My intex avatar tablet (IT-M809RC) wont turn on
It shows the green android guy and it just stays that eay and i also tried reseting it with a paper clip
  • 21 Answers
SOURCE: Red light will not go Green
FIRST U CONFORM THAT UR WEBCAM DRIVER CD HAD BEEN INSTALLED, AFTER THAT UR ADD THE WEB CAM IN UR COMPUTER....
OR
JUST OPEN THE CRTL PANEL.
AND CHOOSE THE ADD DRIVERS.
CHOOSE THE WEBCAM CD DRIVER THROUGH THE BROWSE AND INSTALL IT.
THEN REBOOT UR COMPUTER AND ADD THE WEB CAM.....
Posted on Dec 10, 2008
SOURCE: my etouch elonex tablet wont
Has anyone found out the problem to the e touch as mine is not working ither.. Great gadget!!!
Posted on Dec 25, 2010
SOURCE: My elonex e touch tablet
My elonex e touch tablet wont turn on, it just stays on a screen which says android
Posted on Jul 10, 2011
brimknows
  • 10 Answers
SOURCE: my android tablet is "frozen". Will turn on but
has anything been deleted from it when it has been plugged into a computer or has anything been deleted from the device itself from its root directory? if not and its gone like that by itself, it could be corrupted software or a missing root file which is usually bad at first, now what i know about some tablets is if it wont work theres a recovery file usually internally but this is in some tablets only that ive read about, i also have one but havent needed to try to restore it and it can be done from an engineering mode, this is possable by pressing the power button and another button like the home button at the same time once the unit is off untill it turns back on with options, but as for some models im not sure of but i will have to look this up at some stage as i am working on tablets at this time so unless you know what you are doing i wouldnt attempt it, once i have gotten through some tablets ill be able to give a better resolution on this subject with others. the advice ive given wont work for all as pressing power and home will start different options up on different tablets and versions.
Posted on Oct 26, 2011
SOURCE: The tablet turns on but seems frozen and shows the android screen and nothing else. Tried to reset it but it does the same thing
so wat do i do
Posted on Dec 28, 2011
I have a proscan tablet plt7777g. It will not load it turns on and gets to part where it says android but it just stays there.
First Turn off the Tablet, and locate the small pin hole reset.
Press and Hold the Power button while poking the hidden reset button with a small object like a paper clip until you see the Android logo, let off the power button.
Use the paper clip and poke the hole to navigate the menu, hit the power button to accept the menu items.
First select Wipe Data if avialable, then Select Factory Data Reset. Reboot the tablet after it is done reinstalling Android.
This is a common problem with these off name tablets, be weary when buying cheap devices.
Oct 11, 2014 | Tablets & eReaders
Tablet turns on shows zeepad then android and wont turn on
someone told me that when that happens that I must have blown one of my cores
Jul 09, 2014 | ZEEPAD 7 inch Android 2.2 Tablet
Tablet is stuck on the screen that says android
You may have to reset the tablet to factory settings. This may be the only way. It will wipe all the data on it.
To factory reset:
1. Press and hold power plus volume up until an android menu appear 2. Use the volume keys to navigate and option key or power to select. 3. look for factory reset and wipe data 5. restart the device and it should be back to factory settings.
Feb 04, 2014 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
My tablet wont turn on it continues to blink but wont turn on
Try using a paperclip to reset it on the back, hold it in for 5 seconds, if that doesnt work:
Turn the tablet all the way off, press and hold the VOL - and power at the same time for 8 to 9 seconds, it will show a green android guy with a system recovery menu. Use vol - to go down to Wipe Data/Factory Reset, press the power button to select it, go down to 'yes' to confirm, press the power button to select it, it will wipe the tablet, you then press the power button on 'reboot system'.
Apr 20, 2013 | Coby kyros Tablets & eReaders
FORGOT LOCK PATTERN ON A COBY KYROS
Apr 06, 2013 | Coby Kyros MID9740-8 8GB 9.7" Capacitive...
When i try to turn on my android tablet the screen turns on but stays black then it shuts off
yes your os has got corrupted .
rush to service center .
they will re-format it. and it will be ok.
Jan 02, 2013 | Craig CMP741d Tablet
Tablets wont boot up just shows arnova on screen and shuts down
I had same problem looping startup just showing Aenova screen, i tried the pin thing ended up doing a factory reset IT WORKED WAHEY!!
How can I do a Factory Reset on my tablet? If your tablet freezes often or if you get error messages during the start up of your tablet, you can use the recovery mode to reset your tablet to its factory settings, removing all installed applications as well as any data or content.
Your tablet must be up to date with the latest firmware - downloadable from the downloads area of this website.
To access Recovery mode on the ARNOVA 10bG3
To access to the recovery mode:
1. Hold down the volume button + and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button +.
The ANDROID green robot is displayed.
3. Once the ANDROID green robot is displayed, press simultaneously the volume button + and the ON/OFF button.
The Android system recovery screen is displayed.
a. Use the volume buttons to navigate
b. Use the ON/OFF button to select an option
To restore the default parameters of your tablet:
1. In the Android system recovery, select Wipe data/factory reset;
2. Select Yes -delete all user data.
3. Select Reboot system now.
Your tablet reboots. Redefine your parameters through the wizard.
Your tablet is restored to its default settings.
To access Recovery mode on the ARNOVA 9G3
1. Hold down the Home button and press the ON/OFF button.
2. Once the ARNOVA boot logo is displayed, release the Home button.
To access Recovery mode on the ARNOVA 8cG3/8bG3
1. Hold down the volume button - and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button -.
Sep 16, 2012 | Tablets & eReaders
Computers & Internet Logo
122 people viewed this question
David Payne
David Payne
