Bobcat 553 altanator won't charge - Computers & Internet
  • 48 Answers
It's sounds like the brushes need redoing. If this is a brand new item then return to the place of purchase for replacement. Before doing any un-necessary replacements try adjusting the alternator making sure the the belt deflection is to within nominal tolerances. If you have done this then it is time to think about replacing the brushes.
Easy to fix after you have acquired the new brushes it is as simple as undoing 2-3 screws removing the old bushes & place the new part & tighten not forgetting to readjust the belt deflection.
Posted on Apr 29, 2014
The adjustable seat guides are rusted on my bobcat 553. How can I remove the seat to fix the adjustment?
remove the whole seat assembly
tip upside down and remove the retainers from the slides and pull the seat of the slides
get new seat slides and reverse the assembly procedure
Jul 19, 2016 | Seat Cars & Trucks
Where do I find the fuses on a bobcat 553
Should be in the engine compartment on the right side lower next to the bottom door hinge. There are two of them in plastic covers, you will see the wiring harness going into the back of them. The relays are above battery.
Dec 30, 2014 | Bobcat Welding Tools
My bobcat 553 wont start unless i jump the starter and then the hydraulics still dont work
have a load test done on the battery to check for a dead cell. IF the battery is dead then there will not be enough current to work the electronic controlled hydraulic valves . I imagine this machine has joy sticks for controls and not linked levers to the valves.
Mar 20, 2014 | Cars & Trucks
2004 sebring won't start at all
sounds like you might have lost the altanator. Check the battary to see if it is very low, if so it was running of the battery and not the altanator. try charging the battery and see if it will run. If it does, checkthe voltage on the battery. it should be above 13 volts when runnig.If not it is the altanator.
Sep 15, 2012 | 2004 Chrysler Sebring
Mini van wont start battary charged new altanator and starter all wires are grounded
Do you mean it won't start, or won't crank.
You should have a neutral safety switch between the key switch and the starter to prevent you from cranking the engine in drive or reverse.
A defective switch would keep the engine from cranking.
A mechanic would check for voltage at the starter on the wire from the key switch and go from there.
Jul 25, 2012 | 1997 Dodge Caravan
Altanator keeps dieing.
A fresh charged battery does not mean it is a good battery.The battery is working the alternator to death,replace it,it has a bad cell,or the amps are to low,and has a short in it.The alternator senses the battery is in bad need off charge,and puts all out until the alternator has nothing left,This is the most likely cause of this problem.Also be sure the battery cable ends are shiny clean when replacing the battery.
Nov 26, 2009 | 1995 Mazda Protege
Bobcat 553 f - traction lock problem...help
sounds to me like a bad connection or a weak solenoid causing the voltage drop. a good alt charges at 14.25-14.50. it takes voltage to open solenoids not close them.
Jul 19, 2009 | Bruder Cat Skid Steer Loader
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
