Toshiba 55vl900a red light on will not come on
A vertical dark line has appeared on the screen of my 55VL900A television. Is there anything I can do to get rid of it?
The TCON board or the LCD panel is faulty. Can confirm By replacing the TCON board.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 06, 2017 | Televison & Video
Toshiba LCD LED TV Not working.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Oct 22, 2016 | Toshiba Televison & Video
Red light blinking
google to see several posts on projection tv red light blinking from several different manufactures (sony; toshiba; samsung; philips; you name it) and several models.
http://www.avsforum.com/forum/63-rear-projection-units/975795-toshiba-65h81-went-black-blinking-red-light-help.html
Apr 16, 2016 | Televison & Video
42 inch toshiba red light blinks three times no picture or no sound
Toshiba e-studio 18 every morning frist time copy light and background
Oct 31, 2013 | Office Equipment & Supplies
Toshiba a200 flashing power light .. blue blue red red HELPPPPPPP
Remove battery and power
Remove memory in lower socket, the one on the system board and try reboot with just power cord. May have bad socket
Dec 11, 2009 | Toshiba Satellite A200-0ET00X Notebook
Toshiba dlp red light green light on and off no image
It was the lamp cover original response was right on point
Nov 29, 2008 | Televison & Video
Toshiba tv
Is the red light flashing or solid?
If the red light is flashing it is the signal board is bad part number 75001688 $425.00 - $475.00 depending on supplier.
If the red light is solid then you signal cable has come loose or has went bad.
Sep 10, 2008 | Toshiba 42DPC85 42 in. EDTV-Ready Plasma...
Toshiba dlp 46 inch red light keeps blinking
42 inch Toshiba DLP. Was watching a movie and the screen went dark. The red light started to flash and kept flashing. any ideas
Jun 26, 2008 | Toshiba 46H84 46" Rear Projection...
Toshibe CF32G50 - Red Flashing Light
YOUR SET IS TRIPING MAYBE POWER SUPPLY IN TV SET
Jul 11, 2007 | Toshiba CF32G50 32" TV
Televison & Video Logo
Top Televison & Video Experts
