Question about D-Link DP Computers & Internet
Factory reset d link DI-604 ethernet router - DP D-Link Computers & Internet
    Sergeant:
  • 239 Answers
There should be a pinhole that allows you to do it with a paper clip...
Posted on Feb 16, 2014
I found a d- link 604 in my basement, do I need to download anything for it to work? If I reset it works once.
Most operating systems will automatically download the software for most hardwarwe.. But just in case that yours doesn't, just google Gateway D-Link DI-604 software download and it will direct you to the necessary software.
Sep 08, 2011 | Gateway D-Link DI-604 Cable/DSL Router...
I have a D-link (Broadband VPN Router) that I want to hook up but I don't have the software. Is it possible to get free software downloads? The model #: DI-804HV.
Hello there,
You don't need a software for this one of the connection only requires an ethernet cable. What you need to do is to hook up the cable and then connect to the router locally. You may have to refer to the manual but usually you access 192.168.1.1 or something alike.
Apr 09, 2011 | D-Link DI-604 4-Port Cable/DSL Router...
I need to know if the D link DI 604 Router can be used for a wirless networking
No, is the short answer. It only has the 4 ports which have to be wired with ethernet cables. So this Router is a wired router.
Mar 25, 2011 | D-Link DI-604 4-Port Cable/DSL Router...
Want to connect aDI-604UP wired router to a DIR-615 wireless router to use as a printer port wirelessly
Hello Richard.
For this, you have two types of connection
1. LAN_LAN (ethernet to ethernet) -->wireless router is acting as a switch
2. LAN_WAN (ethernet to internet)-->wireless router is acting as a wireless router
in this case, you need the LAN_LAN connection
Physical connection:
plug an ethernet cable from the ethernet port on the wired router and connect the other end of that cabl to the ethernet port on the wireless router
Configuration:
log-on to the setup page of the wireless router, do this while the wired router is turned off.
-open your internet browser, type 192.168.0.1 on the address bar. Then type the username & password for the router ( default admin as the username, password : ).
Under the setup tab, click manual configuration. Then click network settings, change the router ip address to 192.168.0.5 & disable the DHCP server. save the settings. Just personalize the wireless network.
Hope this helps.
Sep 15, 2010 | D-Link DI-604 4-Port Cable/DSL Router...
Hi, My d-link dl-604 suddenly stopped working. When I plug it in, only the power led and #4 lights are up. None of the other leds are responding nor the internet is not working as well. Please help. Thanks
The following reset procedure will completely restore the default settings on your D-Linkmag-glass_10x10.gif device including your password. This procedure applies to the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-754, DI-764, DI-774, DI-784, DI-804V, DWL-700AP, DWL-800AP+, DWL-900AP+, DWL-1000AP+, DWL-2000AP, DWL-2100AP, DWL-6000AP, DWL-7000AP, and DWL-7100AP.
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
Note: Do not recycle power during the reset procedure.
The default user name for most D-Link devices is admin and the password is left blank.
Hope this helps! Give me thumbs please!
Aug 23, 2010 | D-Link DI-604 4-Port Cable/DSL Router...
My DI-604 router has stopped working. Why
maybe its already defective. isolate it very well. maybe it needs some cold reset.
Mar 05, 2010 | D-Link DI-604 - 4-Port Broadband Router [...
Cant connect the d-link website after ip replacement.
Have you tried to reset your router? If not, do so. It will reset everything to factory default.
To reset, look for a hole near the ports, where it says RESET. Use a pointed object such as a paper clip.
Hope it helps.
Aug 24, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
Lost security key
You will have to do a factory reset on the router. These is a small reset button on the back (you have to press is with a pen). Hold down the reset button while unpluging and pluging back in the router. This will reset the security settings and allow you to start over from scratch.
Jan 24, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
No response from the DI-604 D-Link Router
The cable must be of parrallel type......(not cross)... connecting router and the modem or PC...
Dec 23, 2007 | D-Link DI-604 4-Port Cable/DSL Router...
Factory setting
The following is for the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-624S, DI-754, DI-764, DI-774, and DI-784 routers. To perform a reset, please follow steps below: Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled Reset. Step 2 Hold paper clip down for 10 seconds and release. Note: Do not repower unit during this procedure. Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset. Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults. If you have the European version of this router, this procedure may not work. Please consult the D-Link office near you. D-Link USA does not support the European version.
Feb 16, 2006 | D-Link Air Xpert DI-774 (DWL-774) Wireless...
Computers & Internet Logo
53 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
