Open to remove disc - Computers & Internet
  • 39 Answers
Usually on the front of the cd/dvd player you will find a little hole. After turning off the power just insert the end of a paper clip in there and push. It should release the tray.
Posted on Mar 20, 2014
I have satellite C50D-B-10q. How do I open the CD/DVD drive?
Removing discs
To remove the disc, follow the steps as detailed below:
Do not press the eject button while the computer is accessing the optical disc drive. Wait for the optical disc drive indicator to go out before you open the disc tray. Also, if the disc is spinning when you open the disc tray, wait for it to stop before you remove it.
1. To pop the disc tray partially open, press the eject button. Gently pull the disc tray out until it is fully opened. When the disc tray pops open slightly, wait a moment to make sure the disc has stopped spinning before pulling the disc tray fully open.
2. The disc extends slightly over the sides of the disc tray so you can grasp it. Gently lift out the disc.
3. Push the center of the disc tray to close it. Press gently until it locks into place.
How to remove disc when the disc tray will not open:
Pressing the eject button will not open the disc tray when the computer power is off. If the power is off, you can open the disc tray by inserting a slender object (about 20 mm) such as a traightened paper clip into the manual eject hole near the eject button.
Manual eject hole:
Turn off the power before you use the manual eject hole. If the disc is spinning when you open the disc tray, the disc could fly off the spindle and cause injury.
See page 4-8 of the user manual:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=11&cad=rja&uact=8&ved=0CB0QFjAAOAo&url=http%3A%2F%2Fwww.mytoshiba.com.au%2Ffile%2Fdownload%2Fresource%2Ffile%2F25248%2Fsatc50-satpro%2520c50%2520userguide.pdf&ei=hP8qVL7FH8jygwSZtIDwDw&usg=AFQjCNG3BeuYjMmp05rKf6DHmKe2CwfZxQ&sig2=5VtO-__wyjN_V8vBe9na3g&bvm=bv.76477589,d.eXY
Jun 05, 2015 | Toshiba Computers & Internet
How do I get the disc drive of a dvd recorder to open after getting out the disc and resetting the machine?
Go back through the release process you did the first time to remove the stuck disk. it appears that part of the mechanism that moves the drive did not engage again.
Apr 25, 2015 | Panasonic Televison & Video
I put a disc in the drive and it stayed in the computer when the disc drive was opened
I am assuming that when the disc drive tray came out, the holder was empty, and you had placed the disc in the holder prior to this. Did you use the disc? Did it operate properly? Has your PC been tilted for any reason before trying to remove the disc? My feeling is the disc has to be SOMEWHERE! Take a flashlight and take a peak in the opened drive. Can you see the disc anywhere? Perhaps tweezers can be used with scotch tape wrapped around the points to keep it from scratching the disc. Grasp the edge of the disc and pull it out, if possible. If you can't find the disc, you should open the case and do a search. You might need to remove the drive itself, but hopefully you will get the disc back without needing to go to that step.
Jul 14, 2014 | HP 19-2014 All-in-One Desktop PC - ENERGY...
A DVD is stuck in the player and the door will not open, it makes a grinding noise when you try to open it.
well looks like the disc is lodged into the track thats why you cant open it, the grinding noise is the track slipping on the motor gears as it forces to attempt to open and fails..
what we need to do is open this up and remove the disc manually..
  1. unplug the device (dont wanna get electrocuted)
  2. remove the screws to the back and under the player
  3. lift the cover off by sliding it back then raising it up , prying with a bladed screw driver helps.
  4. you will now see the disc stuck under this metal / plastic piece if you can see the disc at all.
  5. remove the screws holding the disc tray top in place. remove the disc and reassemble.
that should solve the problem, let me know how it turns out of if you need more help if you ran into a tight spot.
Apr 05, 2011 | Oritron Televison & Video
Player was moved discs fell forward. Now when the player comes on it makes a horrible sound. Can't get door to open
you're going to have to open the player by removing the top cover and returning the discs to their correct places on the carousel. If you've coded the discs' locations and disc names it will be a pain to have to re-code them, I don't know if the memory will clear if you take the discs out and power the unit up and it finds they're not there.
I believe the discs being out of place are what is preventing the door from opening. It's operated by a motor located under the right front of the carousel, and the only way to get it it is to remove the carousel.... which isn't hugely easy but it can be done, you'll have to take the top stuff off inside, unplug at least several of the cables etc so you can move the top board out of the way. Make sure that all the discs are back in their places on the carousel, OR removed, before you turn the unit back on.
Dec 02, 2010 | Sony CDP-CX400 400-Disc CD Changer
Discs have been dislodged form the unit - How do I open the unit
Have to remove the top cover and carefully
remove all the cd's without scratching them!
Should operate normally after that!
Apr 20, 2010 | Sony MegaStorage CDP-CX355 300-Disc CD...
DVD side will not open, for the longest I could only get the DVD side to open if there was a disk in the slide yesterday the DVD side was closed with NO disk in it and now I can not open it
The DVD player in model DRC8295 uses a magnet to pull the Disc tray up into position. You can open up the front disc cover and push down slightly on the Disc tray and then push the open/close button to eject the tray. If this doesn't open the unit, you will have to unplug the unit and remove the cover. The cover is held in place by two silver screws on each side and five silver screws on the back of the unit. Once the cover screws have been removed, you can slide the cover towards the back halfway and then take the silver cover (held in place with two screws) off of the DVD player. Once the DVD cover is removed, insert a disc in the player and re-install the dvd cover and case cover. Plug the unit back in and eject and close the cover like normal. I have never tried to remove the magnet from the cover and checked to see if the DVD player still worked correctly. I have found it easier to just leave a Disc in it at all times. I leave a "Bad Disc" in mine and it opens/closes with no problems.
Apr 09, 2010 | RCA DRC8295 DVD Recorder/VCR Combo
My coby-514 dvd won't open up when the open/close
disc is stuck, remove cover screws and carefully remove the disc, do not force the unit, once the disc is out use the remote to close the unit, then use remote to open and use a different disc press play and hopefully it will work, try to avoid not using the remote for all functions,including open-close. do not push tray in manually.
Dec 10, 2009 | Coby DVD-514 DVD Player
Inserted cd disc. play music on cd but will not eject the disc cd is stuck in cd player
Mostly The cd is jammed between the laser sensor and the cd rotator.Try removing the audio player and reseting the whole device if possible.Or if you have sufficient technical know how.Open the player try to manually open the disc tray.and remove thedisc.This can happen even  if the disc is broken inside the player.
Sep 28, 2009 | 2004 Jeep Grand Cherokee
DVD RW stucked - stall the whole system.
Hi, I found this site today cos I had a similar problem. To cut a long story short I found a slot on the bottom of the machine, below the disc tray, that has a white lever in it. After removing the power source I moved the lever to the side and the tray opened manually so I could remove the disc. It seems It was a duff DVDR as other discs now work fine. Good luck !
Oct 15, 2007 | Philips DVDR3440H DVD Recorder/HDD...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
