Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Hp c7200 won't feed photo paper - Kodak EASYSHARE 5500 All-In-One InkJet Printer
When I try to print photos from a memory stick it fails to print and tells me to load paper glossy side down even though there is enough paper properly loaded. When I take out the paper the top sheet has...
The problem is that the metal paper stop is not fully recessing into the guide at the rear of the printer and the photo paper is catching on the lip on top of the stop. Take the back cover off the printer and check that the guide has not moved out of position. Also try to twist the photo paper tray to the left or right so the stop lines up better with the guide recess. This worked for my printer tempoarily, but then things went out of allignment again, so I took a slightly more drastic step. With only a single sheet of photo paper in the tray, print another photo. When the photo tray slides back to deliver the paper to the rollers, unplug the power cord from the rear of the printer to stop the tray from moving forward again. With a pair of needlenose pliers, bend the lip on top of the metal paper stop upward. This fixed my problem permanently.
Oct 19, 2009 | HP C7200-69016 Network Adapter
Willl not feed 4X6 photo paper it jams up and
try feeding the paper in one sheet at a time.
Sep 14, 2009 | HP Office Equipment & Supplies
Can't print onto photo tray!
There should be a switch on the front to select the "paper feed". There should be an indicator laight to show which paper feed is active.
Aug 23, 2009 | HP C7200-69016 Network Adapter
Photo paper stops feeding through about 1 inch from end
Regular paper feeds?
Then use a single sheet of photo paper at a time with nothing else in the tray
Use a ord processor to see if there is t software glitch
Jul 27, 2009 | HP DeskJet 950c InkJet Printer
Wont feed glossy photo paper
Clean the feed roller(s) with a cloth dampened with alcohol. They are probably slippery with paper dust.
Mar 17, 2009 | HP Photosmart C5180 All-In-One InkJet...
My HP C7200 printer won't print from the photo tray
If you using a mac: After choosing the Photosmart C7200 to print your file on the print preview, change PAPER SIZE to 4x6, then lower down, change from PREVIEW to PAPER TYPE/QUALITY, more options will open underneath, on SOURCE, change from MAIN TRAY to PHOTO TRAY. You should also change the PAPER TYPE to some kind of PHOTO PAPER (whichever one your using, but the standard seems to be HP ADVANCED PHOTO PAPER)
Jan 27, 2009 | HP C7200-69016 Network Adapter
Setting up HP Photosmart C7200 All-In-One series printer to our IBM Desktop. We also have an IBM Laptop. Although we both have advanced degrees, the 'Basic Guide' is too lengthy and complicated for us. We...
This sounds as if you have a paper feed problem, and I presume it is still under warranty, I would go to hp.com support and either call them or use email to comunicate with a technician. Most printers have a page separator of sorts to keep all pages from being picked up. I am not familiar with your particular machine, but I am confident that HP can help you with this problem.
Aug 07, 2008 | HP Office Equipment & Supplies
Hello... i have a c7200 hp
sounds like it is now damaged or some bit od paper are still inside
Feb 18, 2008 | Computers & Internet
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
19 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
