Question about Comfortmaker EDM4X48FA 4 Ton Cased Multi-Position Evaporator Coil
Rattling sound on the outside fan of a Comfortmaker high efficiency heat pump
Comfortmaker high efficiency heat pump makes an intermittent rattling sound in the outside component. I took the top off to expose the fan and saw where the outside edges of both blades of the fan are slightly damaged. It must be rubbing against the outside casing but I could not see where it's rubbing. I bent the blades very slightly at the edges and the rattling stopped. Is this a common problem? Does it matter if I bent the edges of the blades a tiny bit?
What causes my frigidaire top load washer to vibrate and make rattling noise during spin cycle
There are springs and bumpers/shocks in the machine that hold the tub. When they break or come loose, the tub wobbles.
Jan 03, 2016 | Frigidaire FAHE4044MW Affinity High...
The fan makes a lot of noise, is there a way to replace it?
The type of refrigerator you have uses a solid-state device which likely uses a Peltier effect element. This uses electricity to transfer heat and cold on opposite sides of the element, absorbing heat from within and radiating it from the other side being cooled by the fan.
With no moving parts other than the fan, they are very reliable but also very dependent on ridding the element of the absorbed heat which necessitates fairly high air flow to function properly. If a fan was used that produced less noise, the airflow might be too little to allow the element to cool the interior efficiently.
Unless the fan has a defective bearing, which would reveal itself by a rattling sound, it is probably still working as it should.
Nov 28, 2010 | Avanti Compact Thermoelectric Refrigerator
Fedder Heat Pump not Running
you can check your heat pump on the outside by turning off the power and listening to see if it makes a whoosh sound. and then turn it back on you should hear it kick in. Is the outside unit running? Sounds like an electrical problem maybe in the breaker or the contactor on the inside of the unit. This is where the 24 volts from the thermostat call to the 240 volts to kick on the condenser fan and compressor. Be real careful in messing with this because of the high voltage.
Jul 09, 2010 | Fedders C36ACD1VF Split System Air...
The oven makes a loud rattling sound when it reaches a certain heat (tends to be about 200 degrees) and then rattles intermittently until turned off. If you slam the door it does sometimes shut for a...
From what you describe is happening, I would say that it is the fan that is causing the noise, not neccesserily the oven fan, because there is an external cooling fan as well, and these are the only moving parts that could cause a noise.
Hope this helps.
Feb 02, 2010 | Candy FP855 Electric Single Oven
Fan Won't Spin
Is it humming like a stuck motor or rattling, like a loose fan. If it's rattling, the fan could eith be loose on the motor or, the center hub could have broken loose.
Aug 10, 2009 | Carrier 38CKC036 Air Conditioner
Chain rattling sound right front
no it would not be the timing belt making a rattling noise it couldn possible be you heat shield around your break rotor it could be someting having to do with ur suspenion like a spring maybe what kind of rattling noise? or a regular heat shield but loose in that particular area
Mar 31, 2009 | 2005 Subaru Forester
66 Mustang- 289 V8- has an intermittent surge and rattling noise
Sounds like crappy gas. The 289 may not like pump no-lead and the rattling sound you are hearing may be pinging / knocking.
Mar 07, 2009 | 1966 Ford Mustang
Heat pump is humming loud>
When the heat is not on. Go to the T-stat and turn the fan to the on position. With the blower now running is it making the noise? If so you probably either have something in there such as the filter that was mentioned, a piece of paper etc. or one or more of the blades on the blower wheel is vibrating. Don't let the condition persist w/o having it checked out or you may turn a simple fix into a costly one.
Jan 22, 2009 | Heating & Cooling
Fan making a rattling sound
check whether any wire is touching it or the blades touches the outer circumference in someway...
Sep 27, 2008 | Toshiba (P000247220) Fan Assembly
Rattling noises and blowing water (goldstar WG5005R)
If the unit is new and tilted enough toward the outside, the rain should not be a factor as far as water blowing out. It will make some rattling noises on the outside more so when its raining or high humidity because the outside fan throws water onto the condenser coil. Sounds like to me that its not draining to the outside.. It shouldn't be dirty enough for the drain paths to be filled with crud. Tilting it more to the outside should fix it. Hope this helps. kstfas
Aug 26, 2007 | Heating & Cooling
Comfortmaker EDM4X48FA 4 Ton Cased Multi-Position Evaporator Coil Logo
43 people viewed this question
Top Comfortmaker Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Comfortmaker Audio Player and Recorder Expert? Answer questions, earn points and help others
