Question about Henry Numatic "" Canister Vacuum
Top falls off when carried - Henry Numatic "" Canister Vacuum
    Problem Solver:
  • 4 Answers
There are two clips on the side make sure there pull right out and the filter is push right down fit the top on and bang the side clips back in some are hard to clip back in I have to bang mine back in x
Posted on Oct 14, 2014
I can't get the filter to stay in after cleaning
Hi Patty, it's Jack at Dyson.
DC59 Motorhead's pre-filter is engineered to easy to remove for its monthly wash, but should also stay in place securely once it's replaced. In use, the filter will be held in place by the vacuum's powerful suction. When carrying the vacuum from room to room, we'd recommend keeping the machine horizontal, and to avoid carrying it upside down or vertically. It's also worth checking that the black rubber seal itself is clean and correctly positioned.
If the issue continues, I would encourage you to contact our experts directly so we can provide further assistance. You can reach us by calling 1-866-693-9766 (US) or 1-877-397-6622 (CA).
Jan 31, 2015 | Dyson DC59 Motorhead Bagless Cordless...
Dust goes to filter
is the canister sealing properly? The air enters the canister under high pressure and it should slow down greatly in there so the heavier (dust) particles will fall to the bottom of the canister and the air should then pass through the filter under a reduced pressure. If the air is easily escaping the canister area without slowing down the dust cannot settle. It should look like a cyclone in the canister, if it's not swirling in one direction but rather bouncing around, look at the inlet to the canister for build up or an obstruction also. If the canister is not sealing the the air will remain moving rapidly and carry the dust along with it. I would also check your filter for a tare along the seam.
Apr 03, 2013 | Dyson DC08 Cylinder Bagless Canister...
Kirby heritage 2 handle wont stay in the upright posision keeps falling backwards
Two things; your bag may be too full and needs replaced. (it doesn't take much to make them top-heavy) or the pin at the back of the base of the handle is not extended.
Feb 14, 2013 | Kirby Heritage II Vacuum
My dyson dco4 has gone loust power and wont switch back on???
How long have you had it? Most of them carry a 5-year warranty! Does yours fall in this category?
Feb 10, 2010 | Vacuums
The cannister won't stay/lock in place
there should be a release for the dirt cup at the top.make sure it in all the way and snapped shut
Apr 28, 2009 | Vacuums
Carpet power head will not stay attached to telescoping wand
to answer your last statement, if you do not have a receipt, the warranty will go by the date ofyour serial number. the first 4 digits are the month and year. this model usually has a 1 year wty. the wand button may not be protruding as far due to dirt under the metal band. however you may still have an issue with the neck on the powerhead which will require shop service.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Jan 18, 2009 | Hoover S3765-040 WindTunnel Bagless...
Cannot hook vacuum floor section when carrying. Falls vertically
Part # S-706. I found it at http://www.vacsrus.com/CartGenie/prodInfo.asp?pid=96&cid=28, but did not purchase it yet.
Jan 18, 2009 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
Bex Bissell Pro Heat 7920-E
Remove the cap for the flow indicator, then there 6 screws to remove to take off the top, before removing the top, turn the smart mix valve to about the half way point so the piston won't fall off. When you are ready to re-install the top cover, just before pushing it all of the way down, turn the smart mix valve to the water only setting, then push it into place, re-install the screws and the flow indicator parts.
May 27, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
I have a vax rapide carpet washer was using earlier and blew my trip switch noticed that the filter is falling to bits doyou think it can be repaired?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=553160
Generic problem for all Vacuums
I have a Vax Rapide
Posted by paulxlyn on Apr 28, 2008
I have a vax rapide carpet washer was using earlier and blew my trip switch noticed that the filter is falling to bits do you think it can be repaired?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Yes, you can contact your local vacuum cleaner dealer and if they don’t carry the Vax Model then feel free to contact the Vax Rapide Factory Manufacturer phone number or the website for further information and to order parts if needed. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.vaxusa.com/
If you have specific questions and you can't find the answer you’re looking for here, please call our Customer Service Department at 877.894.2031
M-F 8AM-7PM EST or check out our Contact Us page for more information.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 28, 2008 | Vacuums
Series6500SR
Check the air filter which is at the air output (blower) part of the canister, under the part where the attachments are stored. Also, I know how to disassemble, but the air filter is the likely problem.
Dec 12, 2007 | Electrolux Epic 6500 Vacuum
Henry Numatic "" Canister Vacuum Logo
20 people viewed this question
Top Henry Vacuums Experts
Gerry Harvey
Gerry Harvey
Chris Nomland
Chris Nomland
Are you a Henry Vacuum Expert? Answer questions, earn points and help others
