Question about Behringer EuroPower EP4000 2Channel Amplifier
Every time i switch the amp on breaker comes out
    Problem Solver:
  • 12 Answers
If you have operated this amp normally before and it just started tripping the breaker and wont re-set, It will have to be checked by a technician to determine what is causing the overload ie shorted capacitor or some such.
Posted on Dec 22, 2014
Have a duo therm a/c unit that comes on as soon as the 30 amp main plug is plugged in. If its switched to on, it works fine, but if you switch to off, it does not shut off but trips the breaker in my
When you switch it to off is that at the thermostat? How long before the breaker trips? Is it possible that the heater strips are coming on at the same time as the a/c? Have you been doing some work on this unit? 30 amps is a lot of juice and I would think you would smell or hear something. You got me curious. You say it comes on when its plugged in, Is that before its switched on? Maybe the compressor contactor is stuck closed. Hope this helps, good luck.
Oct 13, 2014 | Heating & Cooling
Cannot get ANY of the fans to work.
one half of the breaker you moved is not making contact in the panel or moving the breaker caused the fan relay to be on the same 115 volt leg as the power leg. If the breaker is connected to two points in the panel and you have 115 volts on each side of the breaker (230 volts) You can move the breaker one notch higher or lower or switch wires on the breaker to correct the circuit.
Oct 12, 2014 | Heating & Cooling
Outside main 100 amp breaker is tripping but none of the inside breakers, supposedly when dryer and tv on together but not all the time
Am I to assume your dryer is electrical? If so, I'll guarentee it will draw MORE than 14 Amps if heating. Sorry, can't analyze your problem from here.
May 01, 2014 | Cutler Hammer 100 Amp Main Breaker...
How many 100 watt light bulbs can I hook to a 20 amp breaker (120 volts)
A 20 Amp breaker will support 2400 Watts with a 120 Volt line.
120 Volts times 20 Amps (Amperes) = 2400 Watts.
Answer? 24 100Watt light bulbs.
HOWEVER, you should always allow 1 cushion of 100 Watts.
That would be 23 100Watt light bulbs.
(Wait until you add electric motors to the equation. Things start getting a little more complicated)
(I always use 20 amp breakers for lighting. 15 amp breakers for lighting is phased out.
Secondly a 20 amp breaker requires using 12-2 or 12-3 wiring. (12/2, 12/3)
SO does the receptacles.
Therefore 12 gauge wiring is used throughout the house, until you come to the heavier loads )
[ 12/2 = 2 insulated conductors, and one bare copper ground wire.
12/3 = 3 insulated conductors, and one bare copper ground wire.
Remember, with 12/2 the Black wire is ALWAYS the Hot wire. White is Common (Neutral). Bare copper is Ground wire.
12/3 has 3 conducting wires.
One Black, one Red, and one White for the Common. (Neutral) Bare copper is Ground.
Used for 3-way switches ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 30, 2011 | Hammering
Hi, Have an 88 Olds Cutlass Ciera. High beams come on, but won't stay on more then 10 seconds. Low beamd did work, but now flash on and off. This may or may not be related. Short in tail light , the fuse...
MOST VEHICLES HAVE A CIRCUIT BREAKER BUILT IN THE HEADLIGHT SWITCH. OVER TIME THE CIRCUIT BREAKER WILL GET WEAK & IT WILL TURN THE HEADLIGHTS ON & OFF. YOU PROBABLY NEED A NEW SWITCH & THE FUSE BLOWING IN THE TAIL LIGHT CIRCUIT MAY BE A SEPARATE ISSUE.
Jan 09, 2011 | 1988 Oldsmobile Cutlass Ciera
Triing to install intermatic t103 please help. Source is 3 wire 110v want to run 3 blower 110v 9.5 amps each off the t103 timer. Don't have 220v in house just 110v. I need a very simple wiring diagram I...
T103 has 120Volt clock motor, so we can wire this timer.
T103 timer is rated for 30 amps and 2horsepower and your blowers use 28 amps.
So we're getting close to max on the timer. Hopefully blowers won't all be started at one time since motors draw maximum amperage when they start.
However, you need 30 amp breaker and orange 10 gauge wire for that much amperage >> unless only one blower is turned ON at any given time.
Always match wire size, amperage of breaker and amperage of Load or it will trip the breaker.
If you put 30 amp breaker on size 10 wire it is good. But 30 amp breaker on smaller size 14 or 12 gauge wire is fire hazard.
http://waterheatertimer.org/Color-codewire.html
Add a comment at any time, and I will respond
Look at the basics:
You have 2 cables.
One cable comes from breaker box.
Other cable goes to three 120V plugs (120V is same as 110V).
Each cable has black-wire, white-wire and bare-copper-ground-wire.
How to wire the timer.
Timer has 5 terminals: A 1 2 3 4
A) Cable from breaker box:
White wire from breaker connects to terminal A
Black-wire from breaker connects to terminal 1
B) Cable going to 3 plugs
Black wire to plugs connects to terminal 2
White wire to plugs connects to terminal A
Ground wires connect to green ground screw.
Terminals 3 and 4 are not used in this case.
Here is a wiring diagram that shows 120Volt from breaker box and 120Volt going to Load
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
Nov 27, 2010 | Intermatic T103 Indoor 120-Volt 40-amp...
HAVE A ACR 2000 THAT WONT TURN ON,CHECKED POWER AT BREAKERS AND SWITCH HAVE 120 VOLTS
Please try the following: 1# Turn on the main power switch(ON/OFF) & press 15amp & 3amp circuit breaker at the same time to re-set the breaker.2#With line voltage is present at ''Main'' 15amp circuit breaker,Check connection between circuit breaker & power switch(ON/OFF).3# Verify line viltage is present at the power supply input connectior 44,(Brown=hot,Buue=neutral).4# Check connection between power switch & 15amp circuit breaker.Hope this will help you.
Mar 17, 2010 | Measuring Tools & Sensors
Unit comes on and runs for 5 minutes, the circuit trips off
30 is the correct size breaker for this unit. It sounds like there is a grounding issue going on in the system. Or off of the Thermostat. Something is grounding out causing the switch to trip. Are you running #10 wire to breaker and the unit? If not you will need to increase your wire size
Jan 03, 2010 | Dayton D-F79 Electric Space Heater- the...
Behringer EuroPower EP4000 2Channel Amplifier Logo
168 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
