Question about Whirlpool AD50USL Dehumidifier
Unit is not collecting water and carpet is wet
Unit runs all the time we have a water leak that we can't find. Carpet is wet so I know there is moisture to remover. Unit is 10 yrs old and is not collecting water anymore. Has worked great for years any help on fixing this unit.
  • Whirlpool Master
  • 3,368 Answers
Unplug it and let it dry out. Place it on old newspaper and start. Check the paper and look for the wet spot. That will let you know where the water is coming out of the unit. Check that area, it is probably a bad seal on the drain or a crack in the water container.
Posted on May 01, 2014
ttech
  • 139 Answers
SOURCE: Unit cycles off but back on quickly. Does not remove moisture.
It needs the Cover removed and take to the Local Car wash and clear the Front and Back out get all the Junk off of it Use Engine Cleaner first let soak then High Rinse Bring Home let sit outside for A Couple of Hours reassemble and She should Run like New ttech
Posted on Jul 21, 2007
heatman101
  • 43501 Answers
SOURCE: Unit runs but is not operating properly.
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on May 05, 2010
  • 50 Answers
SOURCE: Dehumidifer Runs but doesn't collect water
Depends on he conditions of the water. These units are relatively inexpensive and typically do not justify the expense of repair. I'ld donate it to an air conditioning school and buy another one.
Posted on Jul 19, 2010
  • 4736 Answers
SOURCE: Product is about 6 years old. Used in basement.
There is some service that you can do ... Clean the filter and the cooling coils, regularly. Check the humidity level that you have the unit set on. It may be set to low and there's just not that much humidity in the air at this time, for it to collect. From what you said, it sounds like you may have it set on continuous cycle which could account for the lack of a lot of water in the bucket. In continuous run, the fan stays ON all the time. It's supposed to do that, so that the air is constantly moving and the sensor only turns the compressor ON, if it senses a humidity level 5% higher than what you have it set for. Try running the unit on a 1 or 2 hour cycle (if your model will do that) rather than continuous cycle.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
Posted on May 18, 2011
heatman101
  • 43501 Answers
SOURCE: the unit still makes a running noise but seems to
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
Posted on Sep 07, 2011
Hi! My home dry 660 collects water but also has started leaking onto carpet? Is this a big fix? It is probably about 10years old!
not that big of a job ! it just needs a good cleaning out, start by unhooking power and then remove outer case , look inside at area that has lots of fins !! fine aluminum ones !! there should be a water tray just below the fins ! im betting this is well garb'd up with yuk!! take a 50/50 water bleach solution (gloves would be a good idea too) and work some f this around in the tray till it loosens up , remove with old towels or rags (throw em away) and find the drain hole in the tray that allows the water to drain into collection pan and poke down it with the end of a old pencil to clean it out as well (don't use metal) don't forget to clean your fan blades off too before reinstalling cover and leveling unit before reconnection power
Nov 17, 2016 | Dehumidifiers
I have a whirlpool dehumidifier it is on but will not absorb and water from my carpet
Interesting problem. By the time you read this your carpet is full of mold. You need to put a blower under the carpet to move air through it. The dehumidifier will then adsorbe water from the air if it is operating.
May 06, 2014 | Whirlpool AD50USS Dehumidifier
Water is leaking from the bottom of my maytag dehumidifier. Noticed the problem over the past 2-3 weeks. I have a carpeted basement and the carpet under and around the unit is soaked. water is...
Robert, The water tubing that runs form the interior of the unit to the water bucket is clogged to solve this problem, turn the unit OFF & unplug it. Then do the following.
Remove the water collection bucket and look up inside the bucket holder cavity. You will see either a drain hole or small tubing that drains the water into the bucket. Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reinstall the bucket, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor it for any leakage.
NOTE: Is you don't have access to a Zip Tie, you can use something similar that flexible, like a long pipe cleaner. But, NO wire coat hangers.
I hope this helps you and thanks for choosing FixYa.
Aug 22, 2011 | Maytag M3DH30B2A Dehumidifier
HI, I bought a AD50USV gold dehumidifier at Canadian Tire 2 years ago. Last weekend when I went down to my basement there was water around the machine on my carpet! It was leaking but I cannot find the...
What has happened is the the tubing that fills the bucket is clogged. To solve this, first turn the unit OFF & Unplug it. Then, remove the water collection bucket and look up inside the bucket holder cavity. You will see either a drain hole or small tubing that drains the water into the bucket. Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reinstall the bucket, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor it for any leakage.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers
Jul 13, 2011 | Whirlpool AD50USS Dehumidifier
UNIT IS LEAKING WATER BUT WATER BUCKET IS EMPTY
If the hose is attached the previous answer seems valid and correct. However, I have had a AD75UST0 WHIRLPOOL Dehumidifier for several years. I noticed the port where the water collects to drain into the "tub" sometimes gets a slimy fungal growth on it. This is something that should be routinely cleaned . Just pull out the tub and look at top of Tub compartment. then wipe the portal with a cleaning cloth (use Lysol or similar if desired). This method helped mine significantly from "leaking". In the long run I placed a rectangular storage tub lid under it to protect carpet.
Jul 07, 2011 | Whirlpool 75-Pint Dehumidifier
Dehumidifier is running but very little moisture is accumulating in the tank our carpet is soaked so it should be removing more moisture than it is.
In the is a wall to wall carpet, it's going to take a while. If you have a wet/dry shop vac, you can speed up the process by using the shop vac in wet mode. This will remove a great deal of water and then the dehumidifier will take care of the rest. Remember, it it's wall to wall carpet, the pad underneath is soaked too. So the dehumidifier alone, will really be struggling with it for at least 24 hours.
If it's and area rug, vacuum it to. Then drape it up off the floor over a couple of saw horses or wooden chairs, so the the dehumidifier will fit under one end like a tent. That will dry it out with in 4 or 5 hours.
Last solution, borrow another dehumidifier from a friend and run both at the same time.
Hope this helps you solve your soggy problem.
Mar 12, 2011 | Goldstar DH504EL Dehumidifier
My Haier dehumidifier Model #39R171E is operating intermittently. The bucket is not full - power is on - temp in room says 59- do I increase the humidity to get it to work? Have a large amount of water in...
If your carpet is wet ... like mine was ... the best thing to do is bite the bullet and get the carpet out of your basement or where ever it is ... so your dehumidifier has a chance.
You reduce the % on the machine to reduce the humidity in your room. You should probably also get some fans going.
I have removed my carpet and padding and everything that I can reasonably remove from the room. I have 4 fans going and 2 dehumidifiers and two sump pumps. I also keep the windows open in the day time because it is more dry outside than in the basement. I have heat in the basement which I run at night. My goal is to save my house from damage due to moisture. It will be a good month for the electric company, that is for sure.
I'm sorry you are in this perdiciment ... I'm sorry for me too. My carpet was less than a year old and we have not had any water in the basement for 30 years.
Mar 03, 2010 | Haier HDN655E Dehumidifier
Maytag Dehumidifer still works, but is leaking
Well life span is 3-15 years depends how long and hard you run them. 45 pint is about 1000sqft basment. rule of thumbs bigger better. run less and do a better job. I would start by filling the bucket and place in a dry shower see if you have a crack. cant find a source for the bucket discontinued this might be your problem. http://www.repairclinic.com/SSPartDetail.aspx?s=t-M7DH45B2A-%3d%3di1025984&PartID=1025984 Repair cost are about 40-50 and hour!!!! good luck
Nov 01, 2009 | Maytag M7DH45B2A Dehumidifier
My dehumidifier does not collect any water.
One of two things is happening here.
1. Either the compressor isn't running or...
2. The water is not being routed to the collection bucket properly. This dehumidifier has an option to connect to a hose that can be routed to a drain. Look in the back of the unit to see if you see a connection that could accomidate a garden hose. If you see this and there is no hose connected you may be dumping the water on the floor instead of the bucket. This could explain why your carpets are damp.
Jun 18, 2009 | Kenmore 54501 Dehumidifier
Not working
Hate to tell you, but it may be a goner. Many units have a rectangular air filter that may be clogged, but I would still expect to see some moisture removal. Without exact model I'll have to be general,.... remove cover (front or back, depends on model) to see cooling coils. If the compressor is running, these coils should be wet or may have a light frost on them for a time. Not = refrigerant leak. (not economical to repair) If you see one small area of ice,... it's also a goner. If the compressor does not run you could have a bad compressor, a bad defrost control, or a bad control / humidistat. Other than the filter or possibly a fan motor, these unit are rarely economical to repair.
Aug 27, 2008 | Dehumidifiers
Whirlpool AD50USL Dehumidifier Logo
127 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike
Terry Schneider
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
