Question about LG Art Cool LA121CNP wall/window Air Conditioner
My neo plasma LG error CH 67
Compessor start but fan dosent runs
3 Suggested Answers
SOURCE: error ch 5
check all wiring and connections - ch 5 is a communication error between the indoor unit and the outdoor unit......
Posted on Dec 16, 2007
hvac1960
  • 2133 Answers
SOURCE: LG air conditioner 24awn error code message Ch 6
CH-06 REFERS Indoor unit coil sensor fault. Disconnect from PCB measure resistance. 10 kOhm at 10C and 4 kOhm at 30C. if not replace sensor. THANKS.
Posted on Dec 13, 2010
Our LG mini split heat pump is flashing ch 67. What is the problem and how do we fix it please?
The problem is to outdoor fan motor. Check if has capacitor and replace it. 6?F. Or check the cables to pc board. In the end fan motor replace it.
Dec 22, 2017 | LG Heating & Cooling
I have a neo plasma lg 7kw will not heat LG Air conditioner
Make sure the setting on the remote is correct . Sun symbol for heating. Make sure the filters are clean. On heating, the indoor unit will 1/2 open the flap but the fan shouldn't start. The outdoor unit should start and if working properly, will be blowing cold air. The indoor unit will open the flap fully and the indoor fan will start once it gets hot then you should feel warm air. If the outdoor unit is blowing warmish air, I would say the reversing valve coil has failed or one of the indoor temp or pipe sensors are faulty. If a sensor fails, a "CH" error should appear on the display.
Mar 30, 2016 | LG Heating & Cooling
LG neo plasma error code
It means the lid is open OR it has a short circuit.
Jul 08, 2015 | LG Asmc183vm Neo Plasma Filter
Error code 67?
The indoor fan motor had blocked.
Feb 05, 2014 | LG LSN121HSV2 11,200 BTU 20 SEER Ductless...
Lg dehumidifier ch 67 error
Thanks for the post by Posted by Bill L on Jul 14, 2012.
I decided to take a chance and order the new Sensor assembly $20.50 and install it in my LG LD651EBL Dehumidifier which was giving me ch 67 errors. Wala, it worked, the error code is gone and the dehumidifier is now working perfectly! Thanks
Jul 14, 2012 | LG LD651EBL Dehumidifier
Error code 67
Error code 67 is an airflow problem. Either clogged filter or bad blower motor. Unplug unit remove bucket and feel for filter in front behind cover it drops down. Clean filter with water and reinsert. Plug unit in turn to "on", fan should begin to run, after 3-5 minutes compressor should start. If fan does not start it is bad and should be replaced.
Jul 07, 2012 | LG LHD65EBL Dehumidifier
LG dehumidifier LD451EGL with error code CH67
After cleaning the filter, i had to unplug the unit to clear the ch 67 error code before the unit would run again.
Apr 16, 2012 | LG Dehumidifiers
Error ch 5
Dec 09, 2007 | LG LSC183VMA Split System Air Conditioner
Lg invertor air con "neo plasma"
i have the same, only way to get goin is turn off at mains. ive now tried running on fan low .... got this tip from another problem and seems to work.
good luck
Nov 04, 2007 | Computers & Internet
LG Art Cool LA121CNP wall/window Air Conditioner Logo
80 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
