Question about Frigidaire GLTF1670A Front Load Washer
During spin cycle loud clunking noise - Frigidaire GLTF1670A Front Load Washer
  • Frigidaire Master
  • 5,323 Answers
LOUD NOISES IN washing MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING,
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
The drive coupling connects the motor to the transmission and consists of two plastic drive forks with a rubber coupling between them. One of the drive forks is attached to the drive motor shaft and the other is attached to the transmission input shaft. As the motor shaft rotates, the rubber coupling between the drive forks absorbs the torque to prevent the forks from breaking. Normal use will create wear on the coupling and eventually the drive forks may slip and cause a vibrating noise. If the transmission seizes or if the spin basket cannot turn freely, then the coupling may fail and again you may experience a vibrating noise. Most models will require you to remove the cabinet to access the drive coupler. Disconnect power from the appliance before attempting any repairs.
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Posted on Apr 01, 2015
SOURCE: loud noise during spin cycle
I bought the frigidaire affinity washer. It was quiet until it began the spin cycle, then it sounded like a jet taking off and began to bounce. Come to find out we set it up improperly. You must remove all shipping bolts on the back of the machine and make sure it is level. Ta Da!! it now runs perfectly quiet with little vibration.
Posted on Oct 01, 2008
SOURCE: Clunking noise and vibration during final spin cycle
For all those who say they recently bought the machine, the cause of the machine "walking across the floor" and vibrating violently is the packaging bolts on the back of the machine that were supposed to be removed when the machine was installed (why it says remove packaging bolts in the installation manual). These packaging bolts hold the suspension steady and firm during shipping but MUST be removed before operating the machine. When these packaging bolts (I think there are four total, some up to 6 inches long penetrate the rear of the machine) are removed, they allow the suspesion to absorb the vibration.
Posted on May 25, 2009
  • 5 Answers
SOURCE: My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
Posted on Aug 02, 2009
garing
  • 998 Answers
SOURCE: LOUD CLANGING EXCEESIVE NOISE DURING SPIN CYCLE.
i would think the bearing
Posted on Aug 10, 2009
SOURCE: FWT449GFS2 making loud banging noises during final
lxr6232eqo making loud banging noises during final spin cycle
Posted on Aug 31, 2009
Whirlpool wtw5100sq0 clunks when put on spin cycle
Does the washer currently work fine aside from the loud clunking noise? Does the clunking noise continue or is it just one loud clunk when it starts to spin? If its just one loud clunk then that is not a problem just ignore it as that is the clutch spring releasing, it probably starting making noise from the grease getting washed off when the washer over filled.
However how did the washer overfill? That issue should be addressed too. Sometimes though, if the tub is not centered from a heavy load the water will spill over the back but its not really an overfill.
Mar 25, 2013 | Washing Machines
Loud clunking noise during wash cycle
Hi What machine is this? and is there play on the stainless steel inner drum?
Mar 11, 2013 | Washing Machines
Whirlpool WF665/1 clunking/grinding
Could be worn drum bearings.
Jun 04, 2010 | Washing Machines
Loud noise during spin cycle
what kinda noise, sqeeling, or clunking, mite be sumthing small that made its way behind ajatator an is causeing noise..or one of the springs that hold it broke..sorry i dont no what kind of noise.....
Jan 31, 2010 | Washing Machines
Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Apr 05, 2009 | GE WJSR2070B Top Load Washer
I have a Kenmore series 80 washer that is making a loud clunking
check the motor coupler between the gearcase and motor for wear. If it is cracked or broken it will need to be replaced
Jan 04, 2009 | Kenmore 24032\24036 Top Load Washer
Washer makes clunking noises.......
You didn't give to much detail about the noise, other then clunking. Does it sound like it's metal against metal? Does it sound hollow? When does the noise take place before, during or after the spin cycle.
The easiest thing to do is check to see if the motor is loose, or if you might have too much slop or slake in the belt, if you do then replace and readjust the belt.
Nov 16, 2008 | Whirlpool LTE6234D Top Load Stacked...
Loud cliunking noise in beginning of spin then won't spin
get a flashlight and see if a foreign object has fallen down through one of the tub holes and is jamming the tub you have to look real close
Jan 11, 2008 | GE WJSE3110A Top Load Washer
Frigidaire GLTF1670A Front Load Washer Logo
61 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
