Question about EdgeStar TWR282S Wine Cooler
SALTON wine cooler WC-2034
Unit 0757-83835018 is burned
How do I program the temp on a Salton 12 bottle cooler?
It depends on the model Alan. Some have a digital control on the front panel and some have a rotary knob on the inside.
A list of all the Salton instruction books are here.
https://www.salton.com/instruction-books-manuals/
Jun 12, 2016 | Furniture
My spt wine cooler wont cool it stays at 75
You should refer to the user manual to help you troubleshoot your equipment located Here: http://www.manualslib.com/manual/574948/Sunpentown-Wc-30u.html
I hope this helps!
Good Luck!
Rich Lilja
Jul 22, 2014 | Sunpentown WC-30U Under-Counter Wine &...
Top unit won't cool
Usually with thermoelectrics they either work or they dont. Not easily repairable unless you are a competent technician as the components need metering. Sounds like a heater element gone.
Apr 09, 2014 | Sunpentown SPT WC-1857DH 18 Bottle Dual...
Should there be any problem to locate my wine cooler under the counter?
Actually, when using a freestanding wine cooler the heat designed to escape from the back and I your case the heat won't have a place to escape to and eventually will over heat the whole unit. Then the compressor will attempt to compensate for the heating and may eventually burn itself out.
Aug 14, 2012 | Furniture
What is a build-in wine cooler?
A build-in wine cooler is designed to be built into exiting counter and cabinetry. Build in wine cooler includes a front ventilation system which channels the heat forward from the unit, just like any other wine cooler.
The wine cooler is plugged in, but it does not come on.
Check the outlet, should be 120v. also is the evaporatir fan coming on. Could be a compressor relay problem. You have to go behind unit to check. remove relay and see if its burnt. You can smell if its burn out
Feb 17, 2011 | Magic Chef MCWC45A Wine Cooler
Unit has been operating in a wine closet and just stopped working it there anything I should check or clean? swaney167@aol.com
does the 'closet' have any ventilation? if not the unit could have overheated and shut down or , worse, burned up the motor. any 'electric smell to it? under the unit, should be a fan, it that stopped it will not cool. look for lint build up under the unit or around any air vents. How old is the wine cooler? can you get any info from the Wine cooler's mfg web site? www.danby.com/products/wine__beverages -
Dec 26, 2010 | Danby DWC440 Wine Cooler
Refrigerator cooler and fan stopped
On winecaptains when I hear this its usually telling me that the thermostat is open. You will need to replace it. You can put the 2 wires together and plug the unit back in to see if this works. If it does replace the thermostat. If this is a 20 series then the control should be a #2767-1 if its a 15 or 75 wc then part #2767-S But if its a 21 then you need somthing else with the electric. Try to unplug the unit and wait 5 min then restart it if its a 21 series
Jul 20, 2009 | U-Line Wine Captain (2015WC) Wine Cooler
Power ON but unit does not get cold
I have the same issue, same thing after approx 2 years,the zone on top stopped working, even leaking water if I leave it plugged... did you ever get any answer for this?
Thx
Mar 31, 2009 | Refrigerators
U-Line 15WC Wine Cooler Problem
Cheak The Compressor relay is fault
May 20, 2008 | U-Line 75WC Wine Cooler
EdgeStar TWR282S Wine Cooler Logo
66 people viewed this question
Top EdgeStar Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you an EdgeStar Refrigerator Expert? Answer questions, earn points and help others
