Question about Frigidaire Dishwashers
Frigidaire 154580501 won't start - Frigidaire Dishwashers
  • Electrolux
    Electrolux Feb 27, 2014
    Hi Jorie, I see that your question is listed under Frigidaire dishwasher, is this correct? I want to help you with your problem; however, it appears above-listed model number is invalid. The serial tag, which lists your model number, is typically located on the right side as you open the door. With this information I can better address the issue at hand. Thank you!
My 2009 Frigidaire dryer door won't open
un plug the dryer for two minutes let it reset , then plug it back up. see if this helps you.
Feb 11, 2013 | Frigidaire Dryers
I have a stackable Frigidaire washer/dryer combo and the problem is that when you push the start button, you hear an electrical buzzing but the dryer won't start. When you take the panel off it st
Hello Mike Brady - From what you have described it seems like the dryer is experiencing a wiring failure or a communication error with the control board. Contact a professional to move forward accurately.
Jan 08, 2013 | Frigidaire FEX831CS Top Load Stacked...
Reset frigidaire dishwasher model FDB1100RHC
I had the same issue. I unplugged the dishwasher and plugged it back in. Bam! It's working fine now.
Oct 16, 2012 | Frigidaire Dishwashers
When pressing start on my frigidaire washer LTT2940FE1, It says pause and won't start.
Reset the unit at the household circuit breaker and retry. PAU means the unit is paused either by a blockage and the sensor won't let the unit continue, or it was manually paused by a button press.
Jul 26, 2012 | Frigidaire ATF6000ES Front Load Washer
My Frigidaire frontload washer (model #LTF7000EG0) wont start because Door luck button comes on saying it won't lock. Please Help??
My guess is that being that the lock is electronic, either the lock is defective or there is a problem in the control board in that it's not telling the lock to lock the door. I would have a tech check the board.
May 08, 2012 | Frigidaire Washing Machines
My frigidaire gallery electric dryer won't turn on. In the past it has been a bit on the noisy sound with a squeaky sound coming from the back. The last time I went to put a load in the dryer the...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 27, 2011 | Frigidaire Dryers
Frigidaire gallery series electric dryer/washer. Dryer won't start
heatman101
Aug 10, 2011 | Frigidaire Dryers
Dishwashers Logo
63 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
