Question about Baking
Cookie press top won't screw on - Baking
I want to know how to enable Third Party Cookies on Windows 10 please.
For enabling third party cookies follow this steps:
1. Open Internet Explorer by clicking the Start button ,
2.Click the Tools button, and then click Internet Options.
3.Click the Privacy tab, and then, under Settings,
4.Click Advanced ,Then you'll get Advanced privacy Settings window. There you can see the Third-Party cookies options.
5.For enabling Third-Party cookies, Click the Accept option. That's it.
Oct 22, 2015 | Google Chrome
I am tracking my family and the system asks that I enable third party cookies. I am on Windows 10 and I cannot find out how to enable third party cookies.
As Windows 10 have the latest and newest browser named EDGE so in order to enable or disable cookies follow these steps:
1. Open Edge.
2. Press the three-dot More Actions button on the top right.
3. Select Settings from the menu that shows up.
4. Tap or click View Advanced Settings. You'll need to scroll down to the bottom of the page.
5. Press the dropdown arrow under the Cookies field.
6. Select Block All Cookies or Block Only Third Party Cookies if you want to disable cookies, or Don't Block Cookies if you want to enable them.
Thanks
What does a cookie press do?
A cookie press is basically a barrel
with a handle. You put the cookie dough in the barrel and select a cookie shape
to put at the end. By pressing down really hard on the handle, the cookie press
squeezes out a shaped cookie which you can drop straight onto a baking tray.
Feb 28, 2013 | Baking
Face book won't let me into my account..says my cookies aren't enabled
Hi Cynthia,
Depending on which web browser you are using firefox, Internet Explorer. I use Firefox in, in there you will have to:
press the orange firefox button in the top left of the screen:
Options:
Privacy:
Use custom history in the drop down box
then check accept cookies from sites
also check the box which says accept third party cookies.
Hope this helps.
Dec 29, 2012 | Facebook Social Network
Manual for wearever super shooter cookie press
Instructions hand copied from my old manual
1. Stand motor on flat surface; screw barrel securely into place.
2. Attach flat side of piston onto screw and turn far enough to see 1-2 threads
3. Insert assembled piston/screw in barrel so that notches in piston line up with the ribs in barrel; snap screw into place.
4. Fill barrel with desired mixture, using small amounts at a time and tamping into place with barrel loader; wipe any excess mixture from exterior of barrel
5. Select desired cookie disc or tip; place on filled barrel
6. Attach cap to barrel; tighten securely in place. Note: machine may be operated with barrel partially filled
Note: If cookies do not cut off properly even though dough consistency is correct, make sure the 3 feet of the barrel cap touch the cookie sheet each time in order to form the cookie. As the gun is lifted, the flow of dough is cut, forming the cookie on the sheet.
Nov 23, 2012 | WearEver Wear-Ever Super Shooter Electric...
It won't let me on i'm on auto sign in and usually i'm straight on now it goes half way and stops why?
Flirtomatic usually works by using cookies. So When you set the browser to clean and close, it also deletes cookies. You can set it to allow cookies from flirtomatic. 1. Go to Settings. 2. Click Safari 3. Click Accept Cookies - Always
If this helpful, please give a testimonial and vote by pressing button thumbs up.
Sincerely, Thiyaga
Aug 23, 2011 | Flirtomatic
I can't see how to remove the worktop of my Bosch dishwasher. I found two screws that look as if they stop it sliding forward but I still can't move it after removing them. It looks for all the...
Hi john_mchugo,
The dishwasher Worktop can be removed by first removing the 2 screws at the back of the machine. The screws are either fastened horizontally, or vertically. Once these screws are removed, the worktop slides backwards, and can be lifted up and off.
On some models there are catch tappets located on the rear right and left hand sides of the Top panel. To remove the Top panel, press up the catch tappets, push the worktop back and lift it off. If these tappets aren't pressed up, the Top won't release at all.
I hope this has helped you.
Kind Regards
* If this solution helped you, please accept it
Aug 18, 2011 | Dishwashers
I have a super shooter hamilton beach cookie press. the long plastic screw will not stay in place, the small plastic gear falls out.
Hi Jane,
The bolt isn't supposed to stay in one place. It's meant to turn, so the dough can be pushed to the end of the plastic tube. When you're putting the parts together, wind the bolt to one end of the long (7 inch) screw. Next, put the 1.5 inch circular disk on the same end of the column as the bolt. Then, stick the screw in the little hole; the bolt will just lay inside the hole. The screw will go almost all the way inside the handle. Then, attach the plastic tube, making sure to line up the indentations in the tube and on the circular disk. Then, add the cookie dough. When you press the handle (turning on the Super Shooter), the screw should turn, causing the round disk to move up and push the dough toward the tip/disk. I hope this helps. Happy Baking!
Chris
Dec 05, 2010 | Hamilton Beach Microwave Ovens
The problem is I don't have any instructions. This pastrty press is way old.
maybe this will help :)
cookie presses come in a wide variety of choices; some are even electric, but there is nothing like a good old-fashioned cookie press for the sheer fun of use and the quality of the end product. The Mirro Cookie Press contains a central cylinder with a screw-on end that holds the cookie extrusion plates and tips for shaping cookies and pastries. On the other end of the cylinder is a cap with a large screw running through the center. On the outside of the cap is a handle for turning the press inside the cylinder. The screw is attached to a plate, which pushes the dough through the cookie press shaping plate or tip onto the cookie sheet, and it's ready to bake. jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); });
Difficulty: Moderately Easy Instructions Things You'll Need:
  • Recipe and ingredients for cookie dough
  • Soft dishcloth
  • Mirro Cookie press with at least one plate
  • Non-stick cookie sheet
  • Spatula
  • Cooling rack
  1. Step 1 Wash the cookie press and the plates in hot soapy water. Handle the press carefully to avoid damaging the threaded ends of the cylinder or the screw-on caps. Dry all parts thoroughly with a soft dishcloth.
  2. Step 2 Screw the pressure plate all the way inside the top cap and screw it onto the cylinder.
  3. Step 3 Prepare the cookie dough. See links below for recipes or look for any recipe labeled "pressed cookies" (sometimes called "spritz" cookies.) Follow the recipe directions exactly as the right consistency is extremely important when making pressed cookies. The dough should be soft but not crumbly.
  4. Step 4 Fill the cylinder with the dough. At this point, if you realize the dough is too stiff, you might try adding an egg yolk. If the dough is too moist, add more flour a tablespoon at a time.
  5. Step 5 Place the extrusion plate or pastry tip inside the bottom lid and screw it onto the cylinder. Turn the handle until the dough is ready to come out of the extrusion plate or pastry tip.
  6. Step 6 Place the bottom of the cookie press on the baking sheet and turn the handle until enough dough has come out to see the shape of the cookie. Carefully lift the cookie press straight up so as not to smear the dough.
  7. Step 7 Bake according to the instructions for the recipe. Let cookies set on cookie sheet for 3 to 5 minutes before removing with a spatula. Place the cookies on a cooling rack.
Mar 27, 2010 | Kitchen Appliances - Others
How do I resign into my facebook account on my computer, my son signed in to my computer and now his account shows on my computer
Press on the Account link on the top of the page and the press Log Out. Then you will be able to login using your username and password.
Mar 07, 2010 | Computers & Internet
Baking Logo
103 people viewed this question
Top Baking Experts
Don A
Don A
Pamela Leach
Pamela Leach
Are you a Baking Expert? Answer questions, earn points and help others
