Question about Microwave Ovens
Replace interior light bulb - Microwave Ovens
    Sergeant:
  • 239 Answers
If it's like my old Kenmore, you literally have to remove the metal outer shell to get to it.
There's probably also a seal that states that doing so, and breaking the seal, voids any remaining warranty...
I'm an old Maintenance Man. We've had to change fuses or lights located under the outer shell for the Nursing staff on the floors...
The fuse goes when they foolishly put metal objects, even condiment cups that many don't realize have foil under the paper seals...
Posted on Feb 16, 2014
3 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: replacing interior light bulb
It may be an assembly with the bulb permanently fixed to the socket, requiring the replacement of both together.
Otherwise, in some cases manufacturers use glue or tape to keep the bulb from loosening.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We appreciate your thoughtful rating of our answer.
Posted on Nov 17, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: interior light out. replace bulb
Ifthe owner's manual doesn't cover it and there's no obvious coveron the side or rear, you'll have to remove the outer wrapper.
See these files:
http://wwww.microwavedisplay.com/safety.txt
http://wwww.microwavedisplay.com/disassembly.txt
The light is often located on the right side in the air duct attached to the magnetron or above the cooking cavity.
Mostbulbs can be matched up at hardware stores, home improvement centers,and places like Wal-Mart or even large grocery stores.
Posted on Sep 20, 2009
Ge microwave interior light bulb replacement. model #PVM1970SR1SS
Open the cover n you will see the bulb open it by turning it sideways
Sep 12, 2014 | GE Microwave Ovens
I need to change the interior light bulb in my Frigidaire over the counter microwave. The model # is FMV156DCA.
Good Morning Evelyn, thank you for allowing me to assist you!
Here are some simple troubleshooting tips to help replace the light bulb on your Frigidaire microwave, FMV156DCA.
    ·First, disconnect power to your microwave. This can be done by either unplugging it or at the circuit breaker panel.
    ·To release cover, remove the screw on the light cover (light cover may become very hot, do not touch glass when light is on).
    ·Remove old light bulb and replace only with equivalent watt bulb available from parts distributor or the manufacturer directly. Bulbs are also available at most hardware stores or lighting centers. Bulbs larger than 30 watts are NOT recommended.
    ·Close light cover and secure with screw removed in step 2.
    I hope this information proves to be helpful. If you have further questions, please do not hesitate to reconnect.
Nov 25, 2013 | Frigidaire FMV156DC Microwave Oven
Interior light bulb burned out
make this test and fix it. GOD BLESS YOU
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
Oct 31, 2013 | Samsung SMH8165STE Microwave Oven
Interior light out. replace bulb
See these files:
Sep 17, 2009 | Siemens Microwave Ovens
Can not change interior lightbulb
how do I change the little light bulb on the top to take off the cover what do i need.
Please, lvinci@gmnew.com
Feb 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Replace light in overrange GE microwave
Advantum 120 over range microwave - with burned out interior bulb: Remove top fron grill cover -- held byu 2-3 screws on top. Remove sheetmetal plate that lies parallel to top of unit, just to the right of the square plastic porting on the far left of the unit. The sheet metal plating is about 12" wide and 8" deep and is shaped like 2 overlapping rectangles. It is held in place by 1-2 screws. (I don't recall if you needed to remove other plastic grid on right front -- I did, but I was still searching for the bulb). The bulb is located about 5" from the left side and about 2" in from the front, covered by a small sheetmetal box. THe bulb looks like the little halogen bulbs used in low-voltage outdoor lights - but is slightly larger - DO NOT REPLACE WITH THAT KIND OF BULB). Remove the one screw holding the box, unplug the bulb and find a replacement. Can't tell you where to get a bulb -- that's what I'm doing next. Good luck.
Jul 25, 2008 | Microwave Ovens
GE microwave interior light bulb replacement.
Your post has two distinct model numbers shown, so it's hard to be precise, but I'll try my best.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. Other models are similar. It's at
http://207.234.249.73/mwd/ge_lamp_replacement.jpg
Always unplug a microwave before removing or installing any bulbs!
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there.
There may be a panel on the bottom covering the light(s), too.
If not, chances are you'll have to remove it from the wall, then remove the outer cover.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
If yours is an Advantium type, the following instructable should help: http://www.instructables.com/id/SZFF4WSF44XYT8X/?comments=all
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 03, 2008 | GE JES1289SK Microwave Oven
Interior Light
The interior oven light can be accessed in the following way:
1.Open door and remove the top grill via the 2 screws along the top edge.
2. In the interior light will be under metal plate with fasten by single screw. The halogen bulb is rated at 120V 20watt. Looks like a G-8 bulb with 8mm pin spacing with o.a.l. 1-5/8" long
Get these bulbs cheap at http://www.1000bulbs.com/120-130-Volt-G8-Base-Halogen-Light-Bulbs/
Jan 01, 2008 | GE JVM1790 1000 Watts Convection /...
Ge Spacemaker microwave - Model # JNM1851
They sometimes have a plastic cover over the bulb cavity that you can take off from the oven interior
Dec 23, 2007 | GE XL1800 1100 Watts Microwave Oven
Replacing interior light bulb
Nov 06, 2007 | Whirlpool MH1150XM Convection/Microwave...
Microwave Ovens Logo
43 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
