Question about Bobcat Scooter
Bought use. Pin holding together was gone. When I tried to move it it came apart. I got it back together but now it won't go
THE LEG AND COTTER PIN CAME APART FROM THE CENTER SPROCKET
From Paul182 himself: I FIXED THIS MYSELF. i HAD TO HOT GLUE THE PINS INTO THE TUBES, AND UNSCREW THE BOTTOM PLATE, THEN TURN THE TUBES 90 DEGREES PUSH DOWN INTO THE SLOT AND ROTATE BACK 90 DEGREES. NOT EASY BUT IT WORKS. THEN SCREW THE PLATE BACK ON.
Apr 14, 2014 | Cosco Juvenile Cosco Funsport Playard
I just bought a 94 grand prix and it is very hard to shift out of park into gear i checked the cable and that moves freely its in the column its very stiff im wondering if the pin in the column could be...
dude i had the same thing on mine and it was a very simple fix. person whop had car before me had spilled soda multiple times on shift lever. i took the secotion apart that has the lights, separated all the slides and when i put then back together it was as smooth as could be
Dec 28, 2012 | 1994 Pontiac Grand Prix
How do i ger the pin out of the crank shaft on a aprilia rs 125 big end bearing gone but can,t move the large pin holding it together
You need to take the crank to a machine shop. They will use a 20 ton hydraulic press to press the pin out of the crank. A new pin gets the hydraulic press to re-assemble the crank.
Jul 11, 2011 | TN'G RS 125 Motorcycles
I have an older B&D reciprocating saw i use and i need help with changing the blade. It has an allen screw that hold it in but even when i remove it there is still a small pin that holds the blade. I...
No, the pin holds the blade in there as a keeper device, The screw just puts the clamp on it. It was probably just stuck, If the pin is gone, driven out or out of the way, try getting it back to hook the blade on. The clamp alone won't hold it. I tried.
May 28, 2011 | Black & Decker Garden
Just bought Troy-Bilt TB350 XP with "MYSPEED." It starts up fine and moves quicklym because my speed came set at "4." I have tried setting "MYSPEED" to a lower setting. ...
I had the same problem, and after reaching out to Troy-bilt with no luck, I just went ahead and took the speed control assembly apart and figured out what was wrong... not sure what happened, but it wasn't assembled correctly.
In my case, the metal-toothed gearing plate was not positioned properly to allow the gear adjustment lever to move (laid in exactly opposite of correct), and the metal flex hinge that clicks in the notch of the speed control lever was just laying in there not doing anything.
The speed control assembly can be taken off the handle by loosening two bolts. The whole assembly compartment opens up by loosening two more. Take a picture if you have to, but be careful when you open it up that you are paying attention to how everything lays in there and you won't have any trouble putting it back together once you've aligned the metal plate properly. If you need a shot of the assembly put together correctly let me know and I will post a pic. Good luck!
May 07, 2011 | Garden
I just ordered a ps3 controller from RadioShack brand new. the L2 trigger does not work is there anything you would recomend
Hi if you have bought it new it should be working but sometimes you do get a faulty item, now their is no point in taking it apart as you wont be able to take it back to get a refund or replacement.
but you can try the following
1 on the back of the pad their is a tiny hole towards the middle part, if you look at the sticker on the back the whole is just above the top right corner of the sticker now if you switch the pad on by pressing the ps button then get a pin or something long and thin to poke in the hole now poke the pin all the way in and when its in far enough you should hit a switch and feel a click this is the reset button for the pad, so press that and then try the pad.
2 if that dont get it working then hold the pad in your right hand and hit it into the palm of your left hand hard a few times then give it a try, sometimes doing this gets the buttons working as the circuit might be in the wrong place, the printed circuit under the shoulder buttons is thin plastic and can sometimes move so doing this may get it back in its correct place.
3 now if the above fails the only option you have is take it back to where you got it from as taking it apart is the easy bit but putting it back together is a whole other ball game and trust me if you have never done one before then you will struggle to get it back together, you need a lot of luck and skill to get the shoulder buttons back in place its not east and trust me i have fixed loads, give me an xbox controller any day, even though it prefer the ps3 they just didnt make them very user repairable.
let me know how you get on or if you need further assistance ok
please rate this solution as i have a whole page of unrated answers, thanks
Dec 06, 2010 | Video Game Consoles & Games
Need schematic for home universal
You can get that at www.precor.com they bought the company years ago. This should help you.
Howard
aaafitness.net
Oct 01, 2009 | Exercise & Fitness
Rare breaks 'jammed' in vintage bycicle
That rod that holds the brakes in one piece is too tight ..loosen and try again...make sure to center brakes in frame before tightening mounting bolt....Good luck to you friend....Tim
Apr 04, 2009 | Cycling
The laser light on my black & decker bdl500 stopped working
I had the same problem with mine. I took it apart and inspected it. Mine was a loose connection and after some fiddling with the wires the laser came back on. Put it back together and haven't had a problem with it since. Hope it helps.
Jan 09, 2009 | Black & Decker BDL400S Bullseye Crosshair...
Pin fell back inside the central shaft.
Use a good strong magnet from the outside while holding it upside down. Move the magnet around the shaft as if going through a maze that you can't see- untill it finds the exit path out! Take an old hard drive apart and use the magnets they have-they're very powerful.
Oct 08, 2008 | Gitzo Mountaineer Mk2 G1228G Tripod
Bobcat Scooter Logo
19 people viewed this question
Top Bobcat Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Bobcat Health and Beauty Expert? Answer questions, earn points and help others
