view underneath iszuzu rodeo passenger side
He was referring to the steering Rack and Pinion unit. It has rubber bellows shaped boots on each end of the rack to protect against water and dirt from entering the seals
Feb 27, 2018 | 2002 Isuzu Rodeo
How to remove rack and pinion from 99 chrysler lhs
There are few help links showing exact accurate procedure to replace Rack and Pinion. Click the link below and follow the procedure:-----
Pinion Seal Replace on Dodge Dakota? http://howtobyme.blogspot.in/2012/04/pinion-seal-replace-on-dodge-dakota.html
How to Replace a Rear Pinion Seal.
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-rear-pinion-seal.html
How to replace Power steering rack and pinion gear on Chevy Silverado 2500 HD? http://technoanswers.blogspot.in/2012/02/how-to-replace-power-steering-rack-and.html
How to replace Power Rack and Pinion Steering Gear on Acura Car Models? http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-power-rack-and-pinion.html
How to replace power rack and pinion steering gear on Toyota cruiser? http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-power-rack-and-pinion.html
Front Drive Pinion Seal Removal on Ford Explorer? http://repairhelpcenter.blogspot.in/2012/03/front-drive-pinion-seal-removal-on-ford.html
How to Replace Driveshaft, Pinion Flange & Seal?
http://repairhelpcenter.blogspot.in/2012/03/how-to-replace-driveshaft-pinion-flange.html
How to Replace Power Rack & Pinion Steering Gear On 2007 Ford Taurus? http://repairhelpcenter.blogspot.in/2012/03/how-to-replace-power-rack-pinion.html
How to Remove Power Rack & Pinion Steering Gear on Ford Windstar? http://repairhelpcenter.blogspot.in/2012/03/how-to-remove-power-rack-pinion.html
Power Rack & Pinion Steering Gear replacing details for Buick Park Avenue and Pontiac Bonneville
http://repairhelpcenter.blogspot.in/2012/03/power-rack-pinion-steering-gear.html
How to Replace Power Rack & Pinion Steering Gear on Mercedes Benz Truck? http://howtobyme.blogspot.in/2012/03/how-to-replace-power-rack-pinion.html
How to replace Power Rack & Pinion Steering Gear on Toyota 4Runner? http://howtobyme.blogspot.in/2012/03/how-to-replace-power-rack-pinion_27.html
Power Rack & Pinion Steering Gear Replacing on Toyota Land Cruiser & Sequoia? http://schematicsdiagram.blogspot.in/2012/03/power-rack-pinion-steering-gear.html
Power Rack & Pinion Steering Gear Removal on Toyota RAV4? http://repairhelpcenter.blogspot.in/2012/03/power-rack-pinion-steering-gear-removal.html
How to Replace Power Rack & Pinion Steering Gear on Toyota Sienna? http://technoanswers.blogspot.in/2012/03/how-to-replace-power-rack-pinion.html
These details will help.
Thanks.
Nov 23, 2012 | Cars & Trucks
Power steering fluid is leaking - on which side of the car is the rack and pinion when sitting in the drivers seat.
Hi, Aillathu,
The rack and pinion unit fits across from left to right....It is fitted onto the cross member....The pinion is fitted into the housing at almost right angles to the rack....The rack and pinion is a very positive steeling method, giving excellent response and usually good road feel....The unit consists of the rack which is fitted into the housing and joins the left and right wheels....and the pinion at more or less right angles to the rack...A leakage usually indicates worn oil seals which become damaged when a protective boots is broken....(The protective covers fitting onto the end of the rack housing)....The pinion is the part which attaches to the Steering column and the steering wheel....
If you're intending to do this job yourself, remember to pin punch 'match marks' onto the steering wheel and the top of the column before removing the nut. Next disconnect the steering fluid lines and drain the fluid into a container....(Don't forget to use goggles)
Jack the vehicle up and remove the front wheels....Turn the steering so that the tie rod ends can be loosened and removed from the housings (this will require a taper loosening tool)....removing them can also be achieved with a large hammer, but this method is not recommended!....Set the steering at straight ahead....Remove the joint attaching the pinion to the steering column....Once removed loosen the saddles holding the assembly onto the cross member and remove from the vehicle. Replacement of the seals is not as easy as removing the unit from the car, as the job requires special adjustments made to the unit and a very clean working area. Before you do this job please make sure that the leakage is from the rack and pinion and not on one of the hoses....
Regards Johngee10
Feb 06, 2011 | Jaguar XJ6 Cars & Trucks
A little play in rack and pinion
IF RACK GOES OUT YOU HAVE EXCESSIVE PLAY IN THE STEERING DUE TO WORN RACK..OR POOR RETURN OF STEERING WHEEL TO THE CENTER.BEFORE BUYING A NEW RACK PINION.CHECK RACK MOUNTING BOLTS FOR LOOSENESS.CHECK RACK PINION MOUNTING GROMMET.ALSO CHECK FOR LOOSE WORN TIE ROD ENDS.IF WORN THEY WILL CAUSE PLAY IN STEERING WHEEL.
Jun 19, 2010 | 2000 Chevrolet Blazer
How do i remove the rack and pinion on a 1999
Email me at iambanshee74@yahoo.com and I will them to you with diagrams.
May 13, 2010 | 1999 Mercury Sable
Just install new rack and pinion. return hose
is the unit for tha modle year ? is it a universal or oem replacement? the shop you got it at should have the matching lines, how ever if time is agance you try a hose building centre they may be able to provide an adaptor to match your hose
Oct 01, 2009 | 1993 Volvo 240
Rack & pinion replacement
there many web sites that offer tech suppurt, even Chrysler, just start looking, also Napa Auto Parts. Auto Zone. This is to hard to explain on a site like this. GOOD LUCK RDJRP
Jul 11, 2009 | 2005 Dodge Caravan
Powerstearing leaking oil
Have the steering gearbox checked.  If fluid loss was severe.  Wear in steering box causes excessive play in steering controls.  Take on one concern at a time.  They do not seem to be related
Dec 17, 2008 | 1990 Toyota 4Runner
Vehicle Parts & Accessories Logo
48 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
