Question about Dell 3400MP Multimedia Projector
Dell 3400mp Fan Disassbly
Has anyone disassemble the fan on Dell 3400mp? Is there one or two? Is it easy? Can you share the part numbers?
Nobody has a master password for dell 3400mp
Download the manual from the Dell site and see what it is from there. But if the previous owner changed it then you're out of luck.
Sep 06, 2014 | Dell 3400MP DLP Projector
How to replace fan ?
I would recommend searching the brand and model of your laptop. If you need to find the fan, search 'Brand Model # fan' on Google (or your preferred parts site. For example 'Dell Vostro 1720 fan'. If you need the physical replacement instructions, then add 'replacement' or 'disassembly', such as 'Dell Vostro 1720 fan replacement' or 'Dell Vostro 1720 disassembly'. (I used a sample laptop model for these instructions; replace 'Dell Vostro 1720' with your laptop model.)
Sep 01, 2014 | Computers & Internet
How to replace a ceiling hc 1131 wiring harness
Hampton Bay is a low-end fan for Home Depot only. GOOD LUCK!
Aug 17, 2014 | Hampton Bay 24002 Ceiling Fan
Fan problem with Latitude E6230
Go to this link and it will show you how to disassemble the fan. http://www.dell.com/learn/ng/en/ngbsdt1/videos~en/documents~latitude-e6230-heatsink-and-cpu-fan-disassembly1.aspx
Apr 07, 2014 | Dell, Inc Dell Latitude E6230 Laptop...
Xps 420 air temperature sensor
I would remove your fan & heat sink to check that your thermal paste isn't dry first.
Jul 15, 2012 | Dell XPS 420 PC Desktop
My Dell Demension Desktop B110 Model has a fan bellow the power supply fan motor. That so called fan that I'm speaking of so happens to cool the processor, through a funnel type housing that goes around...
there will be a sticker on the fan itself,
it starts "CNxx-xxxxx-",
the italicised x's above denote a 5-digit part number. call dell and ask for a fan, quote the part number and but one.
failing that most local computer repair shops can change the fan motor/blade unit and fit it into the original housing.
May 07, 2010 | Dell (6F858) Cooling Fan
Projector projects red screen.
My take on this...if that pin was *shorted* to another pin in the connector and not just bent, you could be looking at a damaged video input section. The pins in the video connector consist of the 3 color signals(red--green--blue), their individual grounds, and syncing. If this has indeed happened, which is *VERY* easy to do, the projector must be repaired by a service facility.
May 05, 2009 | Dell 3400MP Multimedia Projector
Need instructions on how to replace fan for dell inspiron 1525
The service manual has complete disassembly instructions, this is not easy.
Inspiron 1525 service manual
Mar 25, 2009 | Dell Inspiron 1525 Laptop
47 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
