Question about HP LaserJet CP1515n Printer
Replace pick up introduktion - HP LaserJet CP1515n Printer
Hp officejet pro l7780 all in one printer, Cleaned the pick up roller still not picking up paper
The pick up roller may be worn and in need of replacement. The slight grinding noise is the pickup roller trying to work but slipping
Oct 30, 2012 | HP Office Equipment & Supplies
Ford focus 2002, 2 litres, what is the function of the pick up coil
The pick up coil is located at the base of the distributor and plugs into the ignition module. The pick up coil's purpose is to sense or "pick up" the pulses of the distributor and tell the ignition module when to fire the spark plugs. The most critical part of the replacement of the pick up coil is to make certain you properly mark the orientation of the distributor to the engine block and the rotor to the distributor base. When you successfully make these markings, you will not need to check your timing when this job is finished. Keeping this in mind, here we go: You will need to purchase a replacement pickup coil and a rubber o-ring gasket that will replace the o-ring located where the distributor shaft enters the engine before you start this project.
Dec 05, 2010 | 2002 Ford SVT Focus
How hard is it to install pickup coil in the distributor of a 2001 dodge ram 1500 pickup.
The pick-up coil/stator is easily replaced in a dodge distributor, and once you have removed the distributor cap and the ignition rotor, then just dis-connect the wire connector from the pick-up coil/stator and lift it straight up and out of the distributor, and the distributor does not have to be removed or dis-assembled to replace the pick-up coil/stator. There are two alignment tabs on the pick-up coil/stator that will match up with the distributor cap when the pick-up coil/stator is properly installed. Here are two images to help assist you.
Jun 29, 2010 | Dodge Ram Pickup 1500 Cars & Trucks
How do you replace the feed roller on a fujitsu 4097 scanner
Hi Ranji,
Thank you for contacting Fixya.
The life span of the Pick roller is about 200,000 sheets or one year. Use Abrasion counter on the operator panel to estimate when the Pick rollers need replacement. The life span may be decreased by as much as half when carbonless sheets are frequently read. To replace Pick Rollers, please follow the steps provided below:
a. Remove Guide AASY. b. To remove the Pick rollers, turn the stopper counterclockwise. c. To remove the Pick roller 1, move the Pick roller 1 toward the left then lift it. d. Right after removing the Pick roller 1, remove the Pick roller 2 with the same way. e. To attach the new Pick rollers, place the Pick roller 1 from right above the groove for the Pick roller 1. Put the shaft of the Pick roller 1 into the groove. Then, slide the Pick roller 1 toward the right side. A Pick roller 1 has the groove in its rubber. Make sure that the bushing is securely fixed to the grooves. f. Attach the Pick roller 2, then slide the Pick roller 2 to the right. Make sure that the bushing is securely fixed to the grooves. g. Turn the stopper clockwise to secure the Pick rollers.
Hope the above information is helpful.
regards,
TechSatya
May 20, 2010 | Fujitsu M4099D/FI-4990C Scanners
Nedd to test coil on an 89 chevy 2500, dont know parameters
PICK-UP COIL (HEI)
1. Isolate 2 pick-up coil lead wires. Remove pick-up coil connector from module. Connect ohmmeter to either terminal and ground. See Fig. 4 . Connect pump and apply vacuum to test vacuum advance unit. Replace vacuum advance unit if inoperative. Connect ohmmeter to pickup coil terminals. Operate vacuum pump and observe ohmmeter throughout the vacuum range.
2. Attach ohmmeter to one pick-up coil terminal and distributor housing. Set ohmmeter to middle scale. Operate vacuum advance throughout vacuum range. Reading should be infinite at all times. If not, replace pick-up coil. See Meter "A" in Fig. 4 .
3. Connect ohmmeter leads to pick-up coil connector terminals. Operate vacuum pump to ensure proper operation throughout vacuum range. Flex terminal wires by hand to check for possible intermittent defects in wiring or connectors. Pick-up resistance should be 500-1500 ohms. If resistance is incorrect, replace pick-up coil. See Meter "B" in Fig. 4 .
NOTE: Activation of the vacuum advance may align trigger wheel tooth and pick-up coil pole piece causing ohmmeter pointer to deflect. This
deflection should not be diagnosed as a faulty pick-up coil.
Jan 20, 2010 | 1990 Chevrolet K2500
C88+ tries to pick up paper but won't. No jams,
Probelm with pick up rubber. Replace paper feeder or just replace the rubber. Or add thickness of rubber by adding flexible double tape (about 1 mm). Add just for upper rubber.
Jul 25, 2009 | Epson Stylus C88 InkJet Photo Printer
Speedo not working
Try to clean the metal off of the pick up. It may work. If it has metal shavings on it and occasionally works or still doesn't work replace the pick up.it's shot. The speedo still could be bad. but the pick ups go out rather easily. and even if the speedo is bad more than likely the pick up will have to be changed as well. So i would replace the pick up ( if it's got alot of metal shavings on it.
Jun 25, 2009 | 2000 Harley Davidson FLSTC Heritage...
My speedometer keeps failing as in stops working. Ive replaced it 8 times and the last time I changed it was 16 days ago. Its broken again and I was wondering has anyone else been replacing their...
Had a similar problem. Turned out to be the voltage regulator was failing and applying to much voltage to the speedo which cuts out above a certain level. Check it and your stator connection; also had a problem with that connector that may have contributed. Replaced the regulator with a new one and have never had the problem since.
Hope this helps.
241.10 paper jam
Um I don't know what the other guy is saying since your paper jam has nothing to do with where he is telling to look...
From the service manual:
Error 241 subcode 10:
Page was not properly picked from tray 1.
Possible Causes:
Failure to feed possible causes include:
• Edge locking
• Worn or contaminated pick tires
• Overfilling of tray past the fill line.
Action:
Fan media.
Turn media over.
Reduce amount of media loaded in tray 1.
Replace pick tires.*
To replace pick tires:
Integrated tray autocompensator pick roll assembly removal
1. Remove the integrated tray, and look underneath the printer for the autocompensator arm. Pull the arm
down.
2. Press on the end of the tab (A) and pull the pick roll off the arm. Repeat this step for the pick roll on the other side. Next, gently release the autocompensator arm. Discard the used pick rolls.
Installation
1. Remove the new pick rolls from their packaging.
2. Pull the autocompensator arm down. Locate the recessed area on the pick roll, and align it with the tab on the arm. There are two arrows on each pick roll. Make sure the bottom arrow faces you as you align the recessed area with the tab.
3. Push the pick roll onto the arm with the tab aligned. Repeat this step on the other side to install the other pick roll.
4. Gently release the autocompensator arm. Insert, integrated tray.
Thanks and please take a moment to rate this solution as fixya.
Feb 04, 2009 | Lexmark T640 Laser Printer
Repair Kit for HP 4MV Printer - Pick Up Rollers
The ruber tyres on the pick rollers can harden with age, even if you are not using it. Try applying gum turpentine to rubber tyre with Q tip. This is used to keep a printer picking up untill replacemant rollers can be fitted.
Dec 15, 2008 | HP LaserJet 1020 Printer
HP LaserJet CP1515n Printer Logo
14 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
