Question about Delta Plumbing
Repla ing the washers on a Delta faucet
Delta Faucets Replacing washers
    New Friend:
  • 3 Answers
First turn off water to faucet. There will either be a set screw or a screw under the cap depending on the style. Once handle is removed there is the bonnet, crescent wrench or channel locks will do the trick. With bonnet off you should be able to remove the white cap and steel ball revealing the spring and boot. That's what you replace. Reverse the order to put back together. And there you have it.
Posted on Feb 25, 2014
4 Suggested Answers
  • 68 Answers
SOURCE: faucets turn wrong way
pull the little plasic caps off the tops of the handles and change them around
Posted on Apr 12, 2009
  • 2692 Answers
SOURCE: Delta single handle kitchen sink faucet
Tuen the stops off unsder the sink . Remove the alaen screw from the handle. Using a spanner wrinch or a needle nosed pliers spred apart unscrew the large nut that has two slots. Lift the whole assembly out. Take assembly to the plunmbign supply and match ius the kit that youy need with has two new rubber seals and two springs and maybe a new spanner nut. It also comes with the spanner wrench  and allen wrench  needed to renstall. Tip you may be able just to tighten the spanner nut(clockwise) and stop the leak w/o rebuilding it.
Posted on Apr 25, 2009
Dplumber
  • 119 Answers
SOURCE: I"m removing and replacing a
Since you are replacing the Delta Faucet Delta 470-BL-DST Signature Single Handle Pull-Out Kitchen Faucet With Spray faucet, bend the water supply lines out of the way, and then use a standard basin wrench to remove the nut.
Posted on Jan 25, 2011
Jan 25, 2011 | Delta Faucet Delta 470-BL-DST Signature...
Single handle shower/bath faucet is dripping. Want
I can fix this.
What is the last thing you did before this problem started?
Jan 13, 2011 | Delta Faucet Delta 172-SSWF Waterfall...
Installed new delta leland 978 kitchen faucet. Water pressure from faucet is low. Cleaned screen and there was no change.Could there be a clog some where else in faucet system?
check the angle stop under sink as sometimes the washer gets lodged in the orifice to stop..make sure water is off to house before removing handle to stop...check the hose...then the stem and seat to faucet itself.
Dec 09, 2010 | Delta Faucet Delta 2578SS-278SS Leland...
Facet still leaking after replacing the RP4993G part.
Make sure the area below where you replaced that part is free of scale and is not damaged in any way. Scuffs, scale and dirt will caused your leaking.
Sep 13, 2010 | Delta Faucet Delta 470-BL-DST Signature...
I have 5 of these faucets in my home that was built only 2 years ago. All of these faucets leak from the spout. I have replaced cartridges and they still leak.
Did you replace the seats and springs under the cartridges, Delta part number RP4993. These are the more important parts to replace when your Delta faucet is dripping from the spout.
Sep 03, 2010 | Delta Faucet 2578LHP/H277 Leland 4''...
The sigle lever on my kitchen tap has become almost impossible to lift up and down or sideways please any suggestions,we have removed the round cap from the top and poured descaler down it but no response
you know my grandfather was a carpenter and for some reason he loved Delta faucets. My dad hates delta because they always leaked. We have gone around to all the rentals and even this house he built and replaced all the delta faucets with nice quality moen faucets. You will need to get a washer kit for this faucet. These kits are pretty common since these faucets are so junky. Most hardware stores should have the repair kits. like home depot and Lowes.
Jul 20, 2010 | Delta 2402 Classic Single Handle Kitchen...
My Delta single handle shower faucet drips constantly
call delta and describe the round plate and the screw locatios. they can identify model. you need a new cartridge they costs $25-60. They may send to you for free.
May 08, 2009 | Delta Faucet Company RP26755 Sleeve...
Kitchen faucet won't turn all the way off
You need to replace the washer on the stem. It's a Delta so it's possible that you have the type where the washer is actually in the very bottom of the manifold instead of on the stem.
Apr 04, 2009 | Delta Faucet DELTA/PEERLESS FAUCET CO....
Delta Faucet Kitchen Single Pull
Yes, It can be fixed but it isn't a washer. There is a replacement stem for the faucet . They are readily available at most big box stores and possibly the local hardware store. Bring your faucet model number with you.
Phil
Oct 17, 2008 | Delta 2402 Classic Single Handle Kitchen...
Plumbing Logo
77 people viewed this question
Top Delta Plumbing Experts
bwbconstruct
Level 1 Expert
john h
Craig Butler
Craig Butler
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
