Question about RTO Alternator/Battery Tester
Alternator fails Regularly
My neighbor knows I work on cars. I was a former 'FixYa' Author in 2012, when I was confined to a chair. His 2002 Monte Carlo SS, with High Performance package, (not the Dale Earnhardt Version) went well over 130,000 miles on the Factory Alternator. Replacement, rebuilt, & Re-manufactured units failed within Months. A "New" Alternator, also failed. Any likely reason..??
How to correct a 2005 chevy monte carlo high beams from staying on
About 17,700 results (0.74 seconds) Search Results
    My high beams won't go off!! - Monte Carlo Forum - Monte Carlo ...
    montecarloforum.com > ... > General Forums > General Monte Carlo Talk
    Jun 8, 2012 - i flipped on the high beams last night and i think that switch in the column broke. ... My high beams won't go off! ... 2003 Chevrolet Monte Carlo. Help!! Need to get headlights working. - Monte Carlo Forum ...
    Jan 1, 2012
    Repair Guide: List of Common Monte Carlo Problems and Solutions ...
    Aug 9, 2011
    Fog lights not working, High beams stay on?
    May 9, 2011
    More results from montecarloforum.com
Jan 30, 2016 | 2005 Chevrolet Chevrolet Impala LS
2002 buick lesabre
my neighbor has one (poor sod) now you are book ends.
try asking a real question, please;
Oct 09, 2013 | 2001 Chevrolet Monte Carlo
How do i take alternaoter iot of peugeot e7
Go through few Alternator related solved Solutions including replacement of alternator.Select and Click the link below:----How to replace alternator? http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-alternator-on-gmc-sonoma.html
How to test alternator on Dodge Stratus?
http://technoanswers.blogspot.in/2012/02/how-to-test-alternator-on-dodge-stratus.html
How to test and replace Alternator on Audi A4 Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-test-and-replace-alternator-on.html
How to Remove Voltage Regulator on Car?
http://vwrepairhelp.blogspot.com/2011/11/how-to-remove-voltage-regulator-on-car.html
HOW TO REPLACE AN ALTERNATOR BELT
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-alternator-belt.html
How to monitor Vehicles charging system? http://repairhelpcenter.blogspot.com/2011/11/how-to-monitor-vehicles-charging-system.html
Car Alternator making noise? http://repairhelpcenter.blogspot.com/2011/11/car-alternator-making-noise.html
After replacing Alternator, the battery indicator light Comes ON dash?
http://howtobyme.blogspot.com/2011/11/after-replacing-alternatorthe-battery.html
How to inspect Vehicles Alternator?
http://repairhelpcenter.blogspot.com/2011/11/how-to-inspect-vehicles-alternator.html
How to Test Vehicles Alternator?
http://repairhelpcenter.blogspot.com/2011/11/how-to-test-vehicles-alternator.html
How to Service Vehicles Alternator?
http://repairhelpcenter.blogspot.com/2011/11/how-to-service-vehicles-alternator.html
How to Replace Alternator? http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-alternator.html
Alternator testing? http://schematicsdiagram.blogspot.com/2011/12/alternator-testing.html--------- Cars electrical system is pulsating? http://technoanswers.blogspot.in/2012/01/cars-electrical-system-is-pulsating.html------ 1998 Ford F150 pickup Battery Drains overnight due to Alternator? Alternator drains car battery? http://technoanswers.blogspot.in/2012/02/1998-ford-f150-pickup-battery-drains.html------- 2002 Ford Focus sits over night and battery goes dead? http://technoanswers.blogspot.in/2012/02/2002-ford-focus-sits-over-night-and.html--------- Charging system problem on Chrysler LHS car? http://technoanswers.blogspot.in/2012/02/charging-system-problem-on-chrysler-lhs.html---------- How to replace alternator 1997 Dodge Stratus? http://technoanswers.blogspot.in/2012/02/how-to-replace-alternator-1997-dodge.html------- How to replace Alternator on Mitsubishi Lancer http://www.howtorepairguide.com/2012/10/how-to-replace-alternator-on-mitsubishi.html
These details will help.
For more help.Keep updated.
Thanks.
Oct 15, 2012 | 1986 Ford Bronco II
My neighbor just bought a Svan Signet high chair for her daughter. Is this a good chair or should I consider another brand?
I don't know much about this chair myself; however I found you a promotional video about that specific chair that should hopefully help you out in your decision making process. Enjoy!
http://www.youtube.com/watch?v=FOJstrSaT4Y
Jul 19, 2012 | Baby Gear
At night battery light comes on then i loose lights then car cuts off
Sounds to me that it's 'new alternator' time for your vehicle.
The battery light is directly connected to the circuitry of the alternator and when it goes on indicates that the alternator is not providing enough voltage to supply the car's ignition system with electricity and the battery is discharging to fill the gap.
Replace the alternator, in this case.
Jan 25, 2011 | 2002 Ford Taurus
My 2002 monte carlo won't start. The lights come on though. A guy jumped my car than it started but he didn't think it was the battery. what could it be?
Take the auto 2 Advance auto or AutoZone or like parts store they will check battery & charging circuit, alternator for free!
Nov 07, 2010 | 2002 Chevrolet Monte Carlo
I don't know whats wrong with my 02' Chevy Monte carlo. HELP!!! I was driving and all the lights on the dasd flashed and shut down. This caused my gas not to even work and making it difficult to turn off...
First look under your hood, see if the belt is still on, if it's not install a new one, if there is a belt, I would have my alternator checked out, any auto parts place will do this test for free, you will have to get it jump started to have it check out.If it still don't start could be fuel pump.
Aug 19, 2010 | 2002 Chevrolet Monte Carlo
Charge warning light is on manual states it could be generator belt. How much would this cost to repair?
it's a cheap job and easy to do, however why don't you check it before getting it fixed? if you don't know how ask a friend or neighbor, there are other reasons that can cause no charging, alternator or the alternator connections including the earth lead that is connected to the alternator to an earth point,
Mar 13, 2010 | 2002 Nissan Sentra
RTO Alternator/Battery Tester Logo
Top RTO Measuring Tools & Sensors Experts
jdthefixer
Steve
Tim Venetis
Are you a RTO Measuring Tool and Sensor Expert? Answer questions, earn points and help others
