Question about Samson Audio Players & Recorders
Servo 300 ventilator - Samson Audio Players & Recorders
Low heat on passenger side of Volvo xc90
You need ventilation flaps calibration. Also one of the flap servos might be broken.
Oct 09, 2014 | 2006 Volvo XC90
Lexus GS 300 AC on Drivers side, Heat on Passengers side
most likely the AC head unit has gone bad
Dec 03, 2012 | 2001 Lexus Gs 300
1999 Lexus RX 300 clicking sound below glove box on AC system
If you take the glovebox out, you can see the air inlet servomotor on the left side of the blower housing. (SEE DIAGRAM)
This is very likely to be what you are hearing. This is a quite common problem. This servo is electronicall controlled. When the HVAC is turned on, the servo is supposed to go through a "full swing" to test itself. Many times, things (papers, napkins, drinking straws, etc.) from an overflowing glove box get jammed in the recirc-air flap right behind the glove box. when this happens, the servo cannot make a full swing and sometimes it damages the servo, which continues to attempt the full swing and keeps clicking because it is stripping its internal gears trying to make it happen.
You will most likely have to remove whatever it is that is jamming the door and replace the servo.
May 20, 2012 | 1999 Lexus RX 300
Schematic for samson servo 300?
http://www.eserviceinfo.com/index.php?what=search2&searchstring=Samson+servo+300
Jan 11, 2011 | Samson Servo 300 2-Channel Amplifier
No funciona el ventilador
The flaps that control the ventilation are either cable or vacuum servo controlled. Have someone operate the controls, and try to watch if the cables or servos move properly. It is probably a broken or loose cable, or a broken vacuum line or diaphram.
Aug 28, 2010 | 1990 Pontiac Trans Sport
I need the Samson servo 300 circuit diagram. THANKS a lot! Regards Carlos
I dont have The diagram
Carlos sorry :O[
can you find the "Bridge" switch?
Aug 11, 2010 | Samson Servo 300 2-Channel Amplifier
Samson servo 300 right channel low output power protection on.Left channel ok.
Hi...
This amp will need to be serviced
Check on the web for someone who does audio/stereo repair in your area
Jan 22, 2010 | Samson Servo 300 2-Channel Amplifier
02 Trailblazer Rear Blower Doesn't Always Blow.
More then likely the brushes are sticking in the blower motor.
Apr 19, 2017 | 2002 Chevrolet TrailBlazer
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Jerry Umali
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
