Question about GE Profile JP930 Electric Cooktop
Where is the control lock button on a GE model number JBP2
Tip
Ge jgp328 30 in. sealed gas cooktop
Do anyone know now to turn off the control lock. My stove still lights with the lock on. But it still makes the ticking sound.I am told it only does that when the lock is on.
on Mar 13, 2009 | GE Profile JP930 Electric Cooktop
The control panel displays LOC and the time. oven door opens but unable to reset any controls. is there a way to reset the controls??
Look on the panel for a key that says lock or has a key on it and hold it for10 seconds to see if that clears our
Sep 26, 2014 | General Electric CGS990SETSS GE Cafe 30""...
GE Monogram f160 error code?
When an "F" and a number appear in the display and the cooktop beeps you have a function error code.
Touch the CONTROL LOCK pad.
Disconnect power to the cooktop and then reconnect.
If an F-code appears again, call for service.
May 03, 2014 | GE Monogram ZEU30R Electric Cooktop
Light "Burner On" stays on all the time on my electric stove GE model JBS27WH2WW
I have a GE Range Model JBS27W H2WW and the serial# XXXXX that I was cooking on and the back burner starting throwing out sparks and blew a hole in the coil and the drip pan. Now the light Burner on is staying on and I switched the 8 inch burner in the front with this 8 inch burner and still cannot get it to work.
Dec 19, 2013 | Cooktops
How do you unlock a kenmore elite cooktop?
You can do this by:
Check the oven display to see whether the screen says "LOC." When "LOC" is displayed, the oven lock is activated and the door cannot be opened. You need to make sure it is locked so you do not mistakenly lock the door.
  • 2 Press and hold the "Stop" button on the oven control panel until "LOC" disappears from the display. Some oven models have a button marked "Oven Lock," which should be used instead of the "Stop" button.
  • Lock the oven again by pressing and holding the "Stop" or "Oven Lock" button until "LOC" appears in the display
  • Feb 03, 2011 | Kenmore Elite 44173 30 in. Electric...
    Large element stopped working/that hot surface light stays on
    I have the same problem with mine. Do you have any answer yet?
    Jul 20, 2010 | GE 30 in. Profile JP938SCSS Electric...
    How do I lock the oven door, while it's cooking... NOT self clean
    You can't. The locks are designed for use when the range is NOT in operation. Teach your child to stay away from the range. Even the new GE ranges with the swing latch, if you use them while the oven is in use, the oven locks until it cools down. Sorry to be blunt, a safety gate to keep baby out of the kitchen will be a good fix.
    Jul 30, 2009 | Cooktops
    Got a diplomat ceramic hob with no instructions
    If the KEY lock is on (key botton flashes when switched on) ... touch AND HOLD the lock symbol for AT LEAST TWO seconds until it beeps, then hold the on/off button for AT LEAST 2 SECS.
    If the CHILD lock is on ([L] on all displays when switched on), then:
    1)Hold the on switch for TWO secs min (unit swtiches on) ...then
    2) touch AND HOLD the + AND - for AT LEAST 2 secs
    3) touch the - button once again.
    Jan 14, 2009 | Cooktops
    Just bought a house, no manuals
    After a pot spillover, the cleanup process triggered my stove top to "control lock"
    I removed the pot and once the stove top cooled I pressed and held the "control lock" button.
    It began to blink, I released it and then the light went off and the stove top operated normally.
    You might not have to wait for the stove top to cool. I don't know.
    Aug 24, 2008 | GE Profile JP930 Electric Cooktop
    GE Profile JP930 Electric Cooktop Logo
    69 people viewed this question
    Top GE Cooktops Experts
    Dan Webster
    Dan Webster
    Jim London
    Jim London
    Are you a GE Cooktop Expert? Answer questions, earn points and help others
