Question about JVC KD-S26
How to set station without buttons? - JVC KD-S26
How do i set the staions on my car radio
Look for a SEARCH BUTTON , Press button, when stations found , they will be on each station selector button, to keep station on any button , press button , then station is locked to that button
Mar 15, 2015 | 2012 Chevrolet Malibu
Change clock on Pontiac g6
There is 2 different radios. With or without rds. Here are the instructions for both.
Setting the Time for Radios with Radio Data Systems (RDS) To set the hour, press the clock button. The clock symbol displays and the hour flashes. Turn the ADJ (adjust) knob to increase or to decrease the hours. To set the minutes, press the clock button again. The minutes. Turn the ADJ knob to increase or to decrease the minutes. The time can be set with the ignition on or off.
To synchronize the time with an FM station broadcasting Radio Data System (RDS) information, press and hold the clock button to enter the clock set mode, then press and hold the clock button for three seconds until UPDATED displays. If the time is not available from the station, NO UPDATE displays.
RDS time is broadcast once a minute. After tuning to an RDS broadcast station, it can take a few minutes for the time to update.
Setting the Time for Radios without Radio Data Systems (RDS) To set the hour, press the clock button. The clock symbol displays and the hour flashes. Turn the ADJ (adjust) knob to increase or to decrease the hours. To set the minutes, press the clock button again. The minutes flash. Turn the ADJ knob to increase or to decrease the minutes. The time can be set with the ignition on or off.
Mar 08, 2015 | Pontiac G6 Cars & Trucks
How to program the radio in a 96Lincoln continental after battery was disconnected
Here is the link to the owners manual which you can download if you wish:
http://owner.ford.com/servlet/ContentServer?pagename=Owner/Page/OwnerGuidePage&year=1996&make=Lincoln&model=Continental
Here/below are the specific instructions on the radio programming (pg. 159 of above link).
Good luck & please flag if "HELPFUL". Thanks!
(from section) Luxury Audio System
Selecting the AM or FM frequency band
Push the "AM" or "FM1/FM2" button to select the desired frequency band. Pushing the "FM1/FM2" button more than once will alternate between FM1 and FM2. These functions are used with the station memory buttons described under How to tune radio stations.
HOW to tune radio stations
There are four ways for you to tune in a particular station. You can use the "TUNE", "SEEK", 'SCAN"or memory buttons.
• Using the "TUNE" function:
You can change the frequency up or down one increment at a time by Pressing and releasing either the left (< arrow/up) or - right (> arrow/down) side of the "TUNE" or "TUNE DISCS" button. To change frequencies quickly, press and hold down either the right or left side of the button.
Manual tuning adjusts your radio to any allowable broadcast frequency, whether or not a station is present on that frequency. (See All About Radio Frequencies in this section.)
• Using the "SEEK" function
: Press the right *) side of the "SEEK" button to select the next listenable station up the frequency band. Press the left (.4) side of the button to select the next listenable station down the frequency band. By holding the button down, listenable stations can be passed over to reach the desired station. Pressing the "SCAN" button will begin the scan mode up the frequency band, stopping on each listenable station for approximately five seconds. To stop the scan mode on the presently sampled station, press the "SCAN" button again.
Setting the station MEMORY PRESET buttons
: Your radio is equipped with 6 station memory buttons. These buttons can be used to select up to 6 preset AM stations and 12 FM stations (6 in FMI and 6 in FM2)
1. Select a band, then select a frequency.
2. Press one of the memory buttons and hold until the sound returns and the lamp above the memory button lights up. That
memory button is now set.
3. Follow the above steps for each memory preset button.
NOTE:
Custom memory presets can be recalled using the keyless entry system. See Memory Profile System in the Features chapter.
Using the Automatic Memory Store feature ("AUTOSET")
: If the memory buttons have been set, either by using the Auto Memory Load feature or if you have set them manually, the system is prepared tolet you use a convenient feature called Automatic Memory Store.
With Auto Memory Store, you can continually set strong stations into your memory buttons without losing your originally set stations. Your radio will automatically set your memory buttons to the strong local stations.
Activate Auto Memory Store by pushing the "AUTOSET" button once. Your radio will set the first six strong stations of the band you are in (AM, FMI or FM2) into the memory buttons. The display will flash "AUTO" and display the autoset icon "A" while the stations are being set in the memory buttons.
NOTE: If there are less than six strong stations in the frequency band, the remaining unfilled buttons will store the last strong station detected on the band. After all stations have been filled, the radio will begin playing the station stored on memory button 1.
To deactivate the Auto Memory Store mode and return to the manually-set memory button stations, simply push the "AUTOSET" button. Display will show "AUTO" then "OFF". The next time Auto Memory Store is activated on that band, the radio will store the next set of six strong stations.
Nov 23, 2014 | 1996 Lincoln Continental
Lock ion a radio station
TO PROGRAM THE MEMORY BUTTONS
Ten FM and five AM radio stations may be independently set. After programming the buttons,
pressing 1, 2, 3, 4 or 5 will instantly change the frequency to the preset station.
1. Turn power on.
2. Set the radio to desired station (see Tune or Seek Function).
3. Press and hold one of the desired memory buttons (F). The station setting begins flashing in
the LCD display (G). Continue to hold the button down until the flashing stops. The memory
button is now set.
4. Repeat steps 2 and 3 to set the other memory buttons.
Please see the attached images for the figure options.
Oct 19, 2014 | Dewalt DCO11 Radio
How to change the time on the clock
Without Radio Data Systems (RDS): To set the hour, press the clock button. The clock symbol will appear on the display and the hour number will flash. Then turn the ADJ knob to increase or todecrease. To set the minutes, press the clock button again. The minute numbers will flash. Then turn the ADJ knob to increase or to decrease. The time can be set with the ignition on or off.
With RDS: Same as without RDS unless you want to Sync. with a radio station. To synchronize the time with an FM station broadcasting Radio Data System (RDS) information, press and hold the clock button to enter the clock set mode, then press and hold the clock button for three seconds until UPDATED appears on the display. If the time is not available from the station, NO UPDATE will appear on the display. RDS time is broadcast once a minute. After tuning to an RDS broadcast station, it may take a few minutes for the time to update
Nov 29, 2010 | 2005 Chevrolet Cobalt
Setting the reset stations on a DAB radio
I used lateral thinking! looked at the instructions for my other matsui DAB radio and worked it out from there. With this Ferguson model you have to find the station you want manually and then press one of the preset buttons (it only has 4 but these are enough for me)
Jan 06, 2009 | Audio Players & Recorders
Need to change the 12v supply by the Radio
The Ford Focus has a stereo problem where the display blinks on and off, with or without the ignition on. This is not a power problem.
This problem occurs when attempting to store a radio station when a blank RDS signal is being transmitted.
To restore your stereo:
  • Insert a CD, stereo will turn on in CD mode.
  • Press MENU button
  • Select DEFAULT RESET by turning the right rotary knob and press to select
  • Select YES by tuning the right rotary knob and press select
  • Press BACK button
  • Press the RDS button once, display will read RDS OFF
  • Stereo will now work properly
To prevent this problem from occurring again, be sure some text is in the top line of the display when setting a stereo station. Do not set a station when the station name is blank in display.
Nov 16, 2008 | 2006 Ford Focus
How to preset a radio station on Sony CFD-S200 Cassette/CD boombox
You will need to use the Forward and Reverse buttons on the CD player. Set the station by holding the button you want to set it to until it blinks and shows the station number.
To set more that 10 stations. Press the (>10) button and then enter 11 or 12 or so on and set the stations the same as above.
Mar 31, 2008 | Sony CFD-S200 Cassette/CD Boombox
JVC KD-S26 Logo
50 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
