Question about Whirlpool Washing Machines
My whirlpool estate washer model#etw4400wq1 during the final rinse/spin cycle doesn't spin out all of the water
My whirlpool estate washing machine model#etw4400wq1 SER#co4961198 during the final rinse/spin cycle will not spin out all of the water. I have to take out 1/4 of the load at a time(4-5 pieces)and spin them 1/4 of a load at a time. Can this be fixed and is the part or parts expensive?
  • 1294 Answers
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
Posted on May 18, 2007
SOURCE: Washer will not Spin during SPIN CYCLES
IT IS THE DOOR LOCK ASSEMBLY, COST AROUND $50.00 WHICH IS FAR BETTER THAN $300.00, WHAT A SERVICE REPAIR PERSON WILL CHARGE YOU. YEA IT'S THE CRAZIEST THING IMAGINABLE, THE DOOR LOCK ASSEMBLY BEING THE CAUSE FOR IT TO NOT SPIN ALL THE WATER OUT. I FIXED MINE MYSELF, HAD TO TAKE IT ALL APART VERY CAREFULLY, BUT I SAVED MYSELF $250.00. YOU CAN GET THE PART ONLINE OR GO TO NEAREST APPLIANCE PARTS STORE IN YOUR CITY. ASK FOR DOOR LOCK ASSEMBLY. THEY WILL KNOW EXACTLY WHAT YOU'RE TALKING ABOUT BECAUSE IT IS A VERY COMMON, I REPEAT VERY COMMON PROBLEM WITH THIS BRAND OF WASHING MACHINE.
Posted on Aug 12, 2008
docjohn174
  • 943 Answers
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Posted on Sep 11, 2008
jonniewalker
  • 1029 Answers
SOURCE: Whirlpool top Loading washing machine won't spin on spin cycle
If the washer won't finish a spin cycle, it probably means that your timer went bad or stalled. You can take the control panel off and look at the contacts for scorching or corrosion.
Posted on Sep 21, 2008
Check the lid switch. Through out time the lid switch housing can come apart from years of heat and cold. When I checked mine, I found the glue deterriated and the housing came apart. What I did to fix it is I zipped tied the housing together and did a functional check and it worked.
Posted on Apr 25, 2009
Whirlpool Estate washer ETW4400WQ1 spins but won't drain
Sounds like either the water pump or the program selector, probably the water pump though
Apr 18, 2014 | Whirlpool Washing Machines
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
My whirlpool estate top load washer ( model tawb600jq1) serial cro708750 type 110 has a very slow drip that begins during the wash cycle and continues after washing is done. How can I fix this?
Water valve is bad most likely. Once the machine gets going in final spin shut off the water supply till you can get another water valve.
This home video of mine shows the basic location of your water valve:
Sep 09, 2012 | Whirlpool Washing Machines
Washer agitates but does not spin
tI is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jun 12, 2012 | Estate Washing Machines
My Whirlpool GHW9250ML is having problems spinning
My Whirlpool Front Load Wasehr Model# GHW9250ML is having problems spinning on the final rinse cycle. The machine shuts down and the letter F appears on the digital read out.
Mar 06, 2010 | Whirlpool GHW9250M Front Load Washer
Spin cycle not removing enough water from clothes
your manual states that it can be caused by cold rinses and or spin cycle not getting completed. please try to rinse in hot or warm and see if that does not solve your problem
Dec 20, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Jul 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Final spin cycle
Lots of possibilities to check out before considering a problem with the machine: Is the load unsorted, too big or off balance? Drain restricted or too high? Oversudsed? Water draining completely out before going into spin?
Jan 08, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washing Machines Logo
29 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
