Question about General Electric GTDP490EDWS GE 7.0 Cu. Ft. DuraDrum Electric Dryer with HE Sensor Dry
Takes several cycles to dry
It is taking several cycles to dry even when 1/2 loads are put in the drum. The vent is cleared with every load and the connection tube is clear. The back of the dryer is heating, but the clothes are still damp. The dryer is 1 1/2 years old and we have been having issues off and on for a year. The dryer vent tubing flows through the roof of the house, so we aren't sure how to check that vent.
    Sergeant:
  • 222 Answers
You may have a clogged air vent, check that the air vent hose is not smashed, if it is not smashed, have your dryer vent cleaned professionally, all the way from where the dryer connects to the wall to where the vent leaves the home,
Recheck the dryer operation, dryer vents should be cleaned every other year for optimum performance
Posted on Oct 24, 2015
4 Suggested Answers
SOURCE: dryer takes very long to dry clothes. usually 2
There is a lint trap at the rear od the dryer and one on the roof or side where ever the dryer vents out. Make sure all those are clean
Posted on Mar 20, 2009
  • 34 Answers
SOURCE: my dvlr223egww takes over 2 hours to dry a load,
The most common problem is your exhaust line is blocked. Turn on the dryer and go outside to feel how much air is coming out the vent. Most likely it is blocked. If so you'll need to disconnect the exhaust duct and vacuum it out.
Posted on Oct 06, 2009
  • 1122 Answers
SOURCE: Dryer is not drying clothes very well
check your wall vent,if it is clogged it will not dry right-mike
Posted on Jan 24, 2010
Testimonial: "Clogged wall vent seems to have been the issue - thanks!"
Takes too long to dry clothes
Feb 16, 2014 | General Electric GTDP490EDWS GE 7.0 Cu....
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
Dryer taking to long to dry
Overloading
1. One of the simplest problems to remedy could simply be that you are putting too many items inside the machine during the drying cycle. Avoid overloading your dryer, as this might cause your dryer to work extra hard to dry your clothing, extending the length of the dry cycle.
Wrong Heat Setting
2. A common issue with clothes dryers could be the wrong heat setting. Most home dryers feature several settings, from low heat settings to high heat and permanent press. Be sure the setting you choose is right for your needs. Another setting to check is the load size of your dryer. If you are drying a large amount of clothes, be sure the setting for large loads on high heat is selected. Choosing the wrong heat setting or load size can cause your clothes and linens to take longer to dry.
Lint Trap
3. One of the simplest fixes for drying issues might just be that your lint trap is clogged. Each time you use your dryer, lint will form in the trap. If the lint trap and vents are full, this could block air going into your dryer and slow down if not completely stop the drying process. After you use your dryer, remove this lint trap and empty it fully. Even if the lint trap is full, your other dryer vents might be clogged as well.
Clogged Vents
4. If your clothes are in the dryer for a long amount of time, but still not drying, the reason for this could be a clogged vent. A sign that your vent is clogged is if your clothes are warm or hot to the touch after sitting in the dryer, but still damp. To unclog your dryer vent, you may need professional assistance. This is especially necessary if your dryer vent leading out of the house is particularly long.
Heat Source
5. If the dryer is not getting enough heat to dry your clothes,something could be wrong with the heating system. After the drying cycle, touch your clothes to see if they are warm. If not, this means that the heating mechanism is malfunctioning. It will need to be repaired or replaced by a professional.
Feb 28, 2011 | GE Profile Harmony DPGT750GC Gas Dryer
Laundry not getting dry
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Jul 18, 2009 | Dryers
THE DRYER TAKES TWO TO THREE HOURS TO DRY ONE LOAD
Vent
Heating element
Internal ductwork
Cycling thermostat
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
May 20, 2009 | Dryers
My Maytag gas dryer is not heating correctly. It gets warm, but takes several cycles to dry even small loads.
one thing u can do remove vent tub,
turn on dryer run for about two min
open door touch inside door if hot
u have a vent problem
May 12, 2009 | Maytag PYG2300A Gas Dryer
Dryer not heating as it should. Gets warm, but takes several cycles to dry clothes
Could be 2 things... either your heat source is out of repair or your vent is blocked. Since you say it only gets warm I'll assume the problem is with the gas coils inside the unit. These parts are replaceable
May 12, 2009 | Maytag Dryers
My Frigidaire electric dryer doesn't heat normally.
some of them dryers have 2 elements and one could be out you have too take drum out too check it
Dec 28, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryer steaming up my house
ck vent againalso be sure dryer is not pushed back too far crimping vent hose..to double ck leave rear vent hose off and dry a load ..may be some lint and moisture in house but if dryes in mormal time will confirm vent problem ..vent may only be partially blocked also look for hole in vent hose or better yet replace entire vent hose
Oct 27, 2008 | Roper RGX4634KQ Gas Dryer
General Electric GTDP490EDWS GE 7.0 Cu. Ft. DuraDrum Electric Dryer with HE Sensor Dry Logo
Top General Electric Dryers Experts
Tim Whalen
Ned Halaweh
Ned Halaweh
Tyler T
Level 1 Expert
Are you a General Electric Dryer Expert? Answer questions, earn points and help others
