Question about GE Profile Spacemaker 1.8 Cu. Ft. Over-the-Range Microwave
The inside lightbulb went out how do we replace it?
Inside lightbulb went out
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 78 Answers
Open the microwave. If there is a removable panel on the top, remove it and replace the lightbulb.
Posted on Feb 18, 2014
2 Suggested Answers
  • 693 Answers
SOURCE: how to replace lightbulb inside microwave
Unplug the microwave from its electrical outlet. Never service an electrical appliance while it's plugged in.
  • 2 Remove the screws that hold the outer shell onto the microwave chassis. Often the screws are on the bottom or back of the microwave. Use a Phillips screwdriver or Torx driver to remove the screws.
  • 3 Lift the outer shell off the microwave chassis and locate the box that houses the halogen lightbulb. In most cases, the box is metal. It may or may not have a lid on it. If it has a lid, loosen the tabs and pull off the lid.
  • 4 Unscrew the halogen bulb and replace it with a bulb rated at the exact same wattage.
  • 5 Place the cover back onto the box if necessary and place the shell over the microwave chassis.
  • 6 Secure the shell to the chassis with the original screws and the screwdriver or torx driver.
  • Posted on Oct 27, 2011
    How do i change the lightbulb
    Sometimes you change them from the inside, but more often, there is a small door on the outside which is fixed by a single screw. It is on the outside of the case which corresponds to the place inside where the light is at the back or on the side.
    Jan 08, 2016 | Microwave Ovens
    How do I replace the lightbulb in the microwave and what light bulb do I need to purchase?
    to replace the bulb in microwave ovens you will have to take the outside case off the unit as the bulb placement is not accessible from inside the oven
    when you get to the bulb take it to an appliance repair shop and they will have a bulb
    Sep 09, 2015 | In Microwave Ovens
    How do I replace the lightbulb in a Frigidaire Microwave Model FFCE2278LS?
    Good Evening Gary, thank you for your post!
    From the information you have provided you need to replace the lightbulb inside of your Frigidaire microwave. I have researched your microwave and you are unable to disassemble your microwave in order to replace the lightbulb. In order to provide you with a proper resolution I would suggest seeking assistance from a professional technician for repairs. This will help you avoid unnecessary part purchases or personal injury. -Matt
    Jun 13, 2015 | Frigidaire Microwave Ovens
    Replace a lightbulb
    The lamp is housed inside the outside enclosure which has to be removed to gain access for replacement. You should be aware that removal of the enclosure may expose you to hazardous voltages inside.
    Feb 13, 2015 | Microwave Ovens
    How can I replace lightbulb in my kenmore microwave?
    If there is alight you can open the oven cover and move around sideways the cover will open
    Sep 13, 2014 | Kenmore 69109 Microwave Oven
    look at the top. there may be an access thingy you can remove to get to the lightbulb. replace the lightbulb with suitable replacement. problem solved.
    Feb 16, 2014 | GE Microwave Ovens
    How to replace lightbulb inside microwave
  • Oct 27, 2011 | GE JVM1860 Microwave Oven
    Lightbulb on ceiling of oven went out. How do I
    Hello :
    1:Unplug the microwave oven from the outlet. Wait 20 minutes for the capacitor that is inside the microwave to discharge.
    2:Unscrew all the screws around the casing by turning them counterclockwise.
    3:Remove the cover by lifting off.
    4:Locate the light bulb in the microwave. This will be located on either the right or left side.
    5:Unscrew the light bulb by unscrewing counterclockwise. Some light bulbs are held into the socket by two notches; for these you will need to gently push on the bulb and turn counterclockwise to unsecure the bulb, then pull out of the socket.
    6: Place your new bulb in the empty socket and secure by turning clockwise until tight, or if the bulb is one with notches on both sides, then guide the notches into the slot on the socket, push gently and turn clockwise until clicked into position.
    7: Replace the cover and screw back on. You are now done and may plug back in the microwave.
    Warning : Unplug the microwave before starting and wait 20 minutes for any residual electricity to be bled off from the capacitor.
    Things you will need : Phillips screwdriver
    good luck .
    please rate !
    Mar 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
    Lightbulb burned out for microwave model # KHMS 1850SSS-0 Kitchen Aid Where can I purchase a replacement? Thank you, Carrie
    Most home improvement stores and even some Walmarts/Chain grocery stores/Ace Hardware carry replacements. You will need to remove the cover from the microwave oven on most models unless your bulb is inside a protective cover inside the actual oven. Take the bulb with you when you go to make certain of a proper match. Be certain to unplug the oven if you need to remove the cover in any case.
    Oct 13, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
    GE Profile Spacemaker 1.8 Cu. Ft. Over-the-Range Microwave Logo
    153 people viewed this question
    Top GE Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    vince
    Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
