Question about Life Fitness Health & Beauty
Broken connection to cuff - Life Fitness Health & Beauty
2 Suggested Answers
  • 71 Answers
SOURCE: cuff connection to monitor broken need replacement
You will need to figure out which connecter it is so that you can have it replaced. I have a sheet that shows every one imaginable and after you narrow it down I can help you find it. info@mesasales.com
Posted on Aug 31, 2009
How do I fix a homedics BPA-201 Digital Blood Pressure Monitor. Or who do I send it to be fixed. It keeps displaying E1. But I checked all cuffs connections and they are fine.
Are you moving your arm at all after you press the start button. I just have a wrist cuff, but if I move anything after I've pushed the start button I get an error code.
Apr 02, 2015 | Homedics Health & Beauty
Omron problems
That is most likely caused by the ribbin cable coming loose or going bad at its connection
Jul 18, 2014 | Omron HEM 780 Automatic Blood Pressure...
Monitor starts normally but on it's way down, the number drops down dramatically
check for leaks...i have opened one of this before and it has a broken hose inside...but before going anywhere else, try to check your cuff near the hose then the hose fittings for possible sign of leakage...
you can inflate your cuff then submerge the hose and cuff in water to do the check...
May 17, 2014 | Omron Bp785 10 Series Upper Arm Blood...
Err code 3
From manual at pag.3:
err code 3Appears when pressure value did not increase during cuff inflation: 1) cuff is not fastened 2) air connector is not connected properlMake sure cuff tube is properly connected to monitor, cuff is securely fastened and exhaust rate is between 2 mmHg and 5 mmHg. Make sure air connector is inserted properly into tube and monitor.
refer to manual
Mar 05, 2012 | Lifesource UA 767 Plus Digital Blood...
I keep getting an error code E83 Timeout:Inflation. I need to be checking my sons BP. Is there a trouble shooting i can perform? What do i do?
How old is the cuff? If it has written on it "single use" and you've been using it a while you may have microleaks which means you need a new cuff. Also, check the hose for holes (usually found where the hose splits and connects to the cuff). Last, check the Dinamap to hose connector are the black orings still on the connecting posts?
Critikon/Ge utilizes the oscillitory method for determining NIBP. In other words, it pressurizes the cuff, stabilizes, decreases pressure slightly, stabilizes, etc. so a leak in the cuff or hose won't allow the pressure to stabilize resulting in an E83 error.
Nov 04, 2010 | General Electric Dinamap ProCare Series...
The Sunbeam blood pressure kit doesn't inflate the cuff.
You have the same problem I do. The hose socket to the machine is broken.
Jul 10, 2010 | Sunbeam Digital Blood Pressure Monitor
Vaccuum cleaner with a broken hose
Is it just the corrugations of the hose broken? With most hose fittings there are two small oval shaped lugs on the side of the fitting. Grab a small screwdriver and gently (you may need a little force) push these in to ease the click ring out.
Once out, you'll find a type of screw cuff. Some hoses just unscrew, some are glued in (use boiling hot water to soften to separate).
Cut the broken piece of hose off, make sure the click ring is still on the hose in the right direction, reaffix the screw cuff, and replace the hose (with click ring) back into the hose fitting.
If it's actually the hose fitting broken, check with your local Wertheim retailer or repairer.
May 20, 2010 | Vacuums
Model HEM 780N2 register E after reaching 15 - replaced batteries, what now?
After using the Oregon Scientific pedometer with pulse meter (disaster ..... I couldn't find a PC ready model separate from the software so now I own to ..... Update 2: I just replaced the battery (CR2032) so I guess it lasts about .... Replacement Cuff for HEM-780N, HEN-780N1, HEM-780N2, HEM-780N3, and HEM-790IT ...
omronproducts.blogspot.com/2009_07_01_archive.html
Dec 04, 2009 | Omron Auto Bp Monitor with Easy Wrap Cuff...
Cuff connection to monitor broken need replacement
Aug 25, 2009 | Health & Beauty
Progressive Kenmore hose canister connection broken 116,2341130
A regular person with patience can however it is tricky. Kenmore hoses have an arrow at the cuff where the corrugated hose meets the swivel elbow at the machine, and at the cuff where the handle meets the hose. If your parts fit in the handle, the cuff needs to be squeezed slightly out of round at the arrows to allow the handle to be popped out, usually by using a vice and applying a sharp blow by hand to the underside of the hand grip.
If your problem is in the lower sleeve area where dirt gets into the contacts at the machine end, there is a 1" clip with bayonets on either side. It must be compressed at the bayonets to allow the sleeve to slide off. The internal contact rings should be cleaned and polished with W/D sand paper #600 and then lubed with vaseline. Contact fingers should be spread to apply more pressure on the internal rings before reassembling in opposite order.
When in doubt Panasonic and Kenmore warranty centers will be familiar with these.
Aug 05, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Health & Beauty Logo
32 people viewed this question
Top Life Fitness Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Life Fitness Health and Beauty Expert? Answer questions, earn points and help others
