Question about LG Dehumidifiers
LG lmu366hv with error code ch67 - LG Dehumidifiers
CH67 error code & blinking "bucket full" light
It is a well know problem , you need to replace the bucket switch
Dec 16, 2014 | LG DH404E Dehumidifier
What does error code CH 24 mean?
The CH67 code is generally related to either a fan motor failure or a blockage to the air inflow. It is recommended to check the filter, and make sure that none of the vents are obstructed. If this does not resolve the matter, then the unit may require service. To make service arrangements, you may either contact our Customer Interactive Center at call_skype_logo.png800-243-0000, or you can check our Repair Provider Lookup on our website, at http://www.lg.com/us/support/repair....
Sep 01, 2014 | LG Electronics LD451EGL 45-Pint...
What does error code ch67 on an LG dl301 mean
Look in the owners manual for codes
May 26, 2014 | LG Dehumidifiers
Lg dehumidifier ch 67 error
Thanks for the post by Posted by Bill L on Jul 14, 2012.
I decided to take a chance and order the new Sensor assembly $20.50 and install it in my LG LD651EBL Dehumidifier which was giving me ch 67 errors. Wala, it worked, the error code is gone and the dehumidifier is now working perfectly! Thanks
Jul 14, 2012 | LG LD651EBL Dehumidifier
Error code 67
Error code 67 is an airflow problem. Either clogged filter or bad blower motor. Unplug unit remove bucket and feel for filter in front behind cover it drops down. Clean filter with water and reinsert. Plug unit in turn to "on", fan should begin to run, after 3-5 minutes compressor should start. If fan does not start it is bad and should be replaced.
Jul 07, 2012 | LG LHD65EBL Dehumidifier
LG dehumidifier LD451EGL with error code CH67
After cleaning the filter, i had to unplug the unit to clear the ch 67 error code before the unit would run again.
Apr 16, 2012 | LG Dehumidifiers
Turn on, runs for about one minute theb code O1 appears and it shuts off
The Error Code 01, indicates that the air intake filter needs to be removed and cleaned.
Hope this helps you and thanks for choosing FixYa.
Sep 23, 2011 | LG Dehumidifiers
Have a year old lg dehumidifier and a code of 01 appears in the window and will not start.
The error Code 01 indicates that either the air intake filter is dirty and needs to be removed and cleaned and/or the water collection bucket is not installed properly. Turn the unit OFF & unplug it, before attempting any service work.
Hope this helped you & thanks for choosing FixYa.
Sep 12, 2011 | LG LHD45EL Dehumidifier
Has ch 01 light on
I'm having the same problem. I spoke with LG today and this error code means the unit is not calculating the correct humidity percentage. I told him that I don't really care what percentage it calcs, I just want it to collect water. He told me there was no way to override this and that it will need service to operate.
Aug 08, 2009 | LG LHD45EL Dehumidifier
Error code on Digital LG Dehumidifier - CH 1
Change the sensor assembly, Part # 6877A30013M from Appliance Factory Parts in Englewood CO, about $30. Easy to change, plugs into control board, remove old temperature probe by pry T-well open with small screwdriver and then crimping back closed when new sensor is installed, about an hour start to finish, hardest part is getting all the covers off. Mine is back to working like new again!!
Nov 10, 2008 | LG DH404E Dehumidifier
Dehumidifiers Logo
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
