Question about Hotpoint Dishwashers
Need a water intake valve for my Hotpoint Dishwasher
Model ADW1100N10WW, need to know what part to get and where to get it. Installation instructions?
    New Friend:
  • 42 Answers
I've used two web sites searspartsdirect.com and repair clinic.com
both have diagrams and probably can have them at your house within days! The first one probably has more diagrams. Good luck
Posted on Feb 17, 2014
4 Suggested Answers
  • 220 Answers
SOURCE: Maytag MDB5100AWB Dishwasher not draining
More than likely the filter is clogged,remove the spray arm(there is a threaded cap in the center of the arm twist it to the left,then remove the # 15 or 20 torx(star shaped) screws out of the filter cover(around the edges)The filter is round and runs around the outer edge of the pump housing it lifts right out,clean it and reverse the process.It's the most common issue with not draining on this model.
Posted on Sep 26, 2009
Testimonial: "The solution from TomZS was precisely what I needed to fix my Maytag washer. Thanks a million!"
  • 37 Answers
SOURCE: F13 error code on Miele dishwasher. I can't find
The water valve on Miele dishwashers is built into the end of the water line where it hooks into your plumbing(in that box-looking assembly) Your best bet is to call Miele USA, I have had very good luck with their customer support system, they can usually diagnose your problem right over the phone.
Technical Support
Residential Appliances Hotline
(800) 999-1360
Monday-Friday: 8:00 am - 8:00 pm EST Saturday-Sunday: Closed
http://www.mieleusa.com/usa/contact/contact_miele.asp?page=1
Posted on Apr 20, 2010
  • 7 Answers
SOURCE: How do I replace the door latch on my dishwasher?
Don't try to bend anything! The latch mechanism in the door is probably broken. Open the door and remove the 11 torx screws holding the inner panel on. You will probably find broken plastic bits on the pathetically flimsy latch; mine failed after 4 years and I expect it to happen again.
If you do, see the link given in "I Have 3 problems with my dishwasher, my...",
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5168615&diagram_id=1349844#d1349844 Unlatch the two switches and slide them off the old part and onto the new one, observing all the obvious precautions about not getting shocked and putting the switchess on correctly. Reassemble the door and latch with the screws.
Posted on Nov 10, 2010
My hotpoint LSB 5B019B dishwasher is making random beeping noise during the wash cycle. A lot of stuff I've read on line suggests a reset. Does anybody have any idea how I do this?
I have encountered this problem a few times with this particular range of dishwashers and there are a few possible causes.
1.Low water pressure will cause the diswasher to beep during the wash. Check for kinked pipes or blocked inlet valve.
2.The waste hose being pushed too far down the standpipe or the standpipe itself being to low down causing the water to siophin out of the dishwasher. Check your instruction book for correct installation
3. Using poor quality dishwasher tablets can cause over sudding which has the effect of dropping out the pressure switch making the dishwasher think the water level is low
4. An intermitted faulty element can cause this
5. A faulty display board
The first 3 you can check yourself but the bottom two i strongly recommend getting a hotpoint engineer to carry out the repair.
Aug 20, 2016 | Hotpoint Dishwashers
Dishwasher will not fill with water
depending on the make and model of dishwasher the solution can vary. A good guess (assuming the inlet hose is connected and tap is turned on), is the water pressure setting may not be matching with your normal mains pressure. Check installation instructions for setting mains water pressure. Also some dishwashers like Bosch have special inlet hoses which detect water leakage and shut of the water inlet valve. Need to check if your dishwasher has got this feature and need to confirm the hose is correctly fitted.
More importantly check when you turn wash cycle on if you hear click of the inlet valve or not.
Dec 29, 2012 | Dishwashers
Dishwasher wont take in water but pump is working, had side off and checked in coming supply. could it be the electronic valve on the supply in?
The water-inlet valve lets water enter the machine. First Check to see if the valve is getting water. Make sure it's not clogged. There is a screen on the inside of the valve, this sometimes gets clogged up with debris. Check to see if you get power to valve when unit is put into operation may take a couple minutes to start a fill. If you have power and it's not clogged up replace the valve .If you have no power to the water inlet valve check float switch. This can be done by checking the continuity. Here is a video checking the water inlet valve and the float switch. It may be a different model but the testing procedure will be the same. You can also enter your model # for diagrams and illustrations for most models. All parts come with installation instructions.
Sep 24, 2010 | Hotpoint 24 in. DF55 Free-standing...
Is there a micro switch on a dishwasher to let the water in hotpoint hydrocare super plus model no 7822 my machine dosent seem to fill
Most Dishwasher have a flote switch for the water level. You need to check it as well as the water inlet water valve.
Jul 04, 2010 | Dishwashers
Water does not fill into dishwasher MODEL HDA1006 55BW
The water-inlet valve lets water enter the machine. First Check to see if the valve is getting water. Make sure it’s not clogged. There is a screen on the inside of the valve, this sometimes gets clogged up with debris. Check to see if you get power to valve when unit is put into operation may take a couple minutes to start a fill. If you have power and it’s not clogged up replace the valve .If you have no power to the water inlet valve check float switch. This can be done by checking the continuity. There is a video of this at http://appliancehelponline.com/dishfloatwaterinletvideo.html this will walk you checking the water inlet valve and the float switch. It may be a different model but the testing procedure will be the same. You can also enter your model # for diagrams and illustrations for most models. All parts come with installation instructions.
Jun 23, 2010 | Hotpoint Dishwashers
The dishwasher will not fill with water what can i
The water-inlet valve lets water enter the machine. First Check to see if the valve is getting water. Make sure it’s not clogged. There is a screen on the inside of the valve, this sometimes gets clogged up with debris. Check to see if you get power to valve when unit is put into operation may take a couple minutes to start a fill. If you have power and it’s not clogged up replace the valve .If you have no power to the water inlet valve check float switch. This can be done by checking the continuity. There is a video of this at www.appliancehelponline.com/servicemanual.html this will walk you checking the water inlet valve and the float switch. It may be a different model but the testing procedure will be the same. You can also enter your model # for diagrams and illustrations for most models. All parts come with installation instructions.
Apr 13, 2010 | Maytag 24 in. MDC5100A Free-standing...
Hotwater runs continuously
It sounds like a little piece of trash (precipitated solids in the water line) have gotten in the water valve, or, the fill switch has failed.
If you know how to use a voltmeter, then see if there is voltage always applied to the water solenoid. If not, the water solenoid valve is bad. If it does have voltage all the time (when it's not supposed to be filling) then it's the fill switch.
Feb 01, 2009 | Hotpoint 24 in. HDA3400G Built-in...
Hotpoint Dishwasher. No Water Intake
hi. thanks for the question . the water valve is the problem . the valve is behind the bottom plate .4 screws to remove bottom panel .water valve is on the left. turn water off. disconnect power. replace the valve thanks the appliance doc
Oct 05, 2008 | Dishwashers
Dishwasher tub slowly fills with water after after completion
the internal parts of the valve are sticking open randomley.the diaphram/piston in the valve most likley have lime deposits on it due to poor water quality.you would need the water valve assembly but before you buy this part i would look where the water line goes into the dishwasher and it will lead you to the valve.remove the valve from the unit and disassemble the valve.clean all the internal parts in the valve and reinstall.75% of the time this works ,if not change the valve.
Jan 24, 2008 | Dishwashers
Dishwashers Logo
79 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
