Question about Ragalta Deluxe Ice Maker
Need to know how to operate regalta ice maker
Where does the water go in a regalta ice maker
Nostalgia Electrics Ice Maker Troubleshooting
My Nostalgia Ice maker shows low water, but there is water up to the fill line.
Mar 10, 2014 | Nostalgia Electrics RIC-100 Retro Series...
I purchased the ice cream maker without a user guide. Is one available?
Are you looking for operating instructions or recipes? Recipes available everywhere ... really. Operating? Here is what you do: Get some ice cubes ... crush them with a hammer ... you will need a lot ... the finer crushed the smoother the ice cream. Put the mix in the metal container and put about 4 -6 inches of ice in the bucket with some water. Put about 1# of rock salt on the ice. More ice ... more salt ... more ice ... more salt ... more ice ... more salt until the bucket is full. Start the machine. Your ice cream should be ready in about 1/2 hour. When the machine stops cranking ... remove the mixer from the can. If you can stand it ... let the ice cream sit in the container for 1/2 hour ... the longer you wait the better the batch. But who can wait???
The ice cools the water, the salt reduces the temp of the water to cause the mix to freeze.
I hope this helps you ... this is how we make home made ice cream every summer ... what a special treat for the kids ... young and old alike.
Thanks for your question @ FixYa.com
Mar 18, 2011 | Rival 8605-M 6 Quart Ice Cream Maker
Polar Ice maker says low water level when full of water
Replace the motor. During the cycle of the unit if the water flow circuit does not scence flow, the unit faults with a low water indication
Jun 22, 2010 | Polar PIM15W Ice Cream Maker
I bought a used taylor ice cream machine. It is model number 8756-27 and it was manufactured in 1987. It is a water cooled machine ... Do you know how much water it uses daily?
You use ICE, not water and then rock salt is added over the ice to lower the temperature for making the ice cream.
The salt hastens the melting of the ice and thus lowers the temperature.
Nov 13, 2009 | Rival 8550-X 5 Quart Ice Cream Maker
I need an instruction manual for my Deni 5000 ice cream maker
Are you looking for operating instructions or reciepts?
Find receipts via Google.
Operating instructions:
place the mix into the can with the paddle inside. Place the can into the bucket. Attach the motor or crank as appropriate.
Crush some ice (aboout 5 pounds) and pack about 2 inches around the base of the can with the can in the bucket. cover this ice with rock salt. Put two more inches of crushed ice on top - spread more rock salt (the smaller the ice, the smoother the mix). Continue this process until you are at the top. Make sure the drain is clear, start cranking (or motoring. When the motor stops, unplug it. Cover all with a heavy towel for about 30 minutges (if you can stand it) If for some reason the motor doesn't stop - you didnt put in enough salt. Expect to use about 1/2 of a 5 pound bag.
Remove the towel - the motor - the top - the paddle. Give the paddle to the kids with a couple spoons. Dig in for the adults.
I sometimes add a quart of water but you dont have to.
The ice makes the water cold - the water provides the freezing power, the salt lowers the freezing point of the water - the extra water might speed the process a little bit ... maybe not
Enjoy your delicious home made ice cream.
(BTW - the paddle does not move ... the can spins around the can causing mixing.
a
Oct 14, 2009 | Deni 5000 Scoop Factory 1.5 Quart Ice...
My newair A1200ss stopped making ice. i tried recycling the unit and it has ample water, but the ice tray just stays in the down position. thanks.
I have had the same problem with two different portable ice makers, the ice tray inside is broken so you will have to send it to them and get it fixed. Hopefully eventually they will make the tray out of a stronger plastic.
Nov 29, 2008 | NewAir AI-200SS Ice Cream Maker
Ragalta Deluxe Ice Maker Logo
67 people viewed this question
Top Ragalta Ice Cream Makers Experts
ray gallant
Ruth summersides
Are you a Ragalta Ice Cream Maker Expert? Answer questions, earn points and help others
