Question about Kitchen Ranges
Rayburn cooker not working fault showing as A4 what does this mean
Rayaburn 680kc cooker not working and the fault showing on panel indicates A4 just wondering what this means??
jsrock516
  • 5911 Answers
SOURCE: whirlpool awo3561 fault showing as f06? what does
"F06" is a Motor Speed error code. It means the motor is not spinning, or you have a loss of commuincations between the Motor Control Unit (MCU), Central Control Unit (CCU) or Drive Motor. The following link explains:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
The easiest place to start would be to verify all your connections between the Drive Motor and MCU are intact and not corroded. Then, perform resistance checks on the Drive Motor windings.
For ease of troubleshooting, UNPLUG the washer and remove the top panel by removing the three screws that hold it in place in the rear of the washer. With the screws removed, the panel will slide back, then off. Position the washer where you have full access to the rear. Remove the back panel of washer. With the top and back removed you will have full access to the CCU, MCU and Drive Motor.
If you have questions along the way, or if you require addtional assistance, please let me know. I hope you find this information helpful.
Posted on Mar 05, 2009
  • 1114 Answers
SOURCE: 2005 Audi A4 Emission Control System Indicator
A vehicle's Emission Control Light is a generalized indicator that there is fault or possible malfunction in the vehicle's operating system. In some cases, these warning lights will come on if a gas cap is not fully closed. It could any one of a number of sensors such as the o2 sensor or map sensor. The thing to do is have a reputable mechanic/technician run a diagnostics test on the vehicle.
Posted on Aug 20, 2009
  • 2902 Answers
SOURCE: dismantle rayburn royal
Hi try the aga rayburn wed site for manual .
Posted on Jan 25, 2010
  • 232 Answers
SOURCE: MP210 canon printer showing E6 error
it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release it.
Posted on Mar 05, 2010
  • 149 Answers
SOURCE: rayburn cookers
http://www.rayburn-web.co.uk/DirectoryList.asp?SD=Rayburn obsolete cookers/Rayburn Royal MF/
paste all that to go to the rayburn manuals download site i have seen this manual and it shows what you need
Posted on Mar 23, 2010
Rayburn troubleshooting
www.rayburn-web.co.uk/raytech/default.htm
Aug 26, 2014 | Heating & Cooling
Rayburn 460k keeps cutting out, after 10 minutes it will light again
Rayburn don't make cars. Try in a different section.
Apr 07, 2013 | Cars & Trucks
Radiators go cold after cooking programme ends
Sounds like this is wired in to the oven think you could be missing a link (elec link ) on the rayburn , try the aga rayburn web site they do have atech line
Jan 08, 2013 | Heating & Cooling
Unusual diagram on the indicator panel of audi a4 2001
the only thing i can think of that sounds like the thing you say is a the towing ball indicator fault. means its not locked, so would check this.
Jul 25, 2017 | 2004 Audi A4 3.0
Strong smell of burning oil from chimney of rayburn
the replacement burners seems to not to be set up right. the chap should have had a analiser to make sure the settings are right.you need to call in a pro with the right kit and someone who knows how to use it. your cooker can kill when running like this do not use it
Feb 26, 2010 | Kitchen Ranges
Rayburn cookers
Feb 12, 2010 | Kitchen Ranges
Dismantle rayburn royal
Jan 25, 2010 | Kitchen Ranges
My audi a4 fuel gauge shows fulltank but my
Have the sending unit tested its in the tank.
Sep 14, 2009 | 2004 Audi A4
Rayburn stove
Why is it to heavy to move?
They weigh 500kg. A car weighs 2000kg
Take the doors off and the lids if you like to reduce the weight to around 400kg.
I have moved one completely on my own. ! ( I am a big bloke).
What you need is the following :~
Six 3" round fence posts cut to the depth of the rayburn for rolers
Two car scissors jacks or a trolley jack
Several chunks of wood cut from floor joists. 1 foot long , 3 feet long and 3x7"
Transit van or big MPV or a big estate car or trailer at a pinch.
Good gloves
Toe tectors
Put the rollers at 90degrees to the cooker, get a mate to help you then gradually hotch it over on to the rollers. Push the beast towards the door, putting rollers in front of it as you go, when they pop out the back. Go slowly, no rush. If there is a doorstep, the 3" rollers should clear it with some shoving and pushing. Next when outside push towards the van, positioned as close as you can to the rayburn and door. When its at the van jack up one end about 10" slot under enough wood to keep it propped up. Make sure its even under the two corners of the cooker. Let the cooker down on to the wood and remove the jack. Go to the other end and do the same so the cooker is evenly lifted. Raise it 3" at a time slotting floor joist (3" ) under until its level with the floor of the van. A good shove by two or three lads and it will be in the back of the van. At the other end reversal of process is needed.
That’s how the built the pyramids and if you are careful and well prepared its very safe and very stable. I have honestly done it on my own with the wife wringing her hands and looking worried.
BOB
Feb 12, 2008 | Kitchen Ranges
Kitchen Ranges Logo
126 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
