Question about Kenmore 44102 Front Load Washer
Kenmore Front Load Washer Problem
My washer is a Kenmore front load model # 41729042990 and it is not spinning.  Clothes are soaked.  Does this sound like a big problem,,,,,,,HELP
  • 5 more comments
  • Anonymous Nov 05, 2007
    Washer fills and goes through what seems like a wash cycle, on every setting, but it doesn't spin and there is a lot of water in the bottom of the washer, and clothes are soaked. Kenmore 41743042200. Have taken off the front lower panel and looked at the pump. I can't tell if it is working properly, but I did feel in the tubes to check for blockages. None noted.
  • Anonymous Nov 09, 2007
    same no spinning, water is the basket.
  • sonny g Nov 17, 2007
    my kenmore will not spin. all cycles work but the spin mode. replaced pump and control panel.
  • goodtiming Aug 13, 2008
    Anytime I manually out it on spin cycle it makes a buzzing noise but does not do the fast spin. It will do the slow washing "tumbling" but not the fast spin. I checked the tube in the back and was able to drain the remaining water out. My dog sitter put an extra heavy blanket in there so I think the weight of must have blown something with the spin cycle. What could have blown (belt? gasket?) and is it something easily fixed?
  • cathy1833 Oct 23, 2008
    won't spin....washes, and rinses but no spin just a loud humming from the motor
  • snowstorm1 Mar 09, 2009
    but the repair man replaced the door switch(wax switch) it worked fine for 1 or 2 loads now its back to slow spin and clothes are still soaked.
  • Anonymous Mar 13, 2014
    manual for kenmore 3.5 front loaD WASHER 44152
Pump may be plugged.Take off back Locate pump remove hoses. Check pump spins freely, remove debis. Mine had a hole in the basket gasket sealt hat let debis get in the pump. Good luck
Posted on Nov 02, 2007
My kenmore frontload 44142 went off balance we stopped it emptyed the clothes and now it will not spin.
Posted on Jan 02, 2010
My machine is not a similar model 44142 and the problem I had was the water was not draining out. we took off that big hose that leads to the pump in the front, and there was coins and hair pins. This fixed the problem and save us a couple hundred $$.
Posted on Oct 13, 2008
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
KENMORE FRONT LOAD WASHER MODEL # 417.44052400 WILL NOT SPIN. CLOTHES REMAIN SOAKING WET.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 03, 2011 | Washing Machines
My kenmore top load washer works well, however when the spin cycle runs...the water drains but the clothes are still soaked. It sounds like it is spinning (but Im not sure if it actually is) and there is...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 01, 2010 | Kenmore 24032\24036 Top Load Washer
Washer will not turn on...
My washer makes a wierd clinky sound during wash and rinse cycle and it has began to stop spinning the water will drain but clothes will be soaked. Also sometimes during spin cycle it will agitate instead of spinning
Jun 22, 2009 | Kenmore Elite 45986 Front Load Washer
My Maytag Front load stack unit washer/dryer model # MLE2000AYW
I had a similar problem, My washer spun but the clothes were still soaked with water. We replaced the inertia switch. That solved it.
Dec 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 70 series
First thing is to remove the 2 screws from the console, they may be hidden in the front or bacl of console. After removing screws, lightly push the base of the console towards the front of the washer and pick up. This will expose your lid switch connection. Using a jumper wire, jump out the black and white wires then try advancing your washer into spin/drain. The culprit will usually be the lid switch assy.
Apr 04, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Front Loading Washer Slow Final Spin Cycle
out balance are water still in tub will do that try cleaning out the pump filter under the panel at the bottom of the washer some have a big white looking screw you turnit remove filter if there water in it it will flow to the floor so have something to catch it with
Jan 26, 2008 | Kenmore 44102 Front Load Washer
Kenmore front Loader 41729042990
remove motor, check carbon brushs,replace if short,the manual may help.motors that have brushs are the principle,sole motor is Italian,yours is German,anyway thats beside the point ,its the brushs.buy ,eire
Dec 11, 2007 | Kenmore 44102 Front Load Washer
Kenmore 44102 Front Load Washer Logo
1,499 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
