Question about GE Refrigerators
Freezer Leaking - GSS25WGSD
A quick search online has led us to believe this is due to a clogged drain hose. Would appreciate help locating it and fixing the issue with this model.
  • Joey Province
    Joey Province Feb 16, 2014
    Think we got it, opened the bottom panel, poured hot water through the slit in the back of the freezer and it flowed out the white pipe in the back. Turning it back on.
  • 18 Answers
SOURCE: Drain Hose Clogged
You need to blow the drain line out with either air or the co2 cartridge kit made for blowing the drain lines out.
Posted on Oct 14, 2007
docjohn174
  • 943 Answers
SOURCE: Frigidaire FRT18IL6D
Hi thanks for your question. to unclog. pull fridge away from the wall. remove back cover , clean all coils. let fridge thaw for at least 24 hrs. get small plastic hose to push up the drain tube from the back. blow up yhr drain tube to clear the tube. thanks the appliance doc. please rte my answer, thanks.
Posted on Oct 12, 2008
  • 219 Answers
SOURCE: I have a Amana 18 refrigerator which is leaking
the drain hole is in your frezzer behind the back panel
Posted on Mar 19, 2009
Sea Breeze
  • 4655 Answers
SOURCE: I have water (condensation?) leaking from under the freezer
I appoligize for not seeing your post sooner here are some links to pages that may be helpful, Let me know if you need more help as Fixya has a problem notifing me of anyones response to a solution , Thanks, Sea Breeze
appliancepartsse@yahoo.com
864-812-1887
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://appliancejunk.com/forums/index.php?topic=22.0
PART NUMBER AND MODEL SEARCH FEATURE
Please feel free to contact me the charge is free, Sea Breeze
Posted on Jul 16, 2009
localwonder
  • 6784 Answers
SOURCE: Maytag refrigerator is leaking water
Your freezer has a drain that leads to the exterior drain pan beneath the unit. Occasionally this drain can become clogged resulting in standing water inside your freezer,due to line freeze over. This can, also, cause a run-off, as stated in your post. In the freezer, standing water will become ice and may result in defrost problems or inadequate coldness.
You will need to Clear the drain by forcing a solution of water and bleach or water and baking soda into the drain line with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog. This will correct the issue.
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
NOTE_It is important for the refrigerator to be level. If it is not level, doors may not open or close properly and may not seal tightly. Also, drainage from the defrost cycle might be impaired as might the ice making cycle. The appliance was engineered based on it being installed in a level position. While there may be some tolerance for out-of-level installation, the appliance will operate at its best when properly leveled.
Place a level on top of the refrigerator near the front. Do not put it on the door because the door may not be aligned with the refrigerator case. Check that the refrigerator is level from side to side. Next turn the level to check that it is level from front to back.
If it is not level, adjust one or more of the adjustable leveling feet until it is level. The feet are bolts that can be turned to raise or lower the refrigerator. If they cannot be adjusted with your fingers, use a crescent wrench or pliers.
If you have an ice-maker, it should also be checked for level after first leveling the refrigerator. An ice-maker that is out of level will spill water into the ice bin or into the freezer. It can be repositioned by loosening the mounting screws, adjusting it for level and then re-tightening the screws.
Posted on Dec 13, 2009
Water leaking on inside - top shelves
The drain for the freezer is clogged. Unplug the frige and let it defrost. Pull the cover from the bottom front and note the drain pan. water should start draining into pan as the freezer defrosts. If Not the drain may be blocked. To access the drain remove icemaker then rear panel of freezer carefully, unplugging fan and ground wire. Look for drain in the middle under the coils. Look on outside back for the drain hose, this will help you locate the drain. Clear the drain of ice using hot water. You will hear it drain down the drain hose to the pan below.
Mar 29, 2010 | Whirlpool Refrigerators
Leaking water from freezer into fridge. Lately I have noticed water collecting in the bottom portion. I have discovered that the water in leaking from the three holes that connect it to the freezer. There...
Could be drain hole or tube from the drain hole to the evaporator tray is clogged with ice. Unplug refrigerator. Locate drain hole, use a hair drier to melt ice around drain hole, pour very hot water into it and let it stand. Soak up water with a paper towel after it has cooled. and repeat until water drains freely. I have used my compressed air can to blow the obstruction into the evaporator tray.
Mar 23, 2010 | Refrigerators
Water leaking into refrigerator section from freezer
The drain trough is clogged under the coils behind the freezer wall and also there should be a "p" trap on the back that is connected to the drain tube running to the bottom. Remove trap by turning and pulling being careful not to break the neck. You should be able to blow any debris out. Good luck. Blow don't ****. lol
Feb 13, 2010 | GE Refrigerators
Frost free freezer forming layer of clear ice on floor of freezer
This sounds like clogged drain / hose in the freezer compartment, here's why:
When the defrost circuit turns on, the compressor turns off. The defrost coil melts frost that collects on the freezer coil and drips in to a small pan located below the coil. The pan is formed so that the water that drips in it can flow to a hose connected under it. When the defrost cycle completes. the compressor runs again, bringing the temperature in the freezer to about 0 again. Any water remaining anywhere in the freezer will turn to ice very quickly.
If the hose should become clogged with ice, or slowed by mold, bacteria, etc. - water flow will be slowed, and / or eventually stopped. Ice will become thicker and thicker on the floor of the freezer as there is no place for the water to go.
A service manual for the appliance would be a good idea, but may not be required. You'll need to unplug the freezer and empty the contents. Defrost manually with a hair dryer or other heat source. If you decide to chip away ice, do so carefully.
The defrost and drain area of most refrigerator / freezers are located behind the rear panel of the freezer compartment. This is where the manual would indicate where the parts are located. Remove any ice maker installed if needed to remove the back panel.
Defrost any ice previously hidden by the panel. Chipping ice here should be a last resort, as sharp edges can damage cooling coils, tubing and the drip pan itself. Use a turkey baster filled with hot water to direct a stream at the area of the pan filled with ice. Hot water will likely have to be directed down the opening on the pan to melt ice in the hose as well.
Once the ice is cleared, mix about a 10% to 20% solution of bleach and water (1/2 ounce bleach to 3 ounces water) and direct down the drain hose. This will kill and inhibit further growth of mold and bacteria in the hose, which should help it drain water quickly.
Re-assemble and plug into power.
I hope you found this Very Helpful. If you need more help, ask again - but include the freezer manufacturer's name and model number. Good luck!
Dec 03, 2009 | Freezers
Water leaking from bottom, lots of suds.
Hi
Thanks for using FixYa. This may happen due one or more than one of these issues with your washer--
Probably there is something(coins, socks, dirt, debris, etc) stuck inside the drain filter of your washer. You'll need to check the drain filter. To access the drain filter. To check the drain pump follow these steps:
Unplug the washer to completely disconnect electrical power.Remove the bottom front service panel as shown in the first image below.
Also check your drain hose for a kink or clog. Check the washer house drain for a clog or restriction. Test the washer to see if it will drain properly.
This issue can also be due to clogged drain pump or drain filter, due to which the hose have developed leak. This will cause suds
Please rate the solution if you find it useful and helpful.
Thanks
Rylee
Sep 22, 2009 | GE Washing Machines
Water running out bottom of freezer
That's exactly what it it. Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Aug 27, 2009 | Kenmore 53642 / 53644 Side by Side...
864-812-1887
Jul 12, 2009 | Admiral 26 cu. ft. Side-By-Side...
Water in refrigerator
Defrost drain under evaporator in freezer. Inside back wall of freezer has to be removed to access drain
Oct 05, 2017 | Roper RT21AKXKQ Top Freezer Refrigerator
Water leaking into bottom of freezer and on rto floor in front. Kenmore elite bootom freezer 596 series
Drain hose clogged. Removed rear panel and blew out hose. draining fine and no water leaking into bottom of freezer or floor. Be sure to thaw out drain and tray before you return to service.
Sep 14, 2008 | Kenmore Refrigerators
Water leaking inside of refrigerator from freezer
The defrost drain is frozen, you need to take the cover off inside the freezer and there will be a drain hole probably coverd with ice, you will need to pop most of the ice out first then I use a turkey baster and a tub of hot water. Squirt the hot water in the hole over and over again untill it drains. Then just wipe everything down. Problem solved.
Mar 18, 2008 | KitchenAid KSRA25ILSS Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
