Question about Galaxy Radios DX-2547 40-Channels Base CB Radio
Frequency counter will not stop counting up - Galaxy Radios DX-2547 40-Channels Base CB Radio
  • 60 Answers
Is the radio transmitting and receiving correctly? Did someone tune or peak it recently? It could be a bad counter or just a bad ground.
Posted on Feb 21, 2014
How to solution services call m1 for Konica Minolta 164
11.5.4 MAINTENANCE COUNT.
A. Use
• To display the count of the maintenance counter.
• When the counter reaches "0", maintenance call M1 or the service call will appear, according to the setting on MAINTENANCE COUNT. of SERVICE'S CHOISE.
See P.85 below
e
• To enter an appropriate counter value (0 to 999999) as the tentative maintenance time.
• Specify the setting on maintenance counter to "1" or "2": If the maintenance life is
reached, the maintenance call (M1) or service call [Call Service (M1)] will appear.
"0" : Not counted
1 : Counted (The maintenance call display is given when the counter reaches 0.)
2 : Counted (The service call display is given and the initiation of any new copy cycle
is inhibited when the counter reaches 0.)
NOTE
• The counter value is decremented until it reaches -999999 even after it has
counted 0.
B. Procedure
• The default setting is 0.
• When "1" or "2" is selected, a screen will then appear to allow the counter value to be
entered.
• To clear the count, use [CLEAR DATA] of the SERVICE MODE.
Procedure below to enter::
11.2.1 Starting procedure
1. Press the Menu/Select key.
2. Press the following keys in this order.
Quick Settings Quick Settings left arrow twice the right arrow then left arrow
11.2.2 Exiting procedure
• Press the Back/Stop/Reset key as many times as it is required to display the initial
screen.
11.2.3 Changing the setting value in SERVICE MODE functions
1. Select the desired item using [??/??/??/??] key.
2. Select the setting value using [??/??/??/??] key.
3. Validate the selection by pressing the Menu/Select key.
4. To go back to previous screen, press the Back/Stop/Reset key.
Sep 29, 2016 | Konica Minolta Office Equipment & Supplies
Tip
Features found on most bill counting machines
Bill and coin counters come with a host of different functions and features that when you learn and master the them you will be a bill counting ninja! There are many terms that you will hear when getting started with your coin counter but the the most important ones are hopper capacity, error detection, adding mode and batch counting.
The hopper is the part of the bill counter that holds the bills that are going to be counted. Bill counting machines have a limit to how many bills the hopper can hold this is known as the hopper capacity. Usually instructions come with a number for how many new bills the hopper can hold, but if you are going to be counting older and crumpled bills that number will be cut in half. So if the capacity is 100 new bills then the number of old bills with around 50.
when you are counting bills its important to watch for error detection on the machine. These errors can be for a feeding error, detection of fake bills or a problem with the sensors in the machine. Machines with error decors are on the higher end but they make troubleshooting easier as well as give you confidence in their counting.
These last two features can be combined into one key feature that makes counting bills with a machine a breeze. Adding and batch counting modes. In a regular mode on a bill counting machine the counter will reset when you finish counting a stack, but if you enable adding mode the counter will continue to count from where the last stack left off.
Batching on the other hand is good for when you have a huge stack of bills like lets say $5's and you want them to be split into stacks of 10's. You can set the machine to batch count so it will stop counting after 10 bills have passed through. This is really good for if you are stacking bills into increments that are easy to count.
on Nov 14, 2013 | Retail Supplies
Minolta EP 4000 error M2 how to solve this problem?
Sir, Need to dump the waste toner box and clear the waste toner box counter in service mode. Stop 0 stop 1. select Counter clear Waste toner count count should be set to 180,000 copies for overseas
Panel reset for exit service mode
Apr 24, 2016 | Minolta Office Equipment & Supplies
Frequency counter Keeps counting up
get out you volt meter and grab the counter by the horns and check all the voltages going to it. you can get the manual at www.cbtricks.com and it has the voltage chart.
Feb 16, 2014 | Galaxy Radios DX-2547 40-Channels Base CB...
Reset error m2
M2 -waste toner box need to empty.
Displayed to indicated that the Toner collect count of the consumables counter has reached the set count.To reset select Count in the Tech.Rep.mode and acces the Consumables screen.Select the count of toner collect and press the clear key to clear the count.Place the copier in the Tech.Rep.mode by pressing the following keys:Stop-0-Stop-1.
Dec 30, 2013 | Minolta EP4000/5000 CS/PRO Copier
Service mode of bizhub c280?
Utility counter button
Counter
Details
buttons stop 0 0 stop 0 1
Jun 16, 2011 | Konica Minolta Office Equipment & Supplies
How can i program the counter to count bills totaling one hundred...for example one hundred ones and restarts
The Batch button allows you to count bills in batches from 1 - 999. For example, if you want to sort into piles of 100 bills, the machine will count 100 bills, then stops. Once you remove those 100 bills, it will continue to count the next batch of 100 bills, then stops again. The machine is preset to common counting mode, To count bills in batches, press BATCH. Batching is preset to 100 bills. To change batch amount, press C to clear, and use the keypad to enter a batch number between 1 and 999. Press SET to save the setting.
Apr 20, 2011 | Royal Sovereign Electric Bill Counter...
Waste ink absorber nearly full. Canon pixma mp130/110. How do I empty it?
Canon MP110, MP130
1. Include the printer.
2. Press the button "Menu" , then "Scan" , "Copy" and once again "Scan" (all - fell into service mode).
3. The Arrow to choose "Counter access" , press "OK" .
4. The Arrow to choose "ABC-M DOT Count" (or "ABC-P DOT Count" - depends on that, evidences what from counter = 100 ) and press "Copy" .
5. The Button "-" throw the counter before "0" , and press "OK" .
6. For leaving from service mode to press "Resume" .Good luck! Cheat that you dispose of problems!
Sep 28, 2009 | Canon PIXMA MP130 All-In-One InkJet...
How to Stop the Counter
you can't stop or reset the counter.
May 19, 2009 | Ricoh Aficio 1035 Copier
Item counter
there are several positions on the print item button. All of the way to the right the counter is on. To stop counting move one mor position to the left.
Sep 09, 2008 | Canon MP-25DV Calculator
Galaxy Radios DX-2547 40-Channels Base CB Radio Logo
64 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
