Question about Miscellaneous
Loud hum coming from my dj mixer - Miscellaneous
    Genius:
  • 1,795 Answers
What tune is it humming????
Posted on Mar 16, 2015
I am not getting sound thur my mixer what could be the problem.
Is there any hum sound? Are the switches set to the proper inputs-phono, line?
Feb 14, 2015 | Numark Im1 2-channel Pro Dj Mixer With...
Loud buzz/hum started on jbl eon 1500 powered speaker one side only after power cut off and sudden power back on makes same noise on it`s own as well as with mixer etc could this be a transformer...
For some reason the soft on protection circuit has failed. it is not a simple fix and would require the amplifier module to be removed from the speaker to assess the damage.
Mar 10, 2012 | Jbl Eon 515 Eon515 15 Powered Portable...
Both Technics SL1210 mkII's loud hum and almost no sound...
You seem to have some feedback hum from somewhere. I would think it might be caused by a faulty connection somewhere.
Mar 12, 2017 | Technics Audio Players & Recorders
I get a signal on a channel but there is no output, just a loud hum.
It's a connector's problem, at this type of noise the ground wire is disconnected. Check the cables, reverse left - right to clarify the problem and, if needed, replace the faulty one. Take care to make these checks at low volume level because this kind of hum can burn out the speakers very easily.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Dec 05, 2010 | Vestax Pmc05pro-Sl 2-Channel DJ Mixer...
What do i do with the earth cable on my technics to stop the humming?
If you are connecting it directly to a HiFi amplifier, connect the ground lead of the technics to the ground termination on the back of the amplifier.
If you are connecting to a Dj Mixer, connect the Technics ground lead to the ground on the back of the Dj Mixer.
Make sure the ground is connected securely and will not fall off. To check this, after connection give a light pull on the ground cable. If the lead comes away, reterminate (connect).
Nov 09, 2009 | Technics SL-1210 Turntable
No signal going into mixer.
Did you buy the gear new? If not, the issue might be with the meter. Also, sometimes the signal isn't loud enough to engage the meter, so try cranking up the Trim and Volume (Master & Line), of course, make sure the volume on your amp is down, so you don't blow anything.
Good luck.
- OPTiC
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Feb 04, 2009 | Technics SL-1210 Turntable
Dj mixer problem
The fuse will do nothing in regards to protecting from such a voltage surge. The fuse is only good for minor power issues. Not stepping down the voltage is not a minor issue, and more than likely the transformer blew.
At this stage, you'll need to have it repaired by an service technician. This way they can test for any other damage to the unit.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Mar 24, 2008 | Pioneer DJM-600 Silver Professional DJ...
Miscellaneous Logo
64 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
