Question about Grip Tools 12 Volt 9,500lb Electric Winch 28790
No aasembly papers
How do i assemble my winch
How can I install an 8000 lb 5.5 hp winch and install front to back wiring rated for at least 360 amps?
There must be endless info about this online or youtube or any of the offroad sites.
Make sure you mount a good cut out switch between the battery and winch you can access in a hurry to save your truck. A big fuse is usually available from the winch co rated for that winch. If it all goes wrong you can isolate the winch. Cable is going to be stick welding cable size to get good power. Be careful how you route it. Its a big winch, use a professional mounting kit and good quality fasteners.
Feb 17, 2016 | 2005 Chevrolet Silverado
John Deere 2012 648g3 skidder winch will let out, when you try to winch in it will roll slack out of cable, but winch won't lock up and pull hard. How can I fix it?
if your saying that winch will take in and let out ok but wont hold a load in tension , then your winch directional valve or the winch motor is worn out and is allowing oil to pass right thru it regardless of it not being activated as skidder winches don't have a brake like electric winches do it uses the power of the oil locked into motor to hold a load ( that's also why id never stand under a load suspended by one !!!)
Nov 15, 2015 | John Deere Garden
My winch don't move it all?
if you can use the winch manually by pressing buttons on the winch then the problem will be in either the remote unit(Battery in back to front) or the receiver in the winch
Dec 22, 2014 | Cars & Trucks
Warn winch troubleshooting
It sounds like your solenoid is not reversing the polarity , which will require a new winch solenoid. Before replacing the solenoid, check your switch. It might have one contact no good. Switch the wires around and try to retract winch by paying out.
Aug 03, 2014 | Warn Industries Warn 64851 Atv Winch Mini...
Electric winch
Is there a load switch on winch
Jul 13, 2012 | Electric Superwinch 12 Volt DC Winch -...
Got winch at garage sale in a box in pieces, trying to find assembly schematics so i know if all the parts are there and proper sequence for assembly. any suggestions?
Without a model number no one can answer your post. There are several winches out there. I do not want to sound disrespectful but... we would be guessing without a model number and would be searching for a needle in a haystack. Help us help you. Make and Model number please so we at least have a chance to try and look it up.
Thanks, Kelly
Sep 24, 2011 | Garden
2006 snow bear plow, winch will not lift plow, sounds like its turning but is not lifting plow consistantly, Is something loose?
Yes, Check where strap or chain is mounted to winch. It could be loose or have dirt or oil on it something to make it slip.On mine there's a brass piece that raps around the shaft, It got lose and dirty so I cleaned and tightened it. If you pull motor off winch to check gears [don't use gear] when reassembling it's too thick when it's cold. I used white spray lube. Hope it helps!
Jan 20, 2011 | 82" TruckSUV Snow Plow
Spare tire removal from underneath van cant seem to get the tire from the bracket is there a specail way to remove it
What's happening is that the latch is not releasing - a safety feature so the tire doesn't drop down onto the road should the cable or assembly rust/break etc. While researching I got this info from another forum: Jack up the rear of the van. Wind the spare "up". now put your jack under the spare to support its weight. Then "unwind" it. now look up through the spare to the winch assembly. You'll see a latch at the back - towards the rear of the van. Reach in with a long screwdriver and release it by moving it towards the rear of the van. If you've unwound the winch you should be able to move the plastic holder downwards. Once you've done this you can allow the tire to come down and remove it. Now remove the winch assembly - 5 or 6 bolts. Odds are you'll see apiece of wire hanging or it may have fallen out. You'll also see a spring clip - it clips onto the underside so when you unwind the winch it should pull the aforementioned latch to release the tire. You should be able to get this back in place by fiddling with it, or just attach a wire to the latch to work it manually. Or buy a new winch assembly - approx. $150. Good luck
Dec 22, 2009 | 1994 Plymouth Voyager
518 cat skidder gearmatic winch keeps turning when put in free wheel 1985
pull the secondary clutch apart on the winch and clean with emory cloth or sand paper and u should see a change in this problem
Sep 08, 2009 | Heavy Duty Associated Equipment 6002B...
Grip Tools 12 Volt 9,500lb Electric Winch 28790 Logo
41 people viewed this question
Top Rural King Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Rural King Vehicle Part and Accessory Expert? Answer questions, earn points and help others
