Question about Behringer DJx700 5-Channel Pro DJ Mixer with Digital Effects & Bpm Counter
Djx 750 - no power - transformer dead?
Behringer DJX 750 dead. No lights... nothing happens when power switch is on. Fuse ok. Primary voltage at transformer ok. No voltage on any of the wires on the secondary side. Primary side infinite Ohm. I assume the transformer is the root cause? What voltage should be on the secondary side for the orange an the yellow wires? What is the function of the brown wire? Thx for help.
  • Uwe Zugschwerdt
    Uwe Zugschwerdt Feb 16, 2014
    Hmm found Cap c21 104 M burnt black. So I guess this is the root cause which killed the transformer get killed as well?
  • 110 Answers
Actually, you may be in luck. A burned cap means that it has done exactly what it's supposed to do. So...you might stick an identical one in there -- it's a 0.1 uF cap, and you can find these at Radio Shack (0.1 uF 50V) or online. They are cheap, so give it a shot.
Posted on Apr 13, 2014
3 Suggested Answers
  • 5603 Answers
SOURCE: i replaced the transformer and
Transformers rarely fail... you wasted money on that... Likely one of the rectifier diodes/module or filter caps has shorted. Continued use will burn out the transformer. It is humming because it is overloaded with failing components.
Posted on Jul 04, 2011
  • 5603 Answers
SOURCE: my effects on the behringer djx 700 dj mixer stop working how
This is a wild educated guess.
I repaired a Behringer guitar amp that had a DSP effects in it (BX1200 I believe).
The effects were on a seperate board and the board had its own 5 volt power supply. The filter capacitor for the 5 volt power on the board was UNDERSIZED and it had degraded causing the 5 volts to drop out of regulation, dipping to 4 volts. This caused the DSP effects to fail.
YOUR device MAY use the same DSP OR design.
Check the 5 volt power with an OSCILLOSCOPE to look for dips below the 5 volt operating point that occur at 120 HZ.
Posted on Oct 24, 2009
Behringer Powerplay Pro-8 HA8000
Most behringer transformers are 18Volts 1-2 amps to my knowledge, specially in the smaller units. If you are not sure start with reconnecting a 12 volt (AC) external supply and see how you go. Behringer uses (indicated) 17Volts transformers but that is neither here nor there. Good Luck.
Aug 13, 2014 | Behringer HA8000 POWERPLAY PRO-8
Connected wrong voltage power supply to my mixer when in Hong Kong.
If you have the polarity correct for the connector, and adequate output from the transformer with adequate regulation and filterning, there should be little problem with constructing one or hacking the cord off the dead supply and wiring it to a new one.
The question you need to ask yourself is whether that wait is worth it? If you need it to make money with it right now- then just use care in wiring the new supply up. I have lost track to how many times I have rewired a supply to make it work on something it was not originally on. As long as the specs on the new supply match those of the old one- no problem..
Sep 24, 2012 | Behringer Xenyx 1202fx Mixer 12 Input 2...
Beringer PMH 660M has very low power output to speakers and when the volume in increased the output pops in the speakers and goes completely dead, everything else works ok and the lights stay on
could possibly be the volume switch, try changing the switch with one that you hardly use to eliminate the problem. any further probs just let me know. hope this helps
Feb 16, 2012 | Behringer Music
I replaced the transformer and fuse which is in a sealed compartment above the power supply connection in djx 700 (behringer) and still have humming in the new transformer
Jul 02, 2011 | Behringer DJx700 5-Channel Pro DJ Mixer...
Hi my behrinher DJX 700 - damaged transformer i think, i bought the unit in canada and i used it with a voltage converter, worked just fine, recently my son pluged it in the uk socket and it bloone the...
Sounds expensive. How did the Canadian plug fit a UK socket? The fuse won't have blown fast enough to avoid all damage. Their coucld be an internal fuse - see instruction book. It won't be a home repair job it its not the internal fuse - sorry.
Feb 14, 2011 | Behringer DJx700 5-Channel Pro DJ Mixer...
Does anybody have a schematic for the Behringer LPA1300 power amp section used in the K3000FX keyboard combo? Are the output devices supposed to be the ground path for the power amp. (there are no...
Look at this one:
http://elektrotanya.com/behringer_k1800fx_sch.pdf/download.html
This is for the 1800 however...
Often they will just double up with two amps, one inverted, and use in bridged mode.at the higher power in what we call an "H" arrangement.
Since the drains are tied together, the heatsinks MIGHT be hot output level.
Feb 05, 2011 | Behringer Ultratone K3000fx 300w Keyboard...
My Behringer XENYX 2442FX Mixer does not power up, the only light that comes on is the phantom power light. I opened it up and noticed that the switching power supply has multiple voltage outputs. We...
You should find +/-15 volts and +5 volts as well as the phantom power... but that light can come on at much lower than desired voltage.
Note that the regulators are current limited so a short on the mixer board can kill one of the voltages.... but you are not getting any input from teh switching portion of the regulator so the switching part of the supply is apparently dead. To replace the supply you would have to call Behringer at 1-425-672-0816 to get the part number and an incident number and then call FullCompass which is their part distributor now.
When working on a switching power supply, use an isolation transformer for safety and use a 60 watt lamp in series with the power cord to limit current during testing.
The circuitry will be SIMILAR to the power supply found on page 9 of schematic you can download at:
http://elektrotanya.com/behringer_ub1204fx_pro.pdf/download.html
Dec 15, 2010 | Behringer XENYX 2442FX Mixer
Behringer XENYX 1622FX, won't power on. Phantom power works(?)
After reviewing the schematic, I don't understand how the Phantom power can REMAIN on with the power switch off... this CANNOT occur except for what energy is left in the 48 volt supply filter cap... This might last for minutes after the fuse went... UNLESS you have devices connected which are backfeeding the 48 volts. (which would be a disaster)
The 48 volts, +/- 12 volts and +/- 15 volts and the +5 volts ALL come from the SAME switching power supply. I suspect one of the filter caps went or the primary switching regulator a TDP245Y chip.
You should ONLY work on the line side of this using an ISOLATION transformer since the line side has lethal voltages.
To do testing, one replaces the fuse and puts a 60 Watt light bulb in series with the hot side of the inout line. The lamp "acts" as a resetable fuse and limits the current for testing. When all is well again, the lamp will remain out with the power flowing through it.
The D1 diode bridge and C7 input rectifier and filter are first things to check. You can do those with an ohmmeter.
I will caution you to ALWAYS power any and all equipment from the SAME power source. Plugging in devices from across the room will set up ground loops and any ground fault will fry equipment.
Apr 04, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
My effects on the behringer djx 700 dj mixer stop working how
Oct 19, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
My Behringer ADA8000 Ultragain Pro-8 stopped working all together
Hi. I have an 2 ADA 8000 and one went down with the same fault after 7 years.
Firstly, there is a slow blow fuse in the back above where the kettle lead goes in. CHECK THIS FIRST!
If, like me, you change it and it blows again, change it a second time and it maeks a "crackling noise internally. There is a problem with the internal transformer.
From a lot of talking and searching, I've found out what you need to do. Either yourself or and electronics expert needs to do this.
First of all, you need to order a NEW transformer. You need the specific one from Behringer.. I am in the UK and obtained it from EMS. Their number is 01702 613 172. While waiting for this to be delivered, you need to check the power regulator and the 100Nf capp and the 10Nf caps as these can go faulty and cause the transformer to "over work", meaning that as soon as you put in the new transformer, it could go again pretty soon.
These caps I'm told are generic and do not need to be obtained from Behringer. THE TRANSFORMER DOES.
I Hope this helps you all out as I could not find this information online, this is from genuine experience, from people "in the know". Please spread this info about to help others like us who are stuck in a tight place.
Apr 07, 2009 | Behringer Ada8000 Ultragain Pro 8 Ch...
Behringer DJx700 5-Channel Pro DJ Mixer with Digital Effects & Bpm Counter Logo
258 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
