Question about Remington Precision HC-820 Hair Trimmer
Blunt blade cuts unevon - Remington Precision HC-820 Hair Trimmer
My saw stops rotating during cutting
does the motor stop? If not the gears are worn between armature and spindle. If it does stop you could be applying too much pressure trying to cut with a blunt blade or there is an armature fault.
Apr 24, 2014 | Skil 10-in 15-Amp Compound Miter Saw...
Ryobi mitre saw jamming when cutting
There's a normal adjustment process of squaring the blade to the table, page 19 of your manual. If the blade is not square to the table then it will bind. Here's the link for the manual, see page 19.
http://manuals.ryobitools.com/system/files/400/original/TS1342_942_eng.pdf?2011
Dec 21, 2013 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Why wont my overlock cut
probably because the blades are blunt and out of adjustment. They are only mechanical scissors that rub each other and like ordinary scissor they become blunt. Most shops the sell or service overlockers will have replacement blades for your machine.
Sep 14, 2013 | Janome MyLock 634D Mechanical Sewing...
Andis agc 2 not cutting very well
Yep as simple as that just make sure they are a well recignised sharpener otherwise you will waste your money. You can rule out a clipper problem if other blades cut ok. Clipper Blade Sharpening
Mar 03, 2013 | Andis AGC2 Hair Trimmer
My oster A5 clipper works fine with blades 15 and 40 but has stopped working with the 7f and 8(neither blade is blunt) they are acting as if they are blunt maybe not being held in place tight...
Check your Hinge. if you can open your Hinge with your finger and it opens easy, this mean your hinge is worn out. The Hinge should be very hard to open. This is what keep your blade in place while cutting. Also check the Hinge screws are tight. e hope this was helpful. Manny's Sharpening.com
May 15, 2011 | Andis 01690 Hair Trimmer
The blades are moving back and forth but they will not cut. i've took the blades off cleaned and assembled them back but they will still not cut.
this is not a mechanical fault all you need to do is change the blades because they are blunt and so cannot cut the hair.
hope this solved your problem?
Nov 19, 2010 | Forfex FX 652 Hair Trimmer
Trimed material keeps curling up into the
perhaps you are trying to cut off too much material, rather than having the material on the edge, so the blade just neatens it up. Also, the blade may be blunt
Jan 30, 2010 | Sewing Machines
Hi, used a blade sharpener for my a2 horse clipper blades and they are still blunt. Do i sharpen between the teeth
no . The blades are sharpened by grinding away the base of the wear until the edges between the teeth are sharp. It also necessary for the tension between the cutting blades is correct other wise the cutting teeth ride up over the hair and will not cut. Have a person who does sharpening of knives ,scissors and blades sharpen the clippers for you as the machine will get it right.
Nov 18, 2009 | Makita 9820 - 2 Blade Sharpener
Husky lock 509. My machine does not cut . There is something wrong with the blades
Be sure the blades are "raised" properly - did you have them lowered so you could sew without cutting? Maybe they are not locked back in place. Is the machine set for rolled hem? Re-set it for regular overlocking. Even if the blades were blunt, you should still be getting some sort of cutting happening. Blades are reasonably easy to replace yourself but getting hold of replacement blades can be tricky.
Oct 11, 2009 | Husqvarna Sewing Machines
Remington Precision HC-820 Hair Trimmer Logo
19 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
